Old Nov 01, 2010, 09:57 PM
Bill Sanford is offline
Find More Posts by Bill Sanford
Destructive testing expert!
Bill Sanford's Avatar
Bemidji, MN
Joined Dec 2003
Anyone tried building a helical antenna for FPV?
Hi Guys,
Has anyone tried to build a helical antenna for their FPV base station?
Helicals are circular polarized due to their design and this has many advantages for our application. Receive signal strengths are much more consistent when the plane banks.
Here's a starting point:
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=23560
I need to buy an ARRL Antenna Handbook. I've been a ham for many years and borrowed a friend's book for a few projects many years back. It may be time to invest in one for this aspect of the RC hobby!
Who will be the first to try this design? I'm guessing that someone already has...
Bill
Bill Sanford is offline Find More Posts by Bill Sanford
Old Nov 01, 2010, 10:15 PM
Bemidji, MN
Joined Dec 2003
This looks very interesting from the web site I mentioned.
Good gain, wide pattern and CP!
Try plugging in numbers on the web site. It's easy to get quite a bit of gain from this design to go really far out... The best part is no polarization issues.
Old Nov 01, 2010, 11:02 PM
cliffkot is offline
Find More Posts by cliffkot
cliffkot's Avatar
Joined Jun 2010
Helical Antenna
Circular polarization is the only way to go and Helical antennas are one good way to get it.
Not using CP is one of the reasons guys are losing video on long range flights. They fly out to the limits until the picture gets noisy which on an FM system is just a couple of db from lights out. Bank the plane and the picture is gone.
Here is a picture of one a friend of mine is building for his setup. It has a few bugs which he has to work out. but it will help him break the long distance record (which he set) for round trip fpv flight.
73
Cliff K.
BTW If you are interested in 23 cm video, check out my review of Sunsky system on the 1.2GHZ TX/RX All Infos on One Page site(or something like that), posts #411,412, and 414.
cliffkot is offline Find More Posts by cliffkot
Old Nov 01, 2010, 11:53 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
Is that antenna as big as it looks? ;P
Mikey-flies is offline Find More Posts by Mikey-flies
Old Nov 02, 2010, 03:14 AM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
I have a few built and tuned (spec an with VSWR brudge), they work well, not as convenient and portable as a flat patch though.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Nov 02, 2010, 03:16 AM
ssassen is offline
Joined Jul 2004
73
Cliff K.
Ps. take notice that the former you use to wind the helical on *will* shift your frequency down, as its dielectric properties become part of the antenna design. If you need me to get into further detail, just say so and I'll outline exactly what happens.
Cheers,
Sander.
Old Nov 02, 2010, 06:12 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I have been considering helical antennas for some time now, but have decided to go with a circular patch simply because it is compact.
Helicals are fairly easy to build, but it's finding a good form to wind around that's the problem. Of course, as Sander points out, if you know the dielectric constant of the material, you can calculate the frequency shift and compensate for it.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Nov 02, 2010, 08:12 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Reading the post title I got drawn as I thought someone was going to describe a CP antenna for the Tx. Better still, an omni directional CP solution.
Still interested to see what is being done on the Rx side of things.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Nov 02, 2010, 06:24 PM
cliffkot is offline
cliffkot's Avatar
Joined Jun 2010
Cheers,
Sander.
Yes, it will, but PVC pipe is not really necessary. I think Crist got a little carried away. He was building a bazooka! I think one about 24 inches long would be a good place to start.
Cliff K.
Old Nov 02, 2010, 06:29 PM
cliffkot is offline
cliffkot's Avatar
Joined Jun 2010
Nigel.
CP helical at current frequencies would be a bit unwieldy at the VTX end of things and is not necessary. As long as you use it at the receive end, you can maneuver the airplane any which way and receive the same signal as long as the planes antenna is reasonably omni. There are blind spots of course caused by the VTX antenna pattern, but it is then not a polarization issue. You can't fix everything, only the obvious flaws.
Cliff K.
Old Nov 03, 2010, 03:39 AM
Devonboy is offline
SW England
Joined Aug 2009
Cliff, agreed.
My interest is primarily at 5.8GHz and omni directional CP at the VTx to provide minimal multipath issues at the VRx. Also, 2 fliers could be at the same field, one with RHCP and the other with LHCP and potentially not interfere with each other.
Nonetheless, this is still an interesting thread to further explore the VRx end of things.
Nigel.
Old Nov 03, 2010, 10:14 AM
blupp is offline
Find More Posts by blupp
FPV is my cup of tea
blupp's Avatar
Sweden
Joined Mar 2010
"Left/Right circular polarized antenna ?" might be an interesting read.
blupp is offline Find More Posts by blupp
Old Nov 03, 2010, 10:20 AM
blupp is offline
blupp's Avatar
Sweden
Joined Mar 2010
True, but their TX antennas must be fully CP in the direction of the ground station.
If one banks more than 90 degrees, probably much less, it will interfere.
This is due to the fact that an omni directional CP is RHCP in one direction and LHCP in the other.
Old Nov 03, 2010, 10:22 AM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
In (just for the education).
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Nov 03, 2010, 10:23 AM
Bemidji, MN
Joined Dec 2003
Cliff K.
Yea, I chuckled when I saw Crist's antenna. He must be serious about going for the distance record. A helical with that many turns has over 20db of gain!
Discussion has anyone ever tried mounting a antenna on a gyro. stevessub27 FPV Talk 16 Oct 04, 2010 08:52 PM
Discussion Anyone tried hitec spectra 2.4 and 900mhz on tricopter for FPV? Xnaron FPV Talk 4 Sep 29, 2010 10:46 AM
Discussion Anyone tried the new spektrum carbon fuselage remote receiver(s) for FPV? wrex450 FPV Talk 2 Jul 23, 2010 06:01 AM
Discussion Anyone tried the Boomerang for FPV? IanJ FPV Talk 1 Dec 24, 2008 09:19 PM
Discussion Anyone tried GSM antenna for VTX? xeqouz FPV Talk 15 Sep 23, 2008 04:26 AM
