Old Nov 26, 2012, 08:07 PM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Australia, VIC, Melbourne
Joined Jan 2010
only try this with a well tuned and tested osd, and only with clear 360deg flying ground! accent rate and loiter radius MUST BE CONSIDERED.Safety first
WitnessOnly is offline Find More Posts by WitnessOnly
Old Nov 26, 2012, 08:11 PM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
How about hold it in the wing and just release it with 100% thrttle?
timtimtim is offline Find More Posts by timtimtim
Old Nov 26, 2012, 08:25 PM
Joined Jan 2010
You'll know when you know.... report back with which style you chose, and it didn't happen if theres no vid.
Best of rc luck to you
Old Nov 27, 2012, 09:37 PM
Kahnx is offline
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
Originally Posted by Stunt Double View Post
I have even witnessed the witness launch his skyfun in autopilot rth mode.... radio switched off, chuck the skyfun in the air and watch it fly itself!!! spooky
Now that's something I'd like to see!
Must not be using Eagletree, though - it know's when it's 'home' and wont activate autopilot.
Roger.
Kahnx is offline Find More Posts by Kahnx
Old Nov 28, 2012, 06:38 AM
scottdearinger is offline
Find More Posts by scottdearinger
Gravity? No, the Earth sucks
scottdearinger's Avatar
United States, IA, Des Moines
Joined Apr 2011
Here is what happens when a Radian sailplane pilot gets a fast setup on his skyfun- 84.7 mph ground impact !! it went back together !!! and it flies !! amazing little plane
HobbyKing Skyfun dives to it's death at warp speed (4 min 10 sec)
scottdearinger is offline Find More Posts by scottdearinger
Old Dec 03, 2012, 06:23 AM
Joined Jan 2010
This little baby on 3S draws 56A with 6x4 a safe 170kmh, today with a little wind assist.. 189km/h
Old Dec 03, 2012, 05:19 PM
Stunt Double is offline
Find More Posts by Stunt Double
Joined Oct 2007
189km/h plus you can slow it down and putt along at sensible speeds too, long-range flights, aerobatics!! This ship does it all. If there is a more versatile FPV platform that the skyfun let me know.
Stunt Double is offline Find More Posts by Stunt Double
Old Dec 03, 2012, 06:37 PM
Joined Apr 2012
Whats the slowest speed She Will do with total weight of 800-1000g?
Old Dec 03, 2012, 08:16 PM
Joined Jan 2010
Still air 40 is safe, can go down lower with skill... So have you got yours up timtimtim?
Old Dec 04, 2012, 07:38 AM
Joined Apr 2012
Yes, today actually! cold and snowy but those 5 minutes were enough i guess, sad my fingers.... im suprised how great she flies and how well she glides, but maby that is going to change when i put my FPV gear on it. now im wating for the spring so i can really test this out, its to cold and stupid to be outside these times how about you, any snow yet in melbourne?
Old Dec 04, 2012, 08:09 AM
Joined Jan 2010
Snow showers 2 hours from here but for us on Saturday 37degC Take your pick
Skyfun's a kitten.
Old Dec 10, 2012, 08:57 PM
Kahnx is offline
Registered DSer
Kahnx's Avatar
Joined Mar 2003
New Skyfun!
My new Skyfun had its maiden flight today.
The airframe flew brilliantly!
The Cyclops Storm OSD (RTH), though, did not (still troubleshooting that one).
Top speed on 3S with a Turnigy 2350 and a 6X5.5 on 3S was 154km/hr in level flight and still air. Not bad for a 2200 pack!
Even in still air it get a little yaw wobble - thinking about adding some extra fin area to the rear of the verticals.
Is it usual/necessary to put cooling air scoops to ventillate the cockpit?
Cheers
Roger
Old Dec 10, 2012, 09:29 PM
Joined Jan 2010
Clean Roger
Seems you'll be fine speed wise , Looking forward to seeing how that cam works rec wise, I like the look of them as a moveable second perspective option.
Oh and will also probably have Q's about the Cyclops, liking the size of it
Looking forward to having all 3 Skyfun's up at once
Old Dec 10, 2012, 10:02 PM
Joined Oct 2007
Kahnx, I think your skyfun will fit in just nicely.... i'll be out there somewhere under 399ft on the weekend hope you two can make it.
Old Dec 10, 2012, 11:20 PM
Kahnx is offline
Registered DSer
Kahnx's Avatar
Joined Mar 2003
I'm having trouble with the Cyclops stabilisation setup ATM. It seems to not like 'responsive' airframes - even a very low gain gives over-corrections. Awaiting some help from that forum. It's one of those products that could do with a firmware update. Nonetheless, in the spirit of keeping this one cheap and cheerful, I'll persist with the lost cost stuff, and hope to eventually get reliable RTH.
The plane itself flew very nicely. Once I get it properly dialled in, it'll be a great little flier. I'm hoping to be able to run either a single (lightweight) 3S2200, or put a pair of them in for greater endurance. The single pack is nicely forward in the cockpit, and there's plenty of room to move a twin-pack rearward to keep the CoG.
Roger.
Discussion Finally flew my Skyfun FPV aaron_gx FPV Talk 45 Jan 04, 2015 09:03 AM
Build Log First FPV build - JP Green Sleeve... Jonno271 FPV Talk 131 Dec 16, 2010 11:32 AM
Discussion How to build heavy Duty Antenna Tracking pod for Eagle Tree FPV? ganapati08 FPV Talk 6 Oct 19, 2010 12:24 PM
Gallery Scratch build EPP wing for fast FPV catching up with the winds tushev FPV Talk 4 Oct 18, 2010 10:32 AM
Discussion How heavy is your FPV Skyatec SKYFUN? aaron_gx FPV Talk 2 Apr 24, 2010 11:44 PM
