Well I know many of you have faster setups than this- but you may enjoy this video as I bust my speed cherry- I have been primarily flying Radian sailplanes and Easystars with an occasional warbird flight- rarely going over 50mph or so unless in a dive...
I will put some cams on the plane this weekend- was hesitant to do it on the Skyfun \ Microdan maiden... As My buddy Eckace tells me- I think you are hooked on speed now..
Joined Apr 2012
Where is the the CG on this bird? i just started everything up and there is a noise from the servos, sounds like they are singing... using http://www.hobbyking.com/hobbyking/s...dproduct=16342 whats the problem?
Digital servos tend to have better accuracy and resolution. I find they operate smoother. Analog servos typically use less power.
Depending on your motor setup, 6x4 is what I use with good success. I have never had a problem with the prop when using the finger holds. Toss it like a paper airplane at a 25-30* angle with full throttle, and it will just go... Here is a video from my buddies plane. I am in the yellow shirt, launching my skyfun at the very start. (my buddy chashed into me)
And, my version of the same event from my cam:
Joined Apr 2012
He knocked the nose off his plane, his flight cam was attached to it...
![]() Quote:
| Thread Tools | |
| Discussion Finally flew my Skyfun FPV | aaron_gx | Video Piloting (FPV/RPV) | 43 | Feb 17, 2011 12:27 PM |
| Build Log First FPV build - JP Green Sleeve... | Jonno271 | Video Piloting (FPV/RPV) | 131 | Dec 16, 2010 11:32 AM |
| Discussion How to build heavy Duty Antenna Tracking pod for Eagle Tree FPV? | ganapati08 | Video Piloting (FPV/RPV) | 6 | Oct 19, 2010 12:24 PM |
| Gallery Scratch build EPP wing for fast FPV catching up with the winds | tushev | Video Piloting (FPV/RPV) | 4 | Oct 18, 2010 10:32 AM |
| Discussion How heavy is your FPV Skyatec SKYFUN? | aaron_gx | Video Piloting (FPV/RPV) | 2 | Apr 24, 2010 11:44 PM |
