Old Oct 25, 2012, 04:55 PM
aaron_gx is offline
Find More Posts by aaron_gx
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
Originally Posted by ecworks View Post
Don't know if this has ever been attempted before but I've just about completed my Skyfun conversion to 2 motors, the Twin Skyfun.
Will maiden it tomorrow. Runs great on the bench. Produces 4 lbs of thrust with a 3 cell battery and balances pretty good with a smaller battery pushed far back.
All up weight 2.5 lbs. with 2800 mah battery.
The motor mounts have a slight toe-out to allow the 8" prop some clearance from the fuselage and yet have the motors as close in as possible.
I'll see how it behaves in the air tomorrow.
Vertical takeoff!! Lol, that thing looks crazy!
aaron_gx is offline Find More Posts by aaron_gx
Old Oct 25, 2012, 04:58 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
aaron_gx, I saw in one of your photos you added vertical stabs to the skyfun wingtips. Did that make much of a difference? Im getting a little bit of jiggle especially when its windy.
Stunt Double is offline Find More Posts by Stunt Double
Old Oct 25, 2012, 07:32 PM
aaron_gx is offline
aaron_gx's Avatar
Joined Jun 2008
Yes. It makes a huge difference in wag.
Night Ops (6 min 36 sec)
Old Oct 25, 2012, 07:39 PM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
Maidened the Twin Skyfun this afternoon.
http://www.rcgroups.com/forums/showt...6#post23101030
ecworks is offline Find More Posts by ecworks
Old Oct 26, 2012, 01:32 AM
ecworks is offline
Joined Sep 2011
Twin Motor Skyfun project
2x Master Airscrew 9" 3 blade counter-rotating props with 6.5 lbs of total thrust (4 cell) was too much to resist so I skipped ahead and installed landing gear to allow for clearance and much fun with take-offs and landings:
Old Oct 26, 2012, 08:08 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
is there a problem with mounting the 2350KV motor on the stock mount?
timtimtim is offline Find More Posts by timtimtim
Old Oct 26, 2012, 10:45 AM
aaron_gx is offline
aaron_gx's Avatar
Joined Jun 2008
im still flying my 2350 with the stock mount over a year later. I broke the stock mount on my first skyfun, in a crash.
Old Oct 26, 2012, 08:37 PM
ecworks is offline
Joined Sep 2011
Maiden flight of the twin motor Skyfun w/landing gear
Maiden flight Twin Motor Skyfun w/landing gear (1 min 4 sec)
Old Oct 26, 2012, 10:09 PM
ecworks is offline
Joined Sep 2011
Trying to figure out how to control the twin motor Skyfun during vertical launch.
The scientific method at it's finest...
The pretty powerful propwash over the elevons provides pretty good directional control if I can get the hang of it. May have to dial down the dual rate
Twin Motor Skyfun Vertical Takeoff testing (1 min 40 sec)
Old Oct 27, 2012, 10:55 AM
ecworks is offline
Joined Sep 2011
Tri-Motor Skyfun
Twin motor Skyfun was a success. Bobbled the landing and broke the right motor mount.
Replaced it and pushed on to new frontiers.
Introducing...the Skyfun Tri-Motor:
Old Oct 27, 2012, 02:41 PM
Joined Apr 2012
How about mounting that dog on that famous airliner?
Old Oct 27, 2012, 09:11 PM
WitnessOnly is offline
Find More Posts by WitnessOnly
Cleared for take off...
WitnessOnly's Avatar
Joined Jan 2010
Nice work EC, any plans to fpv it? Would be cool to see a full takeoff to landing flight with the rolling undercarriage
WitnessOnly is offline Find More Posts by WitnessOnly
Old Oct 27, 2012, 10:44 PM
ecworks is offline
Joined Sep 2011
Not planning any FPV, I've got the Twin Raptor and the Twinstar for that. This is more of a proof of concept project using a previously almost destroyed Skyfun.
Old Oct 27, 2012, 10:47 PM
ecworks is offline
Joined Sep 2011
Got the Tri-Motor Skyfun wired up and working.
Using (3) NTM Prop Drive Series 28-26A 1200kv / 250w
and 3 x Master Airscrew 3 blade 7" props w/ 3 x Turnigy Plush 30am ESC's
With a 4 cell it's generating over 5 lbs of thrust.
All up weight with 3300 mah battery: 2lbs 8 oz.
And yes, those are canards...
Old Oct 27, 2012, 10:56 PM
ecworks is offline
Joined Sep 2011
Skyfun Tri-Motor bench test (0 min 19 sec)
Discussion Finally flew my Skyfun FPV aaron_gx FPV Talk 45 Jan 04, 2015 09:03 AM
Build Log First FPV build - JP Green Sleeve... Jonno271 FPV Talk 131 Dec 16, 2010 11:32 AM
Discussion How to build heavy Duty Antenna Tracking pod for Eagle Tree FPV? ganapati08 FPV Talk 6 Oct 19, 2010 12:24 PM
Gallery Scratch build EPP wing for fast FPV catching up with the winds tushev FPV Talk 4 Oct 18, 2010 10:32 AM
Discussion How heavy is your FPV Skyatec SKYFUN? aaron_gx FPV Talk 2 Apr 24, 2010 11:44 PM
