Old Nov 01, 2010, 08:52 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Build Log
FPV Skyfun build
After flying my Easystar for a while now, I felt the need for speed.
So I bought a Skyfun from Hobbyking.
An EZ OSD and 400mW 1.3GHz Tx from Readymade RC.
I will also be running a Thomas 12 channel long range RX.
I was thinking of using a go pro for the main flying camera to save weight, but I would be open to suggestions here. Is it better to use a different flying camera. or should I just go with the go pro?
I'll post some pics when I get going!
I'd like to see how others may have mounted a go pro on the Skyfun...
Gree is offline Find More Posts by Gree
Old Nov 01, 2010, 09:05 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Go GoPro! I'd love to see crazy low flying through trees like you Aussies are famous for. BUT, in HD.
Kmart is offline Find More Posts by Kmart
Old Nov 01, 2010, 09:36 PM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Sounds like fun...
But why would you use such kit for that kind of aircraft? Looks more like a fun around the park plane...which probably does not need an OSD and a LRS...
scrtsqrl is offline Find More Posts by scrtsqrl
Old Nov 02, 2010, 02:02 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Because I want to go cloud surfing! Nothing wrong with long distance, speed and knowing where the hell you are
Kmart you know which go pro is going in there don't you?
Old Nov 02, 2010, 09:40 AM
aaron_gx is offline
Find More Posts by aaron_gx
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
gree, you might be the first to mount a gopro on a skyfun.
I think mine would fly like crap with a big un-aerodynamic brick on it. But mine is a franken-skyfun. I've attached some pictures of it from the last rebuild.
The way I have it setup here I feel is optimum weight and balance for it. I've flown it heavier, and I've flown it lighter, but this seems to perform the best.
aaron_gx is offline Find More Posts by aaron_gx
Old Nov 02, 2010, 09:46 AM
aaron_gx is offline
aaron_gx's Avatar
Joined Jun 2008
Originally Posted by scrtsqrl View Post
Sounds like fun...
I agree here... The skyfun is a quick, small, light plane for crazy flying! I've flown it hard, and put it away wet since day one, and its still kicking. I want to fly through tree openings, under bridges, surf ridges, and not have to worry about losing the plane and breaking the bank if I do.
OSD, gopro and other expensive equipment would just deter me from doing crazy stuff that makes good videos
Old Nov 02, 2010, 04:46 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Well I'll give it all a try anyway. If it doesn't work or is too heavy I can always take all the whizzbang stuff off and buy a Zepher to join the Trappy crowd
I have test the views on different places on the plane with the Go Pro hooked up to my tv. If I use it I plan on sinking it into the nose, so I just get a bit of the nose in the picture. The camera position to achieve this is actually quite sunken, so about half of the camera would be sticking up and the rest buried in foam.
I am still undecided about the heavy go pro or a normal camera. It is just that my ground recorder is really crap so videos look poor. And I don't want to buy a new one.
Plus a free go pro is a terrible thing to waste!
I am waiting on the OSD and video tx to arrive, so I think I will assess the situation then... Hopefully shouldn't be too long.
Old Nov 02, 2010, 06:16 PM
mrleenagle is offline
Find More Posts by mrleenagle
fpv addict
mrleenagle's Avatar
Sydney, Australia
Joined Nov 2007
How did you get a free gopro?
mrleenagle is offline Find More Posts by mrleenagle
Old Nov 02, 2010, 07:31 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
The Lucky So-and-So won a contest/free give-away....
galaxiex is offline Find More Posts by galaxiex
Old Nov 02, 2010, 08:46 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Ohhhhhhhhhh yeeeeeeeeeeeeeaaaaaaaaah
Old Nov 02, 2010, 08:47 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Looks like the EZ OSD may take a while to come in, so I may build it sans OSD to begin with and see how we go from there...
Old Nov 04, 2010, 07:46 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
The Skyfun was my very first plane( and I think best).
Looking forward to seeing the progression.
This plane is awesome.
NDw is offline Find More Posts by NDw
Old Nov 06, 2010, 06:13 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Thanks. I should be able to get to it next week!
Old Nov 19, 2010, 05:17 PM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Well I swapped the EZ OSD for an Eagle Tree since there was no eta from the store on when stock would be arriving. All my gear is shipping as we speak so it should be here sometime next week.
In the meantime I am sitting down today to do the majority of the build so hopefully there will be some posts with pictures in here soon!
Old Nov 19, 2010, 05:41 PM
NDw is offline
NDw
NDw
Joined Aug 2010
I've yet to see a better looking plane in the air
just be carefull of your fingers if not using the stock setup!
Discussion Finally flew my Skyfun FPV aaron_gx FPV Talk 45 Jan 04, 2015 09:03 AM
Build Log First FPV build - JP Green Sleeve... Jonno271 FPV Talk 131 Dec 16, 2010 11:32 AM
Discussion How to build heavy Duty Antenna Tracking pod for Eagle Tree FPV? ganapati08 FPV Talk 6 Oct 19, 2010 12:24 PM
Gallery Scratch build EPP wing for fast FPV catching up with the winds tushev FPV Talk 4 Oct 18, 2010 10:32 AM
Discussion How heavy is your FPV Skyatec SKYFUN? aaron_gx FPV Talk 2 Apr 24, 2010 11:44 PM
