Old Nov 01, 2010, 01:14 AM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
Help!
how to fix this hobby king plane
bought one of those flying wings from hobby king i think it was designed around slope soaring but the manufacturer included a motor mount for electric power so i powered mine with the 2212/6 grayson hobby park jet motor good for 80mph the plane suffered really bad wing flap and loss of control plus tip stalling at high speeds while turning so i added strips of fiber tape to the top and bottom of the wing than covered the whole wing with clear packing tape this has stopped most of the wing flap but now it suffers tip stalling on a fresh charged battery using full throttle if i fly 2/3rd throttle it behaves nicely anymore throttle its just way out of control
how can i fix this? first video shows full throttle on a half charged pack second video shows full throttle on a 3/4th charged pack i had used it a couple of days ago for CofG adjusting i also crashed at the end of the second video because the plane keeps pitching up and down while i try keep level flight
Untitled (2 min 2 sec)
http://vimeo.com/16383660
gazza2003au is offline Find More Posts by gazza2003au
Old Nov 01, 2010, 01:27 AM
Zootster is offline
Find More Posts by Zootster
Joined Jul 2007
Can you dial in some Expo? May tame it down at high speeds.
Zootster is offline Find More Posts by Zootster
Old Nov 01, 2010, 01:33 AM
Sydney, Australia
Joined Jul 2003
no expo on my radio the twitchy movements at the start of the second video was mostly from the plane i was hardly controlling it some of the turns the plane was doing by its self and others i couldnt control so i throttled back before the plane flew over farms and the main road once throttled back i had full control
Old Nov 01, 2010, 03:41 AM
Peril is offline
Find More Posts by Peril
Jets Suck (and blow)
Peril's Avatar
Australia, QLD, Deception Bay
Things I noted from your text that may help.
I'm not sure where the plan lists your CoG to be, but plans and not always correct.
Planes that pitch up and down and are sensitive to input are displaying a typical 'nose light' symptom. Add nose weight and the plane should settle down in pitch stability. Tip stalling at speed can and does occur in most aircraft when you exceed the flying envelope ie. pull to much 'G' by having to much elevator movement (or is nose light). You can limit the travel by using the inside hole on the servo, and the outside hole on the elevator horn.
Tip stalling is a symptom exacerbated by a nose light condition.
Hope this helps.
Peril is offline Find More Posts by Peril
Old Nov 01, 2010, 03:57 AM
Sydney, Australia
Joined Jul 2003
i set the CofG in between the two points i think the pitching could be from the wing flexing bending the elevons out of shape? as they are EPP reinforced with carbon rods
Old Nov 01, 2010, 04:33 AM
glydr is offline
Find More Posts by glydr
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
The lack of rigidity of the elevons could be part of it - though plenty of MS Swifts with floppy elevons fly nicely.
Wings are particularly pitch sensitive. A well programmed computer radio will have very fine up/down (elevator) elevon movement with relatively large left/right (aileron) movement.
Sounds terribly like a rear CoG as mentioned above. Wings (generally) need a fair amount of forward CoG. I was reading a book about one example where the distance between CoG for controllable flight and the CoG of an uncontrollable spin was calculated to be the width of a match.
Could also be the thrust angle on the motor - should be angled slightly up when pushing a wing for the same reason a pulling prop has 'downthrust'. The trouble you have at high throttle could signal this problem as the motor is trying its hardest to push the nose down, so you pull up to correct, its going fast and there is a fair amount of travel on the elevon so it zooms up, so you push down etc etc etc. If you get to height, close throttle and just glide down (no motor thrust playing with pitch) and find it quite controllable this could well be the case.
Most of the advice comes from the text - hard to tell from watching a plane unless your thumbs are on the sticks.
I'm sure these things can be made to fly well.
glydr is offline Find More Posts by glydr
Old Nov 01, 2010, 04:50 AM
me_wantee is online now
Find More Posts by me_wantee
Not a Doctor
me_wantee's Avatar
Australia, NSW, Sydney
Joined Aug 2006
Stiffening the elevons or replacing them with balsa would be a good start.
You could also stiffen the trailing edge with 3x1 carbon and then taping over it.
If you wanna go fast, you need a stiff wing.
me_wantee is online now Find More Posts by me_wantee
Old Nov 01, 2010, 05:46 AM
Swoopdown is online now
Find More Posts by Swoopdown
C'mon more Energy
Swoopdown's Avatar
Melbourne, Australia
Joined Mar 2005
I'm betting your rates are too high on your elevator. My ms swift2 I was able to take my cg heaps further back than recommended. How does it dive test motor off of course? Does it tuck or flare? I'm with me wantee on a stiff wing. Thin carbon spar and some balsa ailerons would help heaps.
Swoopdown is online now Find More Posts by Swoopdown
Old Nov 01, 2010, 05:51 AM
Sydney, Australia
Joined Jul 2003
the wing its self has 3 spars in a A shape another two spars are in the elevons there is 2 lengths of fiber tape each side of the wing top and bottom plus clear packing tape and the wing still flexes a fair amount and in the last video when i crashed from the death spiral it tore the motor mount off i will hot glue it back on might be a little tricky getting the right angle again but i will get it flying correctly hopefully sooner than later and i thought about replacing the elevons with balsa but the TE is about 12mm at the root and 10mm at the tip so if i get 10mm balsa sheet thats going to be a a lot of sanding
Old Nov 01, 2010, 05:55 AM
C'mon more Energy
Swoopdown's Avatar
Joined Mar 2005
Tip stalling and other poor handling behaviours with flying wings can be put down to to much nose weight and needing to use too much elevator (read drag) to compensate. Tale it up high motor of and Di e it ay 30 degrees. Wings (and most models for that matter) should stay pointed in the same dive or if anything a slight pull out. If it flares its nose heavy, if it tucks its tail heavy.
Old Nov 01, 2010, 05:58 AM
C'mon more Energy
Swoopdown's Avatar
Joined Mar 2005
Twist will kill handling. Unless you tape it in 45 degrees tape and spares do little for the twist.
Old Nov 01, 2010, 06:00 AM
Sydney, Australia
Joined Jul 2003
possibly i did have it on full rates i have the push rod connected to the outer control horn and servo arm holes i just had another look at the instructions it says nothing about elevon movement amounts but today i did add 11grams more lead to the nose (second video first video minus 11grams)
Old Nov 01, 2010, 06:47 AM
C'mon more Energy
Swoopdown's Avatar
Joined Mar 2005
From neutral I wouldn't imagine you should need any more than 8mm and thats allowing the fact that they will flatten out at speed. If you had balsa or stiffened elevons that won't twist I'd only use 4 or 5mm.
Some high performance planks only needs 1mm.
Goodluck
Old Nov 01, 2010, 06:48 AM
Zootster is offline
Joined Jul 2007
Buy a good plane....
Old Nov 01, 2010, 06:50 AM
Kookaburra is offline
Find More Posts by Kookaburra
winds light to variable
Kookaburra's Avatar
Australia, SA, Woomera
Joined Apr 2009
Perhaps consider writing this one off to experience and buying a decent aircraft. You gets what you pays for. Can recommend one of the Windrider Bee series.
Kookaburra is offline Find More Posts by Kookaburra
Rant Hobby Partz not releasing money!!! RAIDENSAM, HOW LONG WILL YOU IGNORE THIS THREAD? mt_100 HobbyPartz.com 10 Oct 20, 2010 07:11 PM
For Sale This plane started it all. The Hobby Zone Super Cub wavo Aircraft - Electric - Airplanes (FS/W) 6 Sep 03, 2010 06:07 AM
Discussion How to fix extreme nose heavy plane? GEARHEAD_ENG Fuel Plane Talk 9 Sep 01, 2010 04:23 PM
Discussion Help! what plane is this? and how do i fix it? Flying Scotsman Foamies (Scratchbuilt) 12 Sep 06, 2009 12:29 PM
Question Hobby City profile edf 64, how do i fix this? BCBasher Foamy EDFs 7 Jun 05, 2009 08:01 PM
