I taught myself to fly with the DAW 1-26 glider. The EPP foam is key, as you *will* crash ten to twenty times if you are learning by yourself. It does not thermal terribly well, but it'll work well off of a high-start. Also look into the highlander EPP 2-meter glider at www.madaircraft.com .
Do you have an instructor? I very highly recommend that you have someone help you. It'll save you a lot of time when you don't have to unlearn bad habits. Are you intending on going electric later on? If so, I'd look into Darwin Garrison's Push-E-Cat (search for threads on ezone). It's basically an EPP glider with speed 400 power. It's worthwhile to invest in a versatile speed 400 system early on. One last word of advice: don't try to be too cheap on your initial investments, lest you find yourself buying the same thing again. I.e. get a solid radio system, charger, etc. G'luck, Lee |
The 1-26HLG built as a polyhedral is a good thermalling glider. It's much too heavy to handlaunch, but works great off a highstart. Keep it light by covering it with Econocote or Micafilm.
The Highlander thermals well but you have to be sure to build the fuse rigid enough that the tail doesn't flex during turns. Here's a link with construction tips that will give you an idea of what's involved. http://msinow.com/rc/highlander_cons..._and_links.htm The TG-3 is mostly a slope plane that doesn't thermal as well as the Highlander or 1-26. In the old days (4 years ago), before speed 400 planes became popular, you started with training gliders and that was your only choice. With a Push-e-cat or T-52 you will learn the fundamentals much faster. Then you can move to a thermalling glider. Unless you really have your heart set on a glider, I'd recommend either a Push-e-cat or a T-52. In addition to their training qualities, these planes will thermal, especially if built light. Best of luck. |
Hudson, Ohio
Joined Oct 2001
Hi!
I posted this at www.rcgroups.com but i'm not sure how things are working. So, I don't plan to get any help, i have a lot of time on my hands and i don't mind trying things out. I'll probably be flying this in open field, not much of a slope. Als, i'm pretty set on an EPP plane for durability. I know very little about r/c airplanes. I'll probably get an average 4 channel radio. I want it to be durable (i'm positive i'll be crashing it a lot) and easy to learn to fly on. I'm open to any other plane out there, but i read some good things about the 1-26. Maybe the "Javelin?" <<I'm a beginner, i've been into R/C cars for a little while, but i've wnted to expand into airplanes, preferably sail planes. 've been tryign to find anythign i could online and i think i've decided on an EPP one. I've been looking at the 1-26 hlg foamie and it sounds good. I'm not really going to be doign anythign special with it. I'll probably be flying it just in an open field. Also, i'll probably be hand launching it. thanks for any info!!>> Thanks for ant help! -Ed |
| Thread Tools | |
| Dave's Aircraft Works Extra 300s or Staudacher Review? | Herb | Foamies (Kits) | 9 | Oct 15, 2009 06:37 AM |
| Question Good trainer? Dave's Aircraft Works Schweitzer 1-26 2-meter | icmartin | Sailplane Talk | 3 | Apr 04, 2007 08:53 PM |
| Found: Dave's Aircraft Works Foamie 1-26 2Meter | Matt Galland | Slope | 0 | Dec 02, 2005 06:51 AM |
| Sold FS: NIB Skyking / Dave's Aircraft Works 2m Schweizer 1-26 | surfimp | Aircraft - Sailplanes (FS/W) | 2 | Jun 20, 2005 10:43 PM |
| Dave's Aircraft Works TG3 | Kodaflyer | Foamies (Kits) | 0 | May 18, 2001 08:59 AM |
