Old Oct 31, 2010, 03:07 PM
Jason Lilly is offline
Find More Posts by Jason Lilly
Go Faster!!
Jason Lilly's Avatar
San Diego, CA
Joined Apr 2004
New Product
***Introducing the NEW 60" Molded JW***
I have good news! Bill and I built and flew the new 60” molded JW on Saturday 10-30-10. The build was super quick and easy. We met at the shop at 10:30 am, worked a few hours, had some lunch, fooled with the new linkages and cg for about another hour and then headed up to Blossom Valley for the maiden flight. The big day had finally arrived! The final AUW for this first, (light) JW was about 50 ozs. The DS versions will be at least 20-30 ounces heavier. When we arrived at the hill the wind was light, about 10-15, but there were several other gliders in the air so we knew there was enough lift for the first flight. We carefully measured the cg and placed it about an 1/8” forward of what a typical foam JW is. The first launch was perfect and the plane lifted into the air with ease! We noticed that the new molded Dub required a lot of down trim. We landed the plane, strapped about 1 oz of lead to the nose and launched it again. This time the new molded JW felt perfect! Bill and I flew for another 15 minutes and called it a day with a perfect landing on soft straw. We ended our afternoon with a well deserved HIGH FIVE! We think everyone will love this new bird.
I want to thank Steven Seim from CyberModelle, www.CyberModelle.com, for doing an awesome job with all of the cad work. We sent Steven the original 2D dimensions that Pat Bowman came up with for the JW as well as the airfoil that Joe Wurts tuned specifically for this molded JW. Steven proceeded to take all this data and whip up a large portion of CAD magic to create the 3D art work for the final design.
Here are a few of the finer points that were used in developing the new molded JW.
1. The total fuselage volume has been dramatically reduced while still keeping the same overall length.
2. The airfoil section has been further tuned by Joe Wurts to be appropriate for a fully molded aircraft. The airfoils do not consist of straight lines between coordinate points, Steven rendered them as fully contiguous curves ideal for modern machine carving.
3. The geometry of the wing has been fully restored to the exact dimensions and sweep angles called for by Joe Wurts, which wasn’t possible up until now with EPP foam and wire cutting.
4. There is a elegant full chord fillet (top and bottom) that blends the fuse into the wing. The end result is a rock solid wing mount without and rocking. The wing mounts just like an opus but it’s upside down so there is virtually no load on the wing bolt for positive G maneuvers. We have not tried it yet but I think a nylon bolt will be a good option for lighter conditions.
5. The radio gear mounts through the bottom of the aircraft up into the nose, a configuration that keeps the aggregate aircraft very clean.
6.The aircraft is designed for utter simplicity. Build time is about 3-4 hours and that’s with a 1 hour lunch break!
7. The new molded JW will be made available in at least 2 versions. The first version will be a light one for front side and mild DS. The second one will be a heavier one for ballistic front side and heavy DS.
8. The plane comes apart into 2 pieces for easy transportation.
9. The servo drive system is a top drive bottom hinge setup. The wing accepts full size servo’s with a flush mound cover on the bottom and a small fairing on the top.
We look forward to receiving our first production run, and will keep you all posted!
We are headed up to Blossom again today for more testing....
Jason Lilly is offline Find More Posts by Jason Lilly
Old Oct 31, 2010, 03:21 PM
timbuck is offline
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
NICE work guys , way to go !!!!!!! Carn't wait to see a DS version wound UP..... 300mph plank record
Tim
timbuck is offline Find More Posts by timbuck
Latest blog entry: More colours
Old Oct 31, 2010, 04:02 PM
StevenSeim is offline
Find More Posts by StevenSeim
A dream will find you
StevenSeim's Avatar
North Bend Washington
StevenSeim is offline Find More Posts by StevenSeim
Old Oct 31, 2010, 04:07 PM
Aerogance is offline
Find More Posts by Aerogance
U down with EPP? Ya U know me!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
I will take the first one, Bill won't mind
Aerogance is offline Find More Posts by Aerogance
Old Oct 31, 2010, 05:07 PM
screamin' eagle is online now
Find More Posts by screamin' eagle
R/C Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Sick.
screamin' eagle is online now Find More Posts by screamin' eagle
Old Oct 31, 2010, 06:11 PM
Bill L is offline
Find More Posts by Bill L
Bill L's Avatar
San Diego
Joined Apr 2003
Don't think so
B
Bill L is offline Find More Posts by Bill L
Old Oct 31, 2010, 06:29 PM
Bill L is offline
Bill L's Avatar
San Diego
Joined Apr 2003
We will be ordering 15 planes 5 with the current layup and 10 with the heavier DS layup in the next few days.
We are also working with a European distributor so more details to come.
Old Oct 31, 2010, 07:01 PM
Go Faster!!
San Diego, CA
Joined Apr 2004
The second day of testing went well today. We are still adding more nose weight little by little.
Old Oct 31, 2010, 07:15 PM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Iceland, Siglufjörður
Joined Sep 2008
Love the no load upside down wing idea !!! Very cool.
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Oct 31, 2010, 07:17 PM
Bill L is offline
Bill L's Avatar
San Diego
Joined Apr 2003
action shots
Action shots, going to try and post some video later
Old Oct 31, 2010, 07:20 PM
Bill L is offline
Bill L's Avatar
San Diego
Joined Apr 2003
More pictures
Old Oct 31, 2010, 07:31 PM
Aerogance's Avatar
Joined Sep 2008
Great shots, it has a very streamlined fuselage. I think it is fantastic to have them made with a light and heavy layup option since the design is so versatile. Way to go.
Old Nov 01, 2010, 04:29 AM
sll914 is offline
Find More Posts by sll914
sll914's Avatar
Joined Oct 2003
You guys nailed it with this one! Really nice looking work, that wing fillet looks perfect! I can't wait to get some of these! A molded JW is a dream come true. Love the fact that you can easily remove the fuselage to make packing the truck easier...
On another note:
Jason, I think you need to have a talk with Bill about his throwing form
sll914 is offline Find More Posts by sll914
Old Nov 01, 2010, 05:22 AM
timbuck is offline
Nothing is easy
timbuck's Avatar
Joined Aug 2008
LOL i like it spencer , i think it brings out Bills feminin side
How did you go with the vid , right way up yet ?????
Tim
Old Nov 01, 2010, 05:57 AM
KingOfTheHill is offline
Find More Posts by KingOfTheHill
Ninja of the Nasty
KingOfTheHill's Avatar
Joined Jan 2004
No kidding!... I have dreamed of such an animal for a very long time.
That is just amazing to see. Way to go guys
KingOfTheHill is offline Find More Posts by KingOfTheHill
Discussion 60" C-5 Galaxy fully molded (in work) PANTHERFLYR Scratchbuilt EDFs 22 Jan 15, 2011 12:20 AM
For Sale 60" jw new in box Bill L Aircraft - Sailplanes (FS/W) 5 Jul 13, 2007 09:41 PM
Discussion Wanted new 60" JW John Kim Dynamic Soaring 5 Mar 13, 2007 07:28 PM
Wanted New in Box 60" JW John Kim Aircraft - Sailplanes (FS/W) 2 Mar 12, 2007 10:42 PM
My NEW 60" JW KingOfTheHill Slope 27 Jun 17, 2005 09:47 AM
