Old Nov 15, 2010, 03:15 PM
orange&white is offline
Find More Posts by orange&white
Scott R/C Time Pilot
orange&white's Avatar
NorthBend/Coos Bay,Oregon USA
Joined Dec 2009
The Tomboy is looking good It looks like you have the right amount of dihedral, remember that there is a two rib flat center section in the wing.
orange&white is offline Find More Posts by orange&white
Old Nov 16, 2010, 10:10 AM
owlsabie is offline
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Thank you! Glue and flat piece(which I almost forgot) going on shortly.
owlsabie is offline Find More Posts by owlsabie
Old Nov 16, 2010, 12:41 PM
owlsabie is offline
owlsabie's Avatar
South Africa
Joined Feb 2009
Last pictures
The last pics for a while . . .
The wing is done, I have the one inner rib a little misglued, but its not a biggie as I can hide it. Thanks for reminding me about the flat middle Scott - luckily I checked your thread again before getting brave with the glue.
The servos are mounted on the current balance point. That way I hope that after covering and finishing the battery will be under the main cabin somewhere. With all the models I've built from plans I've always had a problem with servos that need remounting, and look messy - so I used up some of the weight I've tried to save, to make a good sturdy servo mounting.
For controls I have some flexible plastic pushrods that I want to try, then its just the fiddly bits and covering. I can't believe this build is almost over
Old Nov 19, 2010, 09:41 AM
owlsabie is offline
owlsabie's Avatar
South Africa
Joined Feb 2009
Tails
I almost had to rebuild the fin - in my enthusiasm I forgot that it's not going to help if I hinge the rudder, and then glue it onto the stab . . . sounds obvious, but thats what happens if you start to hurry! anyway, no damage done, but I think this is going to be a slightly strange looking Tomboy
Why the sudden hurry? I've got it into my head that I want to see if I can float the Sinbad around for 30 minutes next weekend, and then try the same with the Tomboy. It should be possible I think?
Old Nov 19, 2010, 10:27 AM
Joined Dec 2009
I like the motor cover. You will be pleased when you get the Tomboy going, it floats pretty good. Also remember to sheet the front of the fuselage on the side and bottom, it's needed for strength. I think it is looking pretty good
Old Nov 20, 2010, 04:01 AM
owlsabie is offline
owlsabie's Avatar
South Africa
Joined Feb 2009
Tailplan ready for covering, as is wing - will start later as I now sneezing from sanding
Owl (atchoo!)
Old Nov 20, 2010, 04:18 AM
Joined Dec 2009
Hey Owl, I meant to sheet the front of the fuselage
Scott
Old Nov 20, 2010, 11:19 AM
owlsabie is offline
owlsabie's Avatar
South Africa
Joined Feb 2009
Wing covered with relatively few wrinkles - the tail is next. I've got the rudder sorted, but I've added a cap strip from 1mm balsa over the center rib of the stab to give me something to glue it onto. Once I'm happy with tail I'll do the bit at the front of the wing and finish the front of the fuse. I'm saving it for last so that I can be sure my hatches, wiring and control cables are in the right places.
I'm really enjoying thus build
Old Nov 20, 2010, 03:25 PM
ColinNZ is offline
Find More Posts by ColinNZ
ColinNZ's Avatar
Auckland New Zealand
Joined Aug 2004
Keep those pics coming Owl.
ColinNZ is offline Find More Posts by ColinNZ
Old Nov 20, 2010, 04:14 PM
Joined Dec 2009
You know, for being a relatively new guy on the model scene, you are kicking ass on scratch building, including designing your own models.
Scott
Old Nov 20, 2010, 05:34 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
I have a Klarich short kit that I had him blow up but just forget what size, maybe 48". I should pull it out and get going.
Bill
williame3590 is offline Find More Posts by williame3590
Old Nov 20, 2010, 06:27 PM
Joined Dec 2009
Bill
Yes you should, immediately, and enter the 2011 Vintage Old-Timer build off with it
Scott
Old Nov 21, 2010, 02:34 AM
owlsabie is offline
owlsabie's Avatar
South Africa
Joined Feb 2009
With a short kit, this would be an even faster build!
Thanks guys - but I'll put up photos when its done, at the moment its just bits of aeroplane and shrink wrap and bad language when the cats want to help . . .
Old Nov 21, 2010, 06:09 AM
owlsabie is offline
owlsabie's Avatar
South Africa
Joined Feb 2009
OK - just a teaser . . .
The covering is not going well, but I think at least it will be functional. I think I'm trying too hard, I haven't struggled like this for a while!
Old Nov 21, 2010, 06:43 AM
Joined Dec 2009
I dont know what you are talking about, the covering looks great.
Discussion And yet another AR drone Arial Video project taudronis Multirotor Talk 17 Dec 07, 2010 11:04 AM
Discussion Yet Another PZ Sukhoi Hack.. del Scratchbuilt Indoor and Micro Models 1 Oct 27, 2010 07:45 PM
Question Yet Another Charger Question -- Features ZackJones Batteries and Chargers 0 Oct 24, 2010 06:53 PM
Idea Yet another parallel balancing by dumping one battery into another one. everydayflyer Batteries and Chargers 11 Oct 23, 2010 08:12 PM
