Old Oct 31, 2010, 11:02 AM
airbagit13 is offline
Find More Posts by airbagit13
Plane Destroyer / Life Enjoyer
airbagit13's Avatar
Miami, FL
Joined May 2009
Whats your favorite way to loose altitude?
Currently (as in today) my favorite way to loose altitude is to go inverted and pull an inside loop and repeat. I guess any way you come down without destroying your plane is great but some are just more FUN!
airbagit13 is offline Find More Posts by airbagit13
Old Oct 31, 2010, 12:16 PM
Merlin1205 is offline
Find More Posts by Merlin1205
USA, FL, Winter Haven
Joined May 2006
I'm old school, I just lower the throttle
Merlin1205 is offline Find More Posts by Merlin1205
Old Oct 31, 2010, 12:17 PM
Tepid Pilot is offline
Find More Posts by Tepid Pilot
Built For Comfort
Tepid Pilot's Avatar
South Central Texas
Joined Aug 2009
Spin or split-s.
TP
Tepid Pilot is offline Find More Posts by Tepid Pilot
Old Oct 31, 2010, 12:42 PM
Captain Dunsel is offline
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
It depends on what I plan to do next. If it's an emergency landing (i.e., there's a full-scale coming into our shared field) and I need to land RIGHT NOW, I'd rather spin down to pattern altitude, then land. Spinning keeps the plane from picking up too much momentum, which I'd have to bleed off before landing.
If it isn't a an emergency, I may split-s, cut power and slip, or just cut power and spiral down. The first preserves momentum, so if I want to go back up, have speed for a maneuver, or just go fast, it's the one I choose.
CD
Captain Dunsel is offline Find More Posts by Captain Dunsel
Old Oct 31, 2010, 12:48 PM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
"Lose" is the word you want there. "Loose" is what your belt is, when you lose your pants.
Lancer31 is offline Find More Posts by Lancer31
Old Oct 31, 2010, 12:53 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Point the nose down, punch WOT, pull up 3ft. from the ground
Xpress.. is offline Find More Posts by Xpress..
Old Oct 31, 2010, 02:22 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Xpress, it's fun to be able to rely on those carbon spars
I'd have to say that if I want to drop altitude FAST I like to point the nose down and do vertical rolls with or without throttle. This keeps the plane headed straight down toward a fixed point on the ground.
If I'm trying to lose altitude and change direction I roll inverted, point the nose down ... and let 'er drop... and then pull up. Very effective.
Piece is online now Find More Posts by Piece
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
A split-ess is a marvellous manouver to turn height into speed, and reverse direction into the bargain.
leccyflyer is offline Find More Posts by leccyflyer
Old Oct 31, 2010, 03:37 PM
Ira NZ is online now
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Depends, am I doing it for fun or because I'm deadstick? Cut throttle and do a couple S turns usually. Cross controlling works ok too if I'm way out high though.
Ira NZ is online now Find More Posts by Ira NZ
Old Oct 31, 2010, 03:42 PM
KYlawyer is offline
Find More Posts by KYlawyer
Bustin' foamies is my hobby
KYlawyer's Avatar
Oldham County KY
Joined Sep 2010
As a newbie, I seem to like to reduce altitude by crashing.
KYlawyer is offline Find More Posts by KYlawyer
Old Oct 31, 2010, 03:49 PM
Ira NZ's Avatar
Joined Apr 2006
That's not reducing altitude, that's eliminating it. :P
Old Oct 31, 2010, 04:18 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
+1
If I am flying something that will take lots of speed I do a split-S then point it straight at me in a screaming dive. This is even more impressive with a nitro plane as you can really hear the engine winding up – the Doppler effect makes it sound even faster as it accelerates towards me.
RC Man is offline Find More Posts by RC Man
Old Oct 31, 2010, 04:57 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
Well, you CAN go into negative altitudes but you have to do a REALLY hard dive to accomplish it.
If you had seen some of my crashes, a regular surface crash-landing would still look like it had plenty of altitude
Old Oct 31, 2010, 05:31 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
Depends on where your 0 feet altitude is. If you're on the slope, the 300ft. drop down below the level of the slope is negative altitude
Old Oct 31, 2010, 05:54 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
A wrist rocket and ball bearings for me.
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Discussion Whats your favorite small Wing set up? airbagit13 Foamies (Scratchbuilt) 12 Sep 23, 2010 02:37 PM
Discussion foam sanding blocks/loose landing paper ,whats the way with blue foam? soarluck Composites Fabrication 9 May 14, 2009 08:24 PM
Whats your Favorite TV Show? CB435 Life, The Universe, and Politics 42 Nov 06, 2002 03:57 AM
Whats your favorite charger these days? Gary U. Electric Sailplanes 39 May 15, 2002 01:29 PM
Whats your favorite foamie ever? Chester_76 Foamies (Kits) 26 May 02, 2002 09:22 PM
