Nov 14, 2010, 10:47 AM
Joined Dec 2004
WERLIC- I started watching your scratch build of a Chris Craft Barrel back with great interest. I always like to watch another modeler venture into designing and scratch building their own models. I like to offer help to anyone who I think is going to get in trouble with their build, so please under stand that this is not criticism of your build, but suggestions to help in your build.
The first thing I noticed is that your shear batten was scored for the bend into the stem post , which really is not necessary if you used the right material such as, 1/8” x 1/4” bass wood battens. Also I noticed that the batten had broken on a frame, leaving a sharp corner, which your really never want. You want a smooth transition for the sub planking and mahogany planking to lay down.
I also notice that you did not carry the shear batten to the transom, but decided to run a second batten to the transom from frame #4. This also could hinder the smooth flow of the shear line when view from the side of the hull.
The same problem is noted with the chine line batten on the hull, which does become much more critical in the performance of the hull, since this will be the planning surface that the hull will rise up from the water surface and ride on. Sharpe edges or bump outs as seen in your last photo of the planked bottom of the hull, will cause a great deal of drag when running in a straight line, and the hull will be very unruly when making a turn due to the chine digging in.
Greater care in the original frame work will make for a better performing and better looking finish hull. Once the hull is planked, the mistakes are forever built into the boat.
