Old Oct 29, 2010, 09:45 PM
BobRCnut is online now
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
How does reducing prop diameter affect its pitch?
Because of the lack of a good selection of forward/reverse pitch props, I'm considering cutting down a pair of 8" forward/reverse pitch props to 6" to better suit the motors used. Since this will drastically affect the blade shape, I'm guessing the effective pitch of the props will also change, but how do I determine which way? Taking an inch off each blade will result in a "paddle-bladed" prop with wide tips. Since most props decrease in pitch as you go further out on the blade, the tips will now be at a greater pitch than the original tips. How will this affect the effective pitch of the now-shorter prop?
BobRCnut is online now Find More Posts by BobRCnut
Old Oct 30, 2010, 12:43 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
Most model props are not true helical cut. So, cutting off the tips will alter its pitch in some way, but to say in what effect is not easy to say, each prop designer does it differently.
The big problem is what you already mentioned, you cut off the narrow tip to end with a wide tip and that will be at a different angle as to what a propper designed prop of that size will be. I once just cut the tip and the amp draw did not reduce as we thought is will, at the end the prop was wasted.
If I have to cut a prop I also reshape the tip to be closer to the original as possible. It is not just a quick field operation but you have to take your time doing it nicely.
rebell is offline Find More Posts by rebell
Old Oct 30, 2010, 02:27 AM
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Thanks for the input, rebell... I'm going to try it using templates to trim the blades. I'm trying to get away from a 5 x 3 3-blade, and cutting down an 8 x 4 to a 6 x 4 will (best guess) result in a bit more current, but I'm not pushing the motors hard anyway. I'll measure the comparative currents and post back with results just for reference. I'm doing this to avoid problems due to mounting a 3-blade prop on a 2-blade prop saver. GWS has promised some additional smaller forward/reverse 2-blade pairs, but I'm guessing it'll be a while. This is for a very small quadcopter running Hyperion 17 gram motors.
Old Oct 30, 2010, 02:32 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
I take Rebel's point about props not being trully helical in pitch but providing you are 'trimming' it and not butchering it down to half it's original diameter I'd still say that 'as near as makes no difference' cutting down a prop wont effect it's pitch.
Take an 8" x 6" prop and cut it doen to 6" diameter and you have, near enough for our purposes, a 6" x 6" prop. The trimmed blades will have reduced aspect ratio so will be a little less efficient.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Oct 30, 2010, 05:07 AM
Yak 52 is offline
Find More Posts by Yak 52
Yak 52's Avatar
UK
Joined Jan 2009
Nominal prop pitch is generally measured at 75% of the blade so the nominal pitch will certainly increase.
The problem is that a prop blade is also doing most of the work between 50-80% of the blade. The blade camber and thickness will have been optimised at this point.
The tip 20% of the blade, however will be optimised for best efficiency in spite of tip losses.
Chop off 25% and you will have the wrong shaped camber and too much thickness in the new 'tip' so you'll lose alot of efficiency. In other words the bit that was doing the work before is now the tip, with all the losses that means.
By chopping off the tip you obviously lose the lift from the bit you cut off, but you also mess up the efficiency of the part that made all the thrust.
That said, it will still make thrust, but the lack of efficiency will quite possibly obviate any other gains.
By all means try it, but be prepared to bin it!
Yak 52 is offline Find More Posts by Yak 52
Old Oct 30, 2010, 06:51 AM
Aberdeen
Joined Mar 2006
Assuming helical pitch then the pitch is the same at any point along the blade
Old Oct 30, 2010, 07:35 AM
Yak 52 is offline
Yak 52's Avatar
UK
Joined Jan 2009
I was assuming it wasn't helical
Your right though, Steve, pitch won't change much.
The diameter/pitch ratio will change ...
And the efficiency could suffer a lot!
Old Nov 06, 2010, 03:07 PM
rick121x is offline
Find More Posts by rick121x
Just a North Vegas flyer
rick121x's Avatar
North Las Vegas NV
Joined Mar 2002
rick121x is offline Find More Posts by rick121x
Old Nov 06, 2010, 03:21 PM
rick121x is offline
rick121x's Avatar
North Las Vegas NV
Joined Mar 2002
Yes the efficiency will suffer. A great deal of the design of excellent props goes into reducing the tip losses. Also, the hub to blade transition will occupy a greater percentage of the usable propeller shape - useful prop thrust area - just wasted.
And yes the prop will run at a higher RPM, so it is important that the motor has a KV rating that supports that function. And if you take care of that; since the motor will be operating at a higher RPM, you will probably want to use a lower pitch prop.
All of this is nicely taken care of using bench thrust testing stand - one of the finest tools I have constructed in my electric flying career. So many fuzzy problems seem have clear solutions with thrust, rpm, current and wattage information. ... I copied mine device from the one advertised by BP Hobbies.
And you don't even have to have the perfect prop for the testing process... getting data from similar, as well as larger and smaller props will allow you to make a very close approximation of the near-ideal setup. It is also entertaining fun
I have found that I shouldn't mess with the shape of high priced, high quality props. They are so good that any change is very likely to reduce the efficiency.
Richard, Good luck!
How to calculate thrust, given RPM, prop pitch and prop diameter? Hogster Power Systems 19 Sep 25, 2014 09:15 PM
Discussion Prop Diameter Size vs Pitch syncronized Racing Boats - Electric 6 Oct 18, 2010 07:08 PM
Discussion How much does blade and paddle pitch affect tail? e78990 Micro Helis 3 Feb 03, 2008 07:45 PM
Does the various APC folding prop hubs affect prop length? rtideas Power Systems 2 Jun 15, 2003 06:59 PM
How does prop RPM affect power? Ninjak2k Power Systems 7 May 19, 2002 01:27 PM
