Oct 29, 2010, 04:49 PM
USA, VT, Putney
Joined Feb 2009
Foxtech 2.4G Tx/Rx system set-up
Hello All,
I am new to FPV, and purchased a Foxtech 2.4G system to start learning the ropes. I know I'll eventually own much better equipment, but I like to make my mistakes on the less expensive stuff first. I used the schematic on the Foxtech website to solder everything up and connect the KX-171 camera. I have double checked the dip switches on both the tx/rx as they use different positions for the same channel. At the moment I am plugging the receiver into a small TV for testing. When I hook separate 3s batteries up to both the transmitter and receiver, I get a b&w image that is scrolling vertically. The image is undecipherable, but clearly changes as I pan the camera. The TV has no vertical adjustment, in fact I can't remember setting a vertical adjustment in years, only the VCR tracking. So, is there an obvious adjustment to be made or something I have missed? Any additional info I can provide? Thanks in advance for the help.
Regards,
Wardo
