Old Dec 28, 2012, 06:21 PM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Graupner MX 20 Hott 1 servo Swash problem
Hi Guys,
I hope you can help me out.
I have a new MX 20 and I'm setting it up with a HelliCommand for my 600 size BlackHawk I'm building.
I need to program the swash as H1 or single servo.
That works but I have a limited stroke and I can not find the reason why
The Gas servo are attached at channel 6 the pitch are attached at channel 1
The Gas Limeter is not working because the gas servo has the complete trow but the pitch is stopping at -50% or +50% depends what I select "Pitch limeter Hinten or Pitch Limeter Vorne So I need to know how to adjust the pitch Limeter I guess
But I cant find where I can do that
The software version are 1.120 If that ring a bell .
It a great device but I'm struggling now.....
Regards,
Jan,
Horseman is offline Find More Posts by Horseman
Old Dec 29, 2012, 02:51 PM
quadslo is offline
Find More Posts by quadslo
Slovenia
Joined Feb 2011
I have serious range problems with my MX-20 and Mx-16 HOTT.
I have a multirotor with 2 operators. One has MX-20 and one MX-16. And I get like 200m range when both radios start beeping.
Is there anything I could do? What is the best way to mount the antennas? I have them facing down and 90˘ angle.
I also have 2 video TX at 5.8 ghz if this is causing problems?
Thanks for the help.
quadslo is offline Find More Posts by quadslo
Old Dec 29, 2012, 02:59 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by quadslo View Post
...What is the best way to mount the antennas? I have them facing down and 90˘ angle.
Like this /\ ? 90 degrees is too much, if you will approach them to about 30 degrees the results will be better.
Is there any metal/carbon object between Rx antennas and you? Landing gear ?
How is Tx antenna orientation ? It must be vertical, pointing whatever sky or ground.
If horizontal, than this is the reason.
5.8Ghz does not influence RC.
renatoa is online now Find More Posts by renatoa
Old Dec 31, 2012, 03:45 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Originally Posted by Horseman View Post
Hi Guys,
Regards,
Jan,
Hi Guys,
The problem is solved with help from the Dutch model forum en the solution was simply reset the receiver, that was all
Greetings,
Jan,
Old Jan 01, 2013, 07:19 AM
PH-SVV is offline
Find More Posts by PH-SVV
PH-SVV's Avatar
Nederland, OV, Kampen
Joined Nov 2010
Groeten uit NL
Hi Guys,
Greetings,
Jan,
Glad you fixed it
Happy flying in 2013 to all !
Greetings,
Sander
PH-SVV is offline Find More Posts by PH-SVV
Old Jan 03, 2013, 08:40 AM
nicklas is offline
Find More Posts by nicklas
nicklas's Avatar
Trollhattan, Sweden
tried to update my MX-16 transmitter with “MX-16_1v722_English” which failed as it stoped during the update. I need to re-flash with “gr_MX-16_1v50_ht.bin”, but I can’t find the file on Graupner’s homepage. Where I can download or find it?
Best regards,
Nicklas
nicklas is offline Find More Posts by nicklas
Old Jan 03, 2013, 09:38 AM
nicklas is offline
nicklas's Avatar
Trollhattan, Sweden
Best regards,
Nicklas
it works now. I restated and did the Emergency
Old Jan 03, 2013, 10:01 AM
mihlit is offline
Find More Posts by mihlit
Joined Oct 2011
Hi guys,
does anyone know what's the protocol for external RF module?
I added FrSky to my MX-20, but it needs "RF module = EXT" and then ppm signal goes to DSC output. Unfortunately, it means I can't use my radio as teacher in teacher-student connection.
There is another option "RF module = SP" which should output some kind of Spektrum protocol - for connection of spektrum rf module. So I'd like to design that protocol to ppm converter, but I'm not able to break that protocol.
There should be 2 (4) combinations.
"SP 1, 6 channels", "SP 1, 8 channels" - for DSM2 RF module
"SP 2, 6 channels", "SP 2, 8 channels" - for DSMX RF module
according to this:
http://www.graupner.de/en/supportdet...2-13a0f39bd13d
"""Spektrum™ module software enhanced:
- Selection:
1 = DSM2™
2 = DSMX™
and this:
http://rcfan.metnitzer.net/index.php?id=20
with PDF in right column: http://rcfan.metnitzer.net/download/...0-Spektrum.pdf
(these two are in german, not english)
Someone tried the opposite way - converting ppm to some spektrum protocol for some spektrum module. That protocol is described here:
http://www.rcgroups.com/forums/showp...33&postcount=8
but it's completely different from both protocols used (SP 1 and SP 2).
Do you know where I could find any information about such protocol? I tried sending email to Graupner (some time ago, different question), but I got no answer from them, so I gave up on asking graupner.
mihlit is offline Find More Posts by mihlit
Old Jan 03, 2013, 10:31 AM
ABLomas is online now
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Can't you just use them in parallel?
Anyway, do you use such combo often? Should be OK for daily flying... ;-)
Haha, where i did heard this... :P
ABLomas is online now Find More Posts by ABLomas
Old Jan 03, 2013, 11:50 AM
mihlit is offline
Joined Oct 2011
The only source of ppm signal is DSC connector, it's the same connector where you put signal from student, so you can't use them together.
Yes, I use it often, except in gliders (vario issues). Before buying MX-20 I had hitec optic 6 with FrSky module, so I have FrSky equipment everywhere. Unfortunately 6 channels was no longer enough for me, so I just wanted some base platform where to put FrSky module to. So I use FrSky often, but after update, I can no longer teach people, because student port is occupied by frsky module (only source of ppm in the radio). That's why I want to build that sp->ppm converter.
Old Jan 03, 2013, 03:59 PM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Best regards,
Nicklas
Hi Nicklas,
I know you have solved your problem but If you need to upgrade for some reason then go here The hott-lounge if you use the complete downloads you get all the languages also.
Regards,
Jan,
Old Jan 13, 2013, 02:34 PM
mihlit is offline
Joined Oct 2011
For those who would like to use FrSky together with MX-20/16/12, but don't know how to do it: http://mihlit.cz/blog/index.php/diln...hott-add-frsky
Old Jan 16, 2013, 04:38 AM
esbakke is offline
Find More Posts by esbakke
Norway, Oslo
Joined Oct 2003
The link doesn' work. Gets a "404"-error.
esbakke is offline Find More Posts by esbakke
Old Jan 16, 2013, 06:49 AM
mihlit is offline
Joined Oct 2011
I just clicked the link and it works. This forum shortens long strings, so if you copied the text, that's why it could look broken.
Old Jan 16, 2013, 07:52 AM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Works for me too.
Great info, anyone needs my collection of HoTT RX? =)
For Sale AirField 2.4GHz DSSS N4 Radio System MTDV Aircraft - General - Radio Equipment (FS/W) 1 Nov 20, 2014 01:47 AM
Discussion E-FLY 6BII 2.4GHz R/C System flashing light fuggire Radios 1 Oct 25, 2010 02:24 PM
Wanted Tactic 2.4ghz radio and receiver system trade for micro microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 10, 2010 09:12 PM
Sold Tactic 2.4ghz Radio and Receiver System Trade for Micro EVEN LOWER!! microflitedude Aircraft - General - Radio Equipment (FS/W) 0 Oct 09, 2010 04:38 PM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
