Old Aug 21, 2011, 03:45 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by BGR View Post
Perhaps some properly attached and supported surgical tubing to house the antenna would be a better choice. Both antenna have about 75% of their length oriented in the same direction. It may be nit picking but I would want as much of the antenna length oriented in the proper directions as possible.
Only the ends of 2.4GHz antennas are active - the rest can be considered as extension cable.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Aug 26, 2011, 04:42 AM
powerblimp is offline
Find More Posts by powerblimp
rc blimp manufacturer
powerblimp's Avatar
Switzerland, VD, Crans-près-Céligny
Joined Dec 2005
hello i really have a problem with mx12v2 and mx16v2 impossible to update the soft!
we did try many times bought all cables doenload all programm and that damned thing does not work!
all is Ok except the last step we got that message
"model conversion check-fail"
.. we did try with win 7 and XP on 3 different PC !!
and franklly why to sell something not ready???
i really thing Graupner will suside!!
take custommer for bench test!
i hate that!!!
it is like buying a car that does not work and you have to update the ignition card!
and it is not working!!
powerblimp is offline Find More Posts by powerblimp
Old Aug 26, 2011, 12:15 PM
udogigahertz is online now
Find More Posts by udogigahertz
udogigahertz's Avatar
Deutschland, Nordrhein-Westfalen, Geilenkirchen
Joined Aug 2007
Originally Posted by Julez View Post
They are correctly mounted in both pictures: The right antenna points upwards, the left one inwards.
Yes, you are right, I was mistaken (must have new lenses in my glasses?).
Udo
udogigahertz is online now Find More Posts by udogigahertz
Old Aug 26, 2011, 01:14 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Blimp,
please contact the customer support on this issue.
In Germany someone had a similar issue, and got a special software from Graupner to revive his disfunctional TX.
Furthermore, one needs to assign full access rights to the folder c:\programms\graupner in Win7.
ICQ and similar programs should be turned off during the update process.
Julez is offline Find More Posts by Julez
Old Aug 28, 2011, 08:05 AM
ztrem is offline
Find More Posts by ztrem
France, Midi-Pyrénées, Balma
Joined Aug 2011
Hello,
does anyone analyze log data after-fly using the file created on the micro SD card?
I did some previous search but found nothing on this topic.
So I did some reverse engineering to decode those binary files and convert them in csv file easy to use with excel. The conversion is still not complete but gives me rather good info...
is someone interested in?
christophe
ztrem is offline Find More Posts by ztrem
Old Aug 29, 2011, 02:53 AM
Joined Sep 2000
Originally Posted by ztrem View Post
Hello,
You can run the recorded data in the Graupner radio studio:
HoTT GPS Module Telemetry - Graupner Radio Studio (2 min 34 sec)
Jürgen
Old Aug 29, 2011, 02:56 AM
Joined Sep 2000
It is most likely a Win 7 issue:
http://www.rcgroups.com/forums/showp...&postcount=700
Jürgen
Old Aug 29, 2011, 05:30 AM
aeropics is offline
Find More Posts by aeropics
aeropics's Avatar
Joined Jun 2008
http://www.youtube.com/watch?v=05aEnQRtbOs
Jürgen
Are there any limitations on the logs data file lenght, or just limited by the size of the mem card?
aeropics is offline Find More Posts by aeropics
Old Aug 29, 2011, 09:47 AM
ztrem is offline
Joined Aug 2011
Jürgen
Hello Jurgen,
as I wrote in a french forum, Graupner radio studio is interesting but is limited in some ways. For example, it is very difficult to display any tendency over time (such as for example temperature, altogether with propulsion current and tension over time). In fact graupner radio studio offers no export of files to an excel compatible format... Excel (or any other spreadsheet software) is the proper tool for displaying such picture. This export could be a graupner radio studio function, but it is not currently.
That's why I decoded the log file (not still complete as I currently have no telemetry mesures except those provided by the receiver itself (as well data provided by the transmitter itself))
If someone is interested I can provide this early version (in fact it is a perl script)...
From my side, I am interested in getting some log files generated by others users of MX-16 / MX-12 (with/without extra sensors) to validate / extend my software...
As an example, attached a graph displaying 5 command channels overtime during a flight...
christophe
Old Sep 09, 2011, 03:17 AM
remeron is offline
Find More Posts by remeron
Joined Nov 2010
Hallo
I have Tx modul M-G2 n. 33302 for my MC24, does know where I can find new firmware?
And what program to use? Tanks for your help.
remeron is offline Find More Posts by remeron
Old Sep 09, 2011, 05:18 AM
rapega is offline
Find More Posts by rapega
Joined Jul 2011
Originally Posted by remeron View Post
Hallo
Hi,
this should be the link:
http://www.graupner.de/mediaroot/fil...20Software.zip
BUT: Your module might have a newer firmware! Mine has.
In that case, the updater will display a warning you should read.
Cheers, Ralf
rapega is offline Find More Posts by rapega
Old Sep 09, 2011, 08:18 AM
remeron is offline
Joined Nov 2010
Thanks for the help, I installed the firmware, but still can not read the telemetry data on the screen of my MC24. What do you think?
thanks
Nicola
Old Sep 10, 2011, 04:36 AM
habicht is offline
Find More Posts by habicht
Joined Nov 2009
mc-24 goes HoTT
The HoTT-ROM #4825.660 and the telemetry #33304 wire must be installed in the service department to get the internal telemetry.
habicht is offline Find More Posts by habicht
Old Sep 10, 2011, 06:03 AM
rapega is offline
Joined Jul 2011
Until that's done, you need a smartbox.
Old Sep 10, 2011, 10:07 AM
remeron is offline
Joined Nov 2010
My God I had a suspicion! I had written to Graupner in Germany asking the same question and they say me that updating the firmware of the module I could read the data on the display. Too bad the release date of the upgrade will not be certain. Thank you all for the help. Nicola
For Sale AirField 2.4GHz DSSS N4 Radio System MTDV Aircraft - General - Radio Equipment (FS/W) 1 Nov 20, 2014 01:47 AM
Discussion E-FLY 6BII 2.4GHz R/C System flashing light fuggire Radios 1 Oct 25, 2010 02:24 PM
Wanted Tactic 2.4ghz radio and receiver system trade for micro microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 10, 2010 09:12 PM
Sold Tactic 2.4ghz Radio and Receiver System Trade for Micro EVEN LOWER!! microflitedude Aircraft - General - Radio Equipment (FS/W) 0 Oct 09, 2010 04:38 PM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 09:39 AM
