Old Oct 29, 2010, 09:54 AM
avt is offline
avt
Find More Posts by avt
avt
Hell Flyer
Israel
Joined Nov 2006
Can I use this adapter for parallel charging in 206B?
I so this at HK and was wondering if I can use it for parallel charging two 4S packs.
As far as I understand, the packs can connected in the 4S and 5S place. Is that correct?
If not, can you please point me to where the adapter can be purchased?
avt is offline Find More Posts by avt
Old Oct 29, 2010, 10:30 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
http://www.rcgroups.com/forums/showthread.php?t=1302613
http://www.rcaccessory.com/pdf/Batte...on%20Guide.pdf
You will need the correct board for your balance tap type .... and a power plug adapter if you are not using Deans (or a seperate parallel power harness).
I also do custom work for parallel / series rigs and other power / tap adapters.
Bob
http://rcsales.shutterfly.com
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Oct 29, 2010, 11:30 AM
avt is offline
avt
avt
Hell Flyer
Israel
Joined Nov 2006
Bob
I appreciate your answer Bob.
But can I use the board from HK? It does fit the balance connectors on my packs. I just wanted to make sure it's the correct configuration.
Regarding the power adapters, I think I will build them myself.
Old Oct 29, 2010, 01:11 PM
Southeast PA
Joined Jun 2007
The link you gave to HK was for an EH tap type adapter (Kokam style) and will work with any packs with JST-EH style tap plugs. YES you could use the 4S and 5S connectors as long as you keep the grounds keyed to the correct column of pins on the ground edge (where all the pins line up)(left corner of pic). The adapter board connecting plug has the proper JST-XH connector for the 206B.
If your packs plug into the 206B tap sockets they are JST-XH (Align style) taps ... they WILL NOT properly plug into the board you linked to.
Bob
Old Oct 29, 2010, 02:46 PM
epbuddy is offline
Find More Posts by epbuddy
Columbus, OH
Joined Dec 2009
what is the brand of your batteries. Since different LiPo's from various dealers may use different balance taps, you need choose the correct one for your application. For parallel charge with 206B, this thread may give you some helpful information:
http://www.rcgroups.com/forums/showt...3#post15964874
epbuddy is offline Find More Posts by epbuddy
Site Sponsor
Old Oct 29, 2010, 03:14 PM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
I just love my paraboard. Thanks epbuddy for a great product at a great price...
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Discussion Help! What size core can I use this equipment on? Thanks! TheNiceGuy Flying Wings 4 Nov 02, 2010 06:13 PM
Question Can I use this charger?? skychief80 Batteries and Chargers 4 Oct 29, 2010 03:17 PM
Question Can I Use This Compaq Server Power Supply? LowFlier07 Batteries and Chargers 2 Oct 28, 2010 04:23 PM
Question can you use this lipo in a 450 roganjosh1 Mini Helis 8 Oct 20, 2010 12:04 PM
Sold parallel charge and balance cables for charging up to 6 lipos at once ff954 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 27, 2010 11:09 AM
