Old Oct 28, 2010, 11:59 PM
tuck is online now
Find More Posts by tuck
tuck's Avatar
United States, CA, Citrus Heights
Joined Feb 2009
please delete
Please delete.
tuck is online now Find More Posts by tuck
Old Oct 29, 2010, 02:46 AM
Si Goodchild is offline
Find More Posts by Si Goodchild
Si Goodchild's Avatar
Lincolnshire, UK
Joined Oct 2009
1. yes, disconnect the red wire from one esc servo lead.
2. yes.
3. some do. mount the escs where they will be cooled by airflow. on a highly-loaded esc i would put it somewhere in the jet inflow our efflux. for cooler-running escs exterior mounting works fine.
Si Goodchild is offline Find More Posts by Si Goodchild
Old Oct 29, 2010, 03:42 AM
Googleplex is offline
Find More Posts by Googleplex
It's a really big number.
Brisbane Intl, Australia
Joined Jan 2001
On the GWS 262 there is enough foam in the nacelle 'mounts' where they join to the wings to embed the ESC's so the heat sink is in the efflux of the fans. It also makes the wiring easier as the channel in the wing for the wiring is too skinny to carry 3 wires from the fuse to the nacelles easily.
The GWS 262 is a good jet - just beware of piling on the throttle in low airspeed situations when flying - run it up smoothly and let airspeed build. The thrust line is quite low and may cause a nose up at low speed + high thrust situation.
Googleplex is offline Find More Posts by Googleplex
Old Oct 29, 2010, 09:22 AM
tuck is online now
tuck's Avatar
Joined Feb 2009
Fantastic gentlemen, Thank you very much.
Zeb
Sold HBFP V2, Parkzone 480 BL motors x2, 30a ESCs, Spektrum DX6i, ar500, ar6110e + more... major.monogram Non R/C Items (FS/W) 11 Oct 24, 2010 05:33 PM
Discussion Tri-rotor copter purchase list: Motors/ESCs/Battery jyros Multirotor Talk 0 Sep 28, 2010 02:42 PM
Sold 1 Lot BL motors and ESCs birdbrain Aircraft - Electric - Power Systems (FS/W) 1 Apr 16, 2010 07:45 AM
Sold 2 EFlite BL-420 3800kv motors (1 new 1 used) MitchUpton Aircraft - Electric - Jets (FS/W) 9 Jun 19, 2009 05:07 PM
2 escs, 2 bl motors red-panda Power Systems 8 Nov 25, 2005 10:01 PM
