Old Sep 20, 2011, 10:44 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I use to use concrete form oil
kerwin50 is offline Find More Posts by kerwin50
Old Sep 20, 2011, 01:35 PM
FBodyexpert is offline
Find More Posts by FBodyexpert
Trees are our enemy
United States, CA, South Gate
Joined Jul 2007
Concrete form release oil is supposed to give good smoke but it is said to be hazardous
FBodyexpert is offline Find More Posts by FBodyexpert
Old Oct 19, 2011, 09:59 PM
Trees are our enemy
Joined Jul 2007
Update
I'm glad to say that over the past few weeks I've been able to accomplish quite a bit by squeezing in build time here and there. I feel that the project is coming along quite smoothly and I am more than pleased with the progressing results. Here are the wings being covered. The last components to be covered:
Old Oct 19, 2011, 10:01 PM
Trees are our enemy
Joined Jul 2007
Bottom of the right wing covered:
Old Oct 19, 2011, 10:03 PM
Trees are our enemy
Joined Jul 2007
Left wing bottom covered:
Old Oct 19, 2011, 10:10 PM
Trees are our enemy
Joined Jul 2007
Both wings covered top and bottom:
Old Oct 19, 2011, 10:15 PM
Trees are our enemy
Joined Jul 2007
Wings fitted:
Old Oct 19, 2011, 10:26 PM
Trees are our enemy
Joined Jul 2007
Striping the top of the wings.. Almost there! After over a year on the this build there is finally a shimmer of light at the end of the tunnel. I ordered a box of 18-8 Stainless Steel 4-40 socket head cap screws and lock nuts to replace the black oxide hardware on all the ball links and servo arms. All that i have left to do before the maiden is to:
*Stripe the bottom of the wings
*Pin Stripe the wings
*Swap out the Black Oxide Ball link and servo arm screws/nuts with Stainless Steel
*Install the batteries (Rx, Ignition, and Smoke pump)
*Drill Hole in engine cowl to access H and L fuel mixture needles
*Make and Install Instrument Panel
*Balance Prop and Spinner
*Balance Plane CG
*Program radio and set throws
*Break In/Tune Engine
**FLY!!
Old Oct 19, 2011, 11:06 PM
taildragger21 is offline
Find More Posts by taildragger21
taildragger21's Avatar
park city
Joined Jul 2004
Nice plane!! If you need any bling or parts for it check out our website!! www.taildraggerrc.com
taildragger21 is offline Find More Posts by taildragger21
Site Sponsor
Old Oct 20, 2011, 04:50 PM
Trees are our enemy
Joined Jul 2007
Thanks, I'll keep that in mind.
Old Oct 20, 2011, 08:29 PM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
shes looking good
Old Oct 21, 2011, 10:39 AM
Trees are our enemy
Joined Jul 2007
Thanks kerwin. I'm happy.
My stainless steel lock nuts and socket head cap screws arrived from McMasterCARR yesterday. Hoping to swap out the black oxide stuff today after work.
Old Nov 10, 2011, 07:35 PM
Trees are our enemy
Joined Jul 2007
Well, its been a long road, but it looks as I'm pretty much there! Finished swapping out the hardward with stainless. $7 well spent. I also finished striping the wings and made an instrument panel which I'm pretty happy with.
To make the instrument panel, I took some 2lb rigid urethane foam. Cut it close to shape on a bandsaw. Then skinned it with Bondo, and sanded it smooth. Then I painted it and glued on the graphics which I made as well.
Also marked off the list is installing the flight packs. I did a rough check of the cg before installing the batteries but I need to do the final balancing.
For the most part, i guess it is safe to say that the construction is finally done. The last couple nights have just been occupied with setting the throws, programming the radio and going over all my work.
I did start the engine up and run about half a tank thru it yesterday. Wow, what a beast! Now if I could just cut down on the vibration at idle.
Old Nov 12, 2011, 08:10 AM
kerwin50 is offline
kerwin50's Avatar
winston mo
Joined Oct 2006
Yeah these gasser do vibrate at an Idle. I've heard that you can retard the timing some for a smoother idle.
Are you now ready for a remaiden.
Old Nov 12, 2011, 05:31 PM
Trees are our enemy
Joined Jul 2007
Actually, Kerwin, I haven't flown her before. The flight video posted earlier in the thread isn't me or my plane. It is a video I found confirming my fears about the original covering. But to answer the.question, I'm getting very close. I still have to program the mix for the smoke, balance the cg, and finish breaking in/tuning the engine.
Last night I had a chance to test the smoke system a bit. I don't have a mix programmed yet so it was with the pump full on or full off. So far so good. I'm getting huge plumes off white smoke using straight baby oil, but I'm also getting a bit of liquid oil so I have to cut the pump back a bit.
Also, I balanced the prop a little better and eliminated some of the vibration.
Discussion First giant scale plane. What to get Hance Giant Scale Airplanes 18 Dec 27, 2010 02:45 PM
Discussion First Giant Scale and first gasser- need advice SafetyChain Giant Scale Airplanes 5 Apr 08, 2010 01:50 PM
Discussion First Giant Gasser Smash McCrash Giant Scale Airplanes 4 Apr 07, 2007 01:08 PM
My First Giant Scale Project!!!!!! Chevalier Giant Scale Airplanes 5 Aug 03, 2004 01:20 AM
