Old Aug 31, 2011, 06:54 PM
FBodyexpert is offline
Find More Posts by FBodyexpert
Trees are our enemy
United States, CA, South Gate
Joined Jul 2007
Stripping off the old covering
FBodyexpert is offline Find More Posts by FBodyexpert
Old Aug 31, 2011, 07:04 PM
Trees are our enemy
Joined Jul 2007
The covering process begins...
Old Aug 31, 2011, 07:07 PM
Trees are our enemy
Joined Jul 2007
More progress covering and reassembling the fuse..
Old Aug 31, 2011, 07:10 PM
Trees are our enemy
Joined Jul 2007
More progress...
Old Aug 31, 2011, 08:06 PM
Trees are our enemy
Joined Jul 2007
Totally off subject, but I just found this vid and thought you guys would appreciate it. I thought I was a good engineer and somewhat decent machinist, but I take my hat off to these guys. Well done, and something to be proud of...
Rotec Radial Engine 150hp (3 min 34 sec)
Old Sep 08, 2011, 08:42 PM
Trees are our enemy
Joined Jul 2007
Question!!
I saw in another build thread someone mention using a felt clunk in the fuel tank when running gas. Has anyone used, seen or heard of this before? If so, what are the pros and cons and where would I find one?
Old Sep 08, 2011, 10:21 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
from an earlier answer:
"Felt Clunks: Header tanks can be used but are generally not needed as Gas isn't as susceptible to foaming as Glow fuel and the carbs seem fairly unaffected by air in the system.
However, the use of a "Felt" clunk is becoming common as they have several properties that make them very attractive.
The "Felt" acts as a very effective fuel filter.
The "Felt" holds fuel causing a sort of pool that insures a constant fuel supply under all conditions.
For instance, on a down line when the clunk isn't in the fuel.
When the tank is not full, the fuel splashes around and small quantities of air enter the system.
If you want to use one, you can get them at most "Weed Whacker" shops."
Gas Engines_Newbies Guide_Giant Scale may be of interest.
See also "Fuel facts & FAQ + Fuel Tank installations" at:
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
Alan T.
A.T. is offline Find More Posts by A.T.
Old Sep 09, 2011, 12:47 AM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I'm using the walbro felt fuel clunk in my gasser. I got it from a lawn mower shop. I think I paid 5 dollars for it.
It provides fuel filtering as well as it hold fuel and is perfect if you do hammer heads with your plane
kerwin50 is offline Find More Posts by kerwin50
Old Sep 09, 2011, 11:59 AM
Trees are our enemy
Joined Jul 2007
Thanks for the info guys! Looks like a winner!!!
Old Sep 17, 2011, 11:54 AM
flyracer is offline
Find More Posts by flyracer
Wannabe 3D Pilot
flyracer's Avatar
USA, AZ, Chandler
Joined Nov 2006
FBody
Good job on the recovering project! Can't wait to see the finished results.
Flyracer
flyracer is offline Find More Posts by flyracer
Old Sep 17, 2011, 12:59 PM
Trees are our enemy
Joined Jul 2007
Originally Posted by flyracer View Post
FBody
Flyracer
Thank you, I'm very anxious to finish and maiden her. Unfortunately, it has been a slow process trying to squeeze in build time with my hectic schedule. With a trophy wife, a 1 year old, a 2 year old and working 50 to 60 hours a week, its tough to find the time!
Old Sep 17, 2011, 01:16 PM
Trees are our enemy
Joined Jul 2007
Question?
Anyone use, used or seen someone use strait diesel as smoke fluid? If so how did it pan out? Seems to me that it would be black rather than white? Is that true?
How about home brewed smoke fluids? Any recipes? Or better yet, what is the chemistry behind the dry smoke oil on the market now?
Old Sep 19, 2011, 01:40 PM
Trees are our enemy
Joined Jul 2007
Anyone????
Old Sep 19, 2011, 02:33 PM
A.T. is offline
Joined Aug 2002
Anyone use, used or seen someone use strait diesel as smoke fluid? If so how did it pan out? Seems to me that it would be black rather than white? Is that true? How about home brewed smoke fluids? Any recipes? Or better yet, what is the chemistry behind the dry smoke oil on the market now?
Smoke Oil - DIY Formulas #01
Smoke Oil - DIY Formulas #02
Alan T.
Old Sep 19, 2011, 05:02 PM
Trees are our enemy
Joined Jul 2007
Alan,
Thanks for the info. A life saver for a second time on this thread! It looks like mineral oil is the winner. Not much for the idea of cutting it with diesel after reading the threads.
Discussion First giant scale plane. What to get Hance Giant Scale Airplanes 18 Dec 27, 2010 02:45 PM
Discussion First Giant Scale and first gasser- need advice SafetyChain Giant Scale Airplanes 5 Apr 08, 2010 01:50 PM
Discussion First Giant Gasser Smash McCrash Giant Scale Airplanes 4 Apr 07, 2007 01:08 PM
My First Giant Scale Project!!!!!! Chevalier Giant Scale Airplanes 5 Aug 03, 2004 01:20 AM
