They are hpi savage truck adjustable upper arms, it has some flex but not as much as the wire, i think it is better to use plastic than metal so it can flex back & not stay bent like the wire, but it may break the receiver box off & there is only one way to find out & parts are cheap anyway, if it does break then i will know not to do that way.
I tested my wheel bar today it works great & it took a couple of hard hits & did not break anything, but it did not save my rear guard from getting folded back
, what i have found if you have a wheel bar & want it to protect your rear guard as well i think it has to be like this, because my fender got folded back when i did a wheelie on the grass & flipped Vinnie into a back slide & the grass was able to grab the fender as it was rubbing on the ground when Vinnie is upside down in a back slide, now i have mounted the wheel bar arms on top & bent it up at the end now when Vinnie is upside down the wheel holds the guard up off the ground & i am also going to run tape like chktm just at the end of the guard to make sure it can't catch on anything & a bigger wheel like Chris uses & a Deegan would also help keep the guard up, just my 2 cents.
Australia, QLD, Burua
Joined Jul 2012
Joined Mar 2012
This is a great set up! What did the wheelie bar and wheel come off of, mini revo? |
United Kingdom, England, Ware
Joined Aug 2012
Something perhaps of interest to UK folk still unsure what they want from the big fat man later this month
.Have been talking to CML regarding some spares for the Venom and in passing enquired as to position for a RTR MM 450 and the E-Gyro upgrade New MM450 @£550.00 inc VAT E-Gyro upgrade £150.00 inc VAT Dig deep
Joined Nov 2009
Still not bad, A new VMX is roughly £360, then you add the e gyro bringing it in £40 cheaper than the MM
The ARx 540 in pro kit E gyro trim is only slightly cheaper at £500 The cost of getting the M5 up to a comparable spec is more than £500 ![]() The Sky RC SR4 is £300 RTR so could be an appealing chance to take when you are saving £200 |
Joined Jul 2012
It is easy to overpower a wheelie with the tenshock but it has also flipped on it's back just from pulling a wheelie & hitting a bump at the same time. |
It is all hpi savage stuff the wheel is off a gpm alloy wheel bar for the savage the rest is upper suspension arms the ones connected to the wheel i just cut & shape them to fit i own a few savage trucks & it is just stuff i had laying around, i could not find any of those mini revo bars, but i think the main thing is to keep the guard tight on the bar so it cannot catch when sliding upside down backwards.
Joined Jul 2012
| Thread Tools | |
| Discussion HoobyKing new dirt bike vs. venom vmx 450 | amitgv1 | Motorcycles | 19 | Oct 13, 2010 11:09 AM |
| Discussion Duratrax DX450 VS. Venom VMX 450 | Butters | Motorcycles | 31 | Mar 18, 2010 03:41 PM |
| Discussion VMX 1/4 Scale Dirt Bike | Venom Media | Venom | 4 | Mar 01, 2010 06:41 PM |
| Discussion Venom VMX 450 MX Bike! | Mark Headling | Motorcycles | 2 | Feb 09, 2010 11:44 AM |
| Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's | Magicd1 | Motorcycles | 6 | Oct 02, 2006 02:06 AM |
