I use a Spektrum Pro transmitter on the MM450, so the settings are different from the Venom radio I use on the VMX, but the same idea works on both transmitters. I cheated the stock servo into being faster by setting the steering EXPO to a minus (-) 41% (Spektrum) and (-) 30% on the Venom . Set the steering speed to max what ever your radio is. I'm very satisfied now and until the MM450 stock servo goes bad, I'll keep using it. Right now I run both my bikes indoors on very tight courses and need quick steering to get the bike stood back up fast so you can get on the gas quickly and so far these settings seem to work. PS - Thanks for the tip for the switch on the gyro esc! |
Joined Mar 2012
Thank you for the tips I'm getting a high trq metal gear airtronics servo for the bike. And prob eventually an airtronics radio as it has just about every adjustment you could want. My XTM nitro buggy came with this radio and I loved it. |
Joined Mar 2012
You can go to where the foot pegs are just off the ground at full lean. Also want to make sure when you lay it on the bars both the front and back tire are still contacting the ground enough so that the front has enough to lift and the back has enough to push . I just cut mine Tuesday and tested it yesterday. I cut 3/4 of an inch off and that seems to be a sweet spot where it gives a lot more lean but still can jump back up with no problem Every time I make a mod to this bike, I love it more and more. I don't think I'll ever touch another buggy or 4 wheel Rc again |
I took the pegs off because at those lean angles the pegs will catch on things once suspension starts compressing and little bumps that come along that miss the wheels. Im going to have rubber bands keep the riders boots tight to the frame so that will minimize rubbing on ground.
Joined Mar 2012
Right now Johnny, my bars are right at 3 3/4" (just short of the lean angle I want) measured from main frame that the rear crash bar mounts to, with the bars perpendicular to the frame of the bike. I'm guessing that between 3 3/4'' and 4" bars bent upwards to get the lean angle might be a good starting point to try. That's what I'm gonna try anyway. |
Joined Mar 2012
Australia, QLD, Burua
Joined Jul 2012
I am going to use 5mm nylon rod for my crash bars.
I shortened that spacer in the wheel & it didn't do anything it still moves side to side it is the wheel shell moving side to side on the bearings i don't know why they can't get there dimensions right i am just going to run it the way it is.
| Thread Tools | |
| Discussion HoobyKing new dirt bike vs. venom vmx 450 | amitgv1 | Motorcycles | 19 | Oct 13, 2010 11:09 AM |
| Discussion Duratrax DX450 VS. Venom VMX 450 | Butters | Motorcycles | 31 | Mar 18, 2010 03:41 PM |
| Discussion VMX 1/4 Scale Dirt Bike | Venom Media | Venom | 4 | Mar 01, 2010 06:41 PM |
| Discussion Venom VMX 450 MX Bike! | Mark Headling | Motorcycles | 2 | Feb 09, 2010 11:44 AM |
| Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's | Magicd1 | Motorcycles | 6 | Oct 02, 2006 02:06 AM |
