Australia, QLD, Burua
Joined Jul 2012
![]() chktm, those stoppers you mentioned, are they something similar to this? http://www.rcplanet.com/Ofna_Stopper...p/ofn10322.htm |
Joined Jul 2012
Yea that looks like them, they are even tricker.
I like that spur gear cover and the chain adjusters. Will have to get some.This one is high def
Some fun with my Son and a Dog. Lots of crashes wheelies and good times. You can see my Son is a bit rusty and at times goes too slow for too long and the bike becomes unstable and wobbly and crashes. Also uses the bars a little too much. He is using one of my gyros probably needs a little more gap at times. Once he speeds up all is good. That gyro is set up to go fast. Ill have to tell him to give it to it more often. He likes to go a bit slower and do more tight cornering. The MM450 should suit him really well. He hasn't had a go for about two months, he goes all right when he gets into it. Great dog exerciser. His bike (. The red one ) has a 6000 pack and 11 tooth pinion and the yellow was running a 5200 and 12 tooth pinion. Both these bikes have the rear insert I made and Hot Bodies big bore shocks. |
Joined Jul 2012
The tube is standard only the horn and the little red bit on the caliper need very slight drilling out. I have a piston hole drill set I do this with. Tiny drill. Try your fishing wire through the tube first, you won't have to drill anything.
Joined Jul 2012
[QUOTE=chktm;22235537]The tube is standard only the horn and the little red bit on the caliper need very slight drilling out. I have a piston hole drill set I do this with. Tiny drill.
Kurtis try some fishing wire should work ok without drilling anything. |
United Kingdom, Beverley
Joined May 2012
[QUOTE=chktm;22236333]
Joined Jul 2012
Here's my fun today. No hospital. Some backflips, crashed attempts and Vinnie thought he'd try a one handed 360. Didn't quite pull it off. The last one is the best. Sorry about delay between jumps. One day I'll sort out a movie app.
But you have to be very careful when opening the throttle out of the corners. And if you hit a bump in that stage, the Bike is gone. The ARX may have disadvantages when turning into a corner. But the geometry of the Bike helps it a lot when you hit a bump "on Power". Yes, the tires on the VMX are better. But they are also softer, which leads to a more inconsistent Handling. We've seen and experienced this on the road bikes over the last 2 years, and I don't see why this shouldn't be the same on the offroad-bikes. Until now, no Venom Owner was brave enough to enter the Race in Fehring. So maybe next year we know what bike is better on Dirt
Joined Jul 2012
I'm glad it's working for you, all I can talk about is what I have seen and driven in the last 2 full AlpenCup Seasons. Regarding the tires: who says, that they need to squirm a little? Common sense, Real MX guys or the stopwatch? When you are racing, the third thing is what counts.. I would love to see more people racing Bikes (even here!), this way we would not have to rely on "What ifs..". Did you ever drive a well-setup ARX? |
| Thread Tools | |
| Discussion HoobyKing new dirt bike vs. venom vmx 450 | amitgv1 | Motorcycles | 19 | Oct 13, 2010 11:09 AM |
| Discussion Duratrax DX450 VS. Venom VMX 450 | Butters | Motorcycles | 31 | Mar 18, 2010 03:41 PM |
| Discussion VMX 1/4 Scale Dirt Bike | Venom Media | Venom | 4 | Mar 01, 2010 06:41 PM |
| Discussion Venom VMX 450 MX Bike! | Mark Headling | Motorcycles | 2 | Feb 09, 2010 11:44 AM |
| Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's | Magicd1 | Motorcycles | 6 | Oct 02, 2006 02:06 AM |
