I hear you Rellik.I'm one of those guys that will buy anything lol.If it is too small i make it bigger,if its too big i make it smaller.After 25 years of tinkering with this stuff i kinda like the challenge.Beleive me,over the years i have tossed many hopups out the window,but i will keep this one no problem.The reason i posted it is just maybe the right person will see it and make a change in the production line.It's a simple change,larger dia. cable and sheath.The tight red thingy,well you can just add a very small shim in between caliper halves.
Mine went together fine and cable gave me no issues. Its a 30 dollar front brake kit. Thats fricken cheap so even if cable is too weak and servo is cheap, the mechanism itself is worth it. For best performance, expect to upgrade cable and servo with metal gears / higher torque and it will be a beast of a brake. I cant wait to do the mod along with the egyro.
[QUOTE=gurumods;21859569]Hay yall,just finished an 8 hour disc brake r ................................stopper.That works perfect also.I wish i could have found a longer peice of tubing instead of splicing three together
im not sure if a length of outer electrical cable sheeth with copper removed would work, im sure you will find somthing better than the wd40 spray tubes but if it works there you go.....i must say when i instaled mine i had no dramas, but it was vtight fit as in the right length,just fitted.........On another note here a tip.at some stage you will need to remove the chain for cleaning or what ever,be sure u put chain clip c pin or what ever its called lol,back on the RIGHT way or you will throw chain ,i also like to put a dob of strong locktite on it.
[QUOTE=UFRC;21862547]
Update,i just found 25ft on ebay for $7.50 from china.I will have plenty now JohnnyMc,A high torque/MG servo is in the works for sure.I agree about the $30 price tag. |
Lloydminster AB
Joined Dec 2010
I put the 100 wt in last summer and the servo is still holding up well. If it does go I have 4 or 5 spare high torque units kicking around. The steering is quite responsive and head shake is quite minimal. i put 30 wt back in for a pack and went right back to 100. I found the 30 to be vague after running the 100 wt.
Took the bike out today after checking clutch gap (2.5mm) and loctite screws and putting 50wt oil in damper.I'm running on loose gravel and it accels straight until i hit the smallest of bumps or even a small stone then it goes into a wild tank slapper.Not sure what to do now as far as adjustments.
fyi setting clutch gap to 2.5 means gyro engages later. At 3.0 clutch engages earlier so more gyro effect sooner. Did you want 2.5 on purpose? Are you getting gyro up to speed prior to launch? I hold full throttle in the air for 3 secs at the least, slow tire down then let er rip.
This is why there is so much buzz about the egyro...to get rid of them dang wobbles! |
Post Falls, ID United States
Joined Feb 2004
On the brake cable... how do you manage to break a 40lb test stainless steel braided cable with ptfe coating? You can fish salmon with that brake line!
Anyhow the cable is not an issue. Its light so it will not affect the steering and its plenty tough for even a high quality torque servo to pull on it. Granted it is a kit so for everyone who puts it together there is a unique way to do it I'm sure. If I had ten guys build it I'm sure I'll get 10 unique results no matter how simple I made the kit. |
Joined Feb 2004
1) as stated above have the gyro clutch engage sooner - or - spool it up ahead of time and keep your speed up when driving. 2) increase the dampening oil weight to 50wt from the stock oil. See how you like and adjust further from there. 3) make sure your forks work. If the front end is not absorbing the bumps you could be bouncing off objects and just making things worse. Driving tip, when a tank slapper starts to happen try adjusting the throttle. Either power out of it and lift the front to let the damper stop it or tap the breaks to change the load on the front tire. Keeping a steady power setting will not usually stop the oscillation. |
Joined Mar 2012
I would say try and run on dirt or gas for now till the new gyro comes out and then try it again. |
| Thread Tools | |
| Discussion HoobyKing new dirt bike vs. venom vmx 450 | amitgv1 | Motorcycles | 19 | Oct 13, 2010 11:09 AM |
| Discussion Duratrax DX450 VS. Venom VMX 450 | Butters | Motorcycles | 31 | Mar 18, 2010 03:41 PM |
| Discussion VMX 1/4 Scale Dirt Bike | Venom Media | Venom | 4 | Mar 01, 2010 06:41 PM |
| Discussion Venom VMX 450 MX Bike! | Mark Headling | Motorcycles | 2 | Feb 09, 2010 11:44 AM |
| Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's | Magicd1 | Motorcycles | 6 | Oct 02, 2006 02:06 AM |
