Old May 27, 2012, 04:55 AM
United Kingdom, Beverley
Joined May 2012
thanks for the reply relik
i am new to the 2 wheel RC
Ill probably go with the vmx as I'm very impatient & iv seen the bike for £350 without all the charger and batterys in the UK alltogether in the UK it'll be £550, but as im going to be getting it from a US shop i can get everything i need plus parts for like £380,
so im saving some money i guess
plus its the new version with the metal gears. waterproof elecs.
Ill just get the E-gyro when its out
just really want some tips on what to set the slipper clutch at and what to set the gyro clutch at?
thanks guys
Kurtis is offline Find More Posts by Kurtis
Old May 27, 2012, 06:50 AM
Joined Mar 2012
the clutch make is so you an hold the clutch and spin the tire without the clutch moving, and do an 1/8th turn tight, try it, nother 1/8th turn and try it till you get it how you like it, and the gyro clutch is between 2.5mm and 3.0 mm, factory has it set at 2.7, but if you get it used make sure you check it, if not you will be ok for a couple packs. ill be back on tonight to give you more tips and tell you things iv found i have to scoot to work.
Rellik is offline Find More Posts by Rellik
Old May 27, 2012, 07:11 AM
Joined May 2012
ok thanks very much relik,
ill give all that a try when its here
id be at work but ankles broken
Old May 27, 2012, 08:42 AM
UK, Brentwood, Brentwood
Joined Feb 2011
ouch broken ankle,s not good only just had my plaster removed last week
deen247 is offline Find More Posts by deen247
Old May 27, 2012, 09:20 AM
Joined May 2012
Haha it was ouch when I broke it haha, can't do nothing I drive a lot so can't do that,
Iv got 3 months of doing nothing so I think I'll get a new hobby
And ah right what you do? Iv got ages haha
Old May 27, 2012, 12:16 PM
Joined Feb 2011
i broke my leg cast finally off though now i can get out with the bikes a lot more easier
Old May 27, 2012, 12:22 PM
Joined May 2012
Ouch!
thats worst then mine haha
mines called a ''high fractured ankle'' were my fibula and tibia come apart at the bottom causing my ankle/foot to come away from my leg bones.
3 months till im back to normal
and goood bet your glad thats off haha
Old May 27, 2012, 12:43 PM
Joined Feb 2011
Ouch!
yeah its so nice being able to scratch again in those places unreachable before and it looked really silly hobbling after the bike when the pack ran out lol
Old May 27, 2012, 01:21 PM
Joined May 2012
haha that sounds good i cant wait!
Old May 27, 2012, 01:32 PM
Joined Mar 2012
chris, not sure if you seen my question i posted about the gyro and how the wires connect from the motor to the esc and spin with the tire?
Old May 27, 2012, 01:40 PM
Joined May 2012
I was going to ask the same thing!
Old May 27, 2012, 02:02 PM
dammachines
WV
Joined Feb 2004
From the pic of the E-Gyro Stator, it appears that there is a small channel cut along the side where the wires are. I would guess the bearing goes directly on the OD of the stator shaft so the wires are sandwiched between the shaft and the bearing. At least that's the way I designed mine to work... They do look like larger OD and ID bearings.
I don't see a hole through the rear axle for pinning the stator to prevent it from rotating. Maybe the rear "brake caliper" fits into the slot on the end of the stator?
dmincin is online now Find More Posts by dmincin
Old May 27, 2012, 02:11 PM
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Wires come out of the back wheel on the right side to the fake brake caliper and route along the right side of swing arm like a brake cable. The wires go along right side of frame to that empty space that is just behind the radiator cover guard piece (above engine, below steering damper). Thats where a separate GESC gyro esc will mount. That controls the motor and will get power from battery. So, theres going to have to be a splitter of the battery connector I guess. Its all in the manual thats available on the mm450 page for download.
JohnnyMc is offline Find More Posts by JohnnyMc
Old May 27, 2012, 02:14 PM
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
That brake caliper, from the pic, looks like its designed to hold the stator shaft.
Old May 27, 2012, 02:23 PM
dammachines
WV
Joined Feb 2004
No fair cheating and reading the manual...
Discussion HoobyKing new dirt bike vs. venom vmx 450 amitgv1 Motorcycles 19 Oct 13, 2010 11:09 AM
Discussion Duratrax DX450 VS. Venom VMX 450 Butters Motorcycles 31 Mar 18, 2010 03:41 PM
Discussion VMX 1/4 Scale Dirt Bike Venom Media Venom 4 Mar 01, 2010 06:41 PM
Discussion Venom VMX 450 MX Bike! Mark Headling Motorcycles 2 Feb 09, 2010 11:44 AM
Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's Magicd1 Motorcycles 6 Oct 02, 2006 02:06 AM
