Old May 22, 2012, 08:39 PM
Rellik is offline
Find More Posts by Rellik
Joined Mar 2012
Originally Posted by Chris Nicastro View Post
I'm back in town from the Hangtown race in Sacramento. Awesome event and we showed off the new MM450 to the public and media. I was able to drive the bike and roost around a bit so that was a lot of fun.
You get that ESC/Radio figured out for more braking Rellik?
yeah i got it set up, but the mechanical gyro is killing me lol its always something, bolts coming loose, something binding, or coming out of adjustment, i thread lock the crap out of the bolts to. I cant wait till the E-gyro comes out so i can ride and not have to worry about all the gears and such, i think the E-gyro will make the bike a lot more reliable and enjoyable to
Rellik is offline Find More Posts by Rellik
Old May 23, 2012, 01:26 AM
RC-Motorradshop is offline
Find More Posts by RC-Motorradshop
Gregor from Germany
RC-Motorradshop's Avatar
Nuremberg, Germany
Joined Aug 2006
I have noticed that it the availabilty for the MM450 has been changend from mid May to late June. I just hope it doesn't change again and again until it's x-mas
RC-Motorradshop is offline Find More Posts by RC-Motorradshop
Old May 23, 2012, 06:25 AM
magnuts is offline
Find More Posts by magnuts
Adelaide, South Australia
Joined Feb 2007
Had a problem with no drive, and thought, good time to rebiuld the VMX. Initially thought the slipper had failed, broken pin in shaft, maybe, wrong.
Found the motor had failed, seperated the rotor from the shaft. Anyhow, stripped it right back and started from scratch.
Replaced speedy with Castle Mamba Max Pro.
Replaced motor with Hobbywing 4800Kv
Fitted front brake, using Savox SH0255MG micro servo
Threw the supplied brake cable in the garbage, and replaced it the gear change cable of a mountain bike, and with the outer brake lining.
Set the timing on the speedy to 15degrees advanced, and WOW, the extra gyro speed makes one heck of a difference, stability is fantastic, and the brake is awesome. I now use virtually zero rear braking, and, at times, can lift the back wheel off the deck.
I had no problems with the supplied speedy, just prefer Castle.
I did find the brake servo and cable a little weak.
magnuts is offline Find More Posts by magnuts
Old May 23, 2012, 01:16 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Sounds great lets see some vids or photos! Let'er rip!
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old May 23, 2012, 02:40 PM
slawsonb is offline
Find More Posts by slawsonb
Bruce
Palmdale, CA
Joined Sep 2005
If the GPV-1 and VMX450 are any indication, the real release date will be 6 months after the initial date.
Bruce
slawsonb is offline Find More Posts by slawsonb
Old May 23, 2012, 03:23 PM
Joined Feb 2004
Thanks for the vote of confidence Bruce!
Bikes are on the water in transit so it will be about 21 days.
Old May 23, 2012, 03:29 PM
deen247 is offline
Find More Posts by deen247
UK, Brentwood, Brentwood
Joined Feb 2011
cool cant wait to get one Chris
deen247 is offline Find More Posts by deen247
Old May 23, 2012, 07:09 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
You guys crack me up...
Akura2 is offline Find More Posts by Akura2
Old May 23, 2012, 09:40 PM
Rellik is offline
Joined Mar 2012
any chance of getting a date that the E-gyro will be available or a price?
Old May 23, 2012, 09:43 PM
slawsonb is offline
Bruce
Palmdale, CA
Joined Sep 2005
Sorry Chris.
Bruce
Old May 23, 2012, 11:03 PM
cmpilot is offline
Find More Posts by cmpilot
United States, NV, Henderson
Joined Feb 2012
$139.99
Mid July
Here's a link to the Atomik site
http://www.atomik-rc.com/Store_3/Bri...91%2C100%2C100
cmpilot is offline Find More Posts by cmpilot
Old May 23, 2012, 11:21 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Originally Posted by cmpilot View Post
$139.99
Mid July
lol, Ive been browsing the site all morning...nothing. Good find.
JohnnyMc is offline Find More Posts by JohnnyMc
Old May 24, 2012, 04:18 AM
magnuts is offline
Joined Feb 2007
Just for you Chris, here are some stills. Had to make an adaptor plate and spacers to line up the servo to the cable, as well as the keepers for the brake lining. The stiffness of the brake lining doesn't seem to influence the steering.
The next 2 things are to get an E-Gyro, and a 10.5 turn and use the Castle Cheat Mode.
Old May 24, 2012, 06:55 AM
Rellik is offline
Joined Mar 2012
$139.99
Mid July
Awesome!! Thank you!!. Wow it looks so mich easier to maintain. So basiclly you put then peices together, mount the esc and your back up and running? I like how it comes with the whole sha-bang. Deff looks like its going to make the bike much more reliable and enjoyable can't wait!!
Old May 24, 2012, 10:25 AM
Joined Feb 2004
Wow that full size cable looks like a bent spoke on there! Are you sure its not affecting the steering? Did you go to a thicker damper oil?
I'm looking at messing around with some 4WD SCT motors from Tenshock on the MM450. These are 4 pole motors so the torque is a lot more than your standard motors. They have a 5200KV motor I want to run that will be pretty fast I bet. I'll run a 100A ESC along with it too. Im also looking at 3500KV on 3S.
The problem is the 5mm shaft. I need to find a pinion that will work or try to turn the motor shaft down.
Discussion HoobyKing new dirt bike vs. venom vmx 450 amitgv1 Motorcycles 19 Oct 13, 2010 11:09 AM
Discussion Duratrax DX450 VS. Venom VMX 450 Butters Motorcycles 31 Mar 18, 2010 03:41 PM
Discussion VMX 1/4 Scale Dirt Bike Venom Media Venom 4 Mar 01, 2010 06:41 PM
Discussion Venom VMX 450 MX Bike! Mark Headling Motorcycles 2 Feb 09, 2010 11:44 AM
Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's Magicd1 Motorcycles 6 Oct 02, 2006 02:06 AM
