Joined Mar 2012
Chris. Have you guys every thought about adding a small e-gyro to the front wheel? I'm thinking this would make the bike super stable (if this is possible)
Also I was wondering if there will ever bee a small wheelie bar made so when the bike dose wheelie it dosent flop from side to side? |
Too much gyro effect will make the bike harder to lean into corners, you wouldn't be able to lean over from one side to the other quite fast. Believe me, it is perfect with the electric gyro system
![]() Besides, I think the front wheel would be too heavy to do wheelies as you like. Bye Gregor |
Joined Mar 2012
Joined Mar 2012
also i am having trouble getting my gyro back together, every thing is adjusted right, and spins find up till the pint i put the 10 screws that run around the tire to hold the two half's together, then it seems like something is getting bound up, i took it apart like 5 times and put it back together and it seems to keep doing this. anyone run into this problem or have and tips that might help me out???? i cant wait till the E-gyro comes out so there is no more messing with these gears and all |
Tips: coffee can holds wheel nicely while putting it all together. For getting wheel halves together with holes matched up first try...put 4 toothpics in screw holes around wheel. Then slide other side of wheel on through toothpics. Get like 2 screws on across from each other, then go around and all screws should be easy squeezy. |
| Thread Tools | |
| Discussion HoobyKing new dirt bike vs. venom vmx 450 | amitgv1 | Motorcycles | 19 | Oct 13, 2010 11:09 AM |
| Discussion Duratrax DX450 VS. Venom VMX 450 | Butters | Motorcycles | 31 | Mar 18, 2010 03:41 PM |
| Discussion VMX 1/4 Scale Dirt Bike | Venom Media | Venom | 4 | Mar 01, 2010 06:41 PM |
| Discussion Venom VMX 450 MX Bike! | Mark Headling | Motorcycles | 2 | Feb 09, 2010 11:44 AM |
| Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's | Magicd1 | Motorcycles | 6 | Oct 02, 2006 02:06 AM |
