Joined Dec 2010
What's the advantage of the nylon rods? I was thinking about just clipping the ends of the wire or bending them up about 2 inches from the end of the loop.
Trying to think of a clever way to rig up a "kick stand" via a servo mounted in the front break slot to help pick the bike up enough to get it going again once it's laid over. |
Post Falls, ID United States
Joined Feb 2004
Try shortening the wires half an inch at a time and you can see the difference right away. Your suspension setting will also effect how easy it is to pick the bike back up too.
The reason for nylon guides is to have something that is more slick on certain surfaces. Its also softer and compliant compared to the steel wires so its just a different way to do the same thing. |
Joined Dec 2010
I was watching some of the tech videos and realized that I should have set the timing markers for the gyro gears but did not. Is it a big deal if timing is off? Do I need to disassemble the wheel and reset timing before running it, or can I wait until routine maintenance is needed (like oiling the gears)
Joined Dec 2010
Joined Feb 2004
Oh I would love to see the look on their faces when they see polyurethane ribbons peel up in curly strings from the gym floor!
![]() Also the nylon bars allow the bike to lean over further off road and catch less on obstacles. Its a little easier on the bike and chassis but it takes more skill to drive the bike because you have to pay closer attention to the lean angle and grip. Generally you drive faster and keep up more momentum in the turns since you lean over further. |
Joined Feb 2004
Cool, yeah the end result is a combo of all of the adjustments to get it set to your liking. I made to be fully adjusted and you can use any Mini Class servo for more braking power.
That would be cool to see front brakes on 2WD SCT's, who knows I mean I did make a set of cut brakes for my Creeper so its totally possible! If your feeling a bit crafty look into our GPV disc brakes and go from there... |
| Thread Tools | |
| Discussion HoobyKing new dirt bike vs. venom vmx 450 | amitgv1 | Motorcycles | 19 | Oct 13, 2010 11:09 AM |
| Discussion Duratrax DX450 VS. Venom VMX 450 | Butters | Motorcycles | 31 | Mar 18, 2010 03:41 PM |
| Discussion VMX 1/4 Scale Dirt Bike | Venom Media | Venom | 4 | Mar 01, 2010 06:41 PM |
| Discussion Venom VMX 450 MX Bike! | Mark Headling | Motorcycles | 2 | Feb 09, 2010 11:44 AM |
| Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's | Magicd1 | Motorcycles | 6 | Oct 02, 2006 02:06 AM |
