Old Nov 21, 2011, 06:38 PM
70 Mach 1 is offline
Find More Posts by 70 Mach 1
70 Mach 1's Avatar
Minnesota
Joined Apr 2010
I'm running mine bone stock, it had the metal gears already installed so all I did was go through make sure screws had lock tight on them and lube them up, I'm using automotive cam break in lube and it's worked like a charm. Other than that a few adjustments here and there and all is still good, can't wait til this weekend when I can put a few or 20 more packs through it.
70 Mach 1 is offline Find More Posts by 70 Mach 1
Old Nov 21, 2011, 08:43 PM
Disposable Hero is offline
Find More Posts by Disposable Hero
Disposable Hero's Avatar
Maryland, USA
Joined Oct 2010
where did you purchase yours? I'd rather buy from a seller that has the metal gear version as opposed to buying one just to rip it apart to install them after the fact?
thanks
Disposable Hero is offline Find More Posts by Disposable Hero
Old Nov 21, 2011, 09:42 PM
70 Mach 1's Avatar
Minnesota
Joined Apr 2010
I purchased mine from the LHS who ordered it in for me, it was the first one they had ordered for anyone, so far I'm very happy with it. Coming from running many different Nitro trucks, Electric Helis (Many Crashes) and numerous airplanes I'm not afraid to do a little maintenace to keep thing going so tearing into the rear wheel is a walk in the park but not really needed until many runs once everything is inspected and lubed up the first time. Just my 2 cents
Old Nov 25, 2011, 10:43 PM
70 Mach 1's Avatar
Minnesota
Joined Apr 2010
Just had another great day with the VMX, once again my daughter and I took her Savage xs and my VMX out, boy did we have a blast!...only complaint I have is I don't have enough batteries. What a fun bike! 4 more packs though it and it didn't miss a beat, my daughter was even ripping off a few cool wheelies and some not so cool crashes...all good!
Old Nov 29, 2011, 06:41 PM
Akura2 is offline
Find More Posts by Akura2
PROFESSOR TRUTH JIMMY ICE
Akura2's Avatar
Joined Sep 2003
Hey Chris... any news on the track tires?
Akura2 is offline Find More Posts by Akura2
Old Nov 29, 2011, 06:54 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Nothing yet. Keep you posted Im working on it...
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Dec 01, 2011, 01:51 AM
rhino131 is offline
Find More Posts by rhino131
rhino131's Avatar
Joined Jun 2004
+1+1+1+1+1+1+1+1+1+1
rhino131 is offline Find More Posts by rhino131
Old Dec 01, 2011, 06:40 PM
RICH S is offline
Find More Posts by RICH S
Joined May 2000
Driving With The Motard Tires?
I fitted a set to my bike, I could never get it to turn on pavement with the dirt tires. Any tips on getting the bike to handle on the street tires?
RICH S is offline Find More Posts by RICH S
Old Dec 01, 2011, 06:56 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Traction on a clean parking lot was great for me. I was driving it around an unused commercial complex. I think at that point I started to increase weight of oil in steering damper and increased steering response on radio for quick turning. You will want to upgrade to like 1/4 in nylon 6/6 rods for crash bars as the stock metal wears out fast. The toes of riders feet begin to grind off at this point so dont bolt the feet down with stock method. Either leave them unbolted, or what I did was create stirups that hold the feet as close to bike as possible. This keeps feet straight and the footpeg will scrape if anything. Finally, when you get some serious leaning going, Ive seen pics from Europe where footpegs are removed. The street guys can give you better advice on setup though.
JohnnyMc is offline Find More Posts by JohnnyMc
Old Dec 01, 2011, 07:48 PM
RICH S is offline
Joined May 2000
Thanks, I already lost the toes a while back, and hated those bolts ( I use black rubber bands to hold the rider on). I figured for the price of the tires, I could do a little road riding without having to buy another bike. Do they make a sand paddler tire also? if so, any pics of them on the bike?
Old Dec 02, 2011, 03:17 PM
RICH S is offline
Joined May 2000
Still Can't Turn?
The motard tires look really nice, took the bike to a lot wound it up and on the straight it's a lot faster, but I still can't get the thing to turn, it pushes bad with no turning. If I hit the throttle hard out of a turn, it just spins out. Any suggestions? Does the gyro/sterring/throtlle need differnt settings? I've seen the vids so I know it turns
Old Dec 02, 2011, 03:56 PM
JohnnyMc is offline
RC Dirt Bike Action
JohnnyMc's Avatar
Joined Feb 2010
Just curious are you on the crashbars when turning? All pressure gets taken off front if so and you end up going straight. For street I had a separate pair of nylon crashbars a bit shorter for more lean angle. I forgot to mention that. Otherwise, sounds like you got a slippery surface. I know if I hit a portion of pavement with light dust/sand it acts like marbles on the ground. My 2 cents.
Old Dec 02, 2011, 05:36 PM
RICH S is offline
Joined May 2000
I'll try shorter bars, I can't even turn it slightly without pushing (without the bars even touching the pavement). In a straight line, the tire really hooks up and it flys!, never seen the thing move like this. You would think the rear has enough traction to pop it around a turn like the dirt tire does when it digs in, I have the front up all the time in the dirt no problem. This is going to take some tinkering. Seems someplace there were vids of the bike driving slowly with the street tires, would be interesting to see the technique the driver was using.
Old Dec 03, 2011, 05:17 PM
Bladerunner1955 is offline
Find More Posts by Bladerunner1955
$450.00 bucks I wish I had back
Sitting on the shelf AGAIN in need of more repairs. I have never worked on a RC item this much in my life, I raced full size MX and didn't need to do repairs half as much as this venom vmx, not to mention needing to do all these upgrades to make this $450.00 toy work.
Bladerunner1955 is offline Find More Posts by Bladerunner1955
Old Dec 03, 2011, 05:20 PM
dont worry it will be broken before you can have any trouble with your battery
Discussion HoobyKing new dirt bike vs. venom vmx 450 amitgv1 Motorcycles 19 Oct 13, 2010 11:09 AM
Discussion Duratrax DX450 VS. Venom VMX 450 Butters Motorcycles 31 Mar 18, 2010 03:41 PM
Discussion VMX 1/4 Scale Dirt Bike Venom Media Venom 4 Mar 01, 2010 06:41 PM
Discussion Venom VMX 450 MX Bike! Mark Headling Motorcycles 2 Feb 09, 2010 11:44 AM
Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's Magicd1 Motorcycles 6 Oct 02, 2006 02:06 AM
