Old Oct 31, 2011, 03:06 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
If you have both turned on and then press the bind button on the RX the system will rebind itself to the radio Tx.
Otherwise if the ESC is still making sounds and the Rx has a green light and the steering servo works then its the ESC that is in program mode. Follow the ESC directions and go from there.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Nov 01, 2011, 12:52 PM
10mtnRC is offline
Find More Posts by 10mtnRC
Joined Oct 2011
Ordered bike today, excited...yay
10mtnRC is offline Find More Posts by 10mtnRC
Old Nov 01, 2011, 07:10 PM
Joined Feb 2004
Sweet!
Keep in touch on here and ask any questions you need to.
Old Nov 01, 2011, 07:37 PM
10mtnRC is offline
Joined Oct 2011
Thanks Chris! Tower says next Monday for delivery so unless you have a surefire way to sneak a 28 lb. package under someones nose I think I'll wait with the Q&A till then.
Old Nov 05, 2011, 07:04 AM
10mtnRC is offline
Joined Oct 2011
The bike came yesterday but it was almost dark by the time I got it set up to run. Snuck a pack in quick before the sun went down. It seems to be very well made and looks great, the only issue I'm having besides learning how to drive the thing is that the front forks bind at the top of their range of motion and are not very responsive. I'm going to see if some more driving smooths them out a bit, or do I need to adjust something? Anyways the bike is fun to drive and there's definitely a learning curve but I like that, I like it alot.
Old Nov 05, 2011, 07:19 AM
uran is offline
Find More Posts by uran
Joined Nov 2011
Hello Chris
The menu item VR3T no modulation, how to bind a new receiver?
English is not my forte!
uran is offline Find More Posts by uran
Old Nov 05, 2011, 09:35 AM
10mtnRC is offline
Joined Oct 2011
Lost one of my guide wires due to being a lazy fool who didn't feel like looking for his threadlock. Here are some pics of my interim solution until I find the guide wire or can't find it and have to order a new one. Good for a laugh, and functional too.
Old Nov 05, 2011, 04:45 PM
quik97 is offline
Find More Posts by quik97
Joined Nov 2011
hey guys I've just ordered a mxv-450 what battery do you use for the 450? and what charger and for the british members where did you get them from? cheers james
quik97 is offline Find More Posts by quik97
Old Nov 05, 2011, 05:02 PM
TopDave is online now
Find More Posts by TopDave
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Turn off reverse
Chris or some other ESC Expert!
Yes, Venom sent me a replacement ESC and REVERSE is programed into it. The manual has 4 reverse power settings but no shut off programming is shown.... Help, my bike does not need (or want, lol) reverse!! Thanks ahead of time, Dave
TopDave is online now Find More Posts by TopDave
Old Nov 06, 2011, 12:59 AM
Guidoracer is offline
Find More Posts by Guidoracer
Guidoracer's Avatar
United States, CA
Joined Nov 2004
If it is the 80A VMX esc, you want throttle mode 1, which is forward-only mode.
http://www.venom-group.com/core/medi...7b8df&_xt=.pdf
Guidoracer is offline Find More Posts by Guidoracer
Old Nov 06, 2011, 05:24 AM
TopDave's Avatar
Waterford, Michigan
Joined May 2006
Thanks Lito, Sometimes when I read instruction sheets, my brain goes numb after the 2nd set of parameters is discussed, and all the terminology all blurs together leaving me with no alternative but to ask some young wizard to help me find what I am clearly looking at! Thanks again...Dave
Old Nov 06, 2011, 09:45 AM
Jonathan Bradbury is offline
Find More Posts by Jonathan Bradbury
Occasional useful idiot...
Joined Nov 2009
Chargers can be had on ebay. Here is a budget one that works. Charges Nimh,Lipo,Life,Pb. Charges up to 5a. Discharges @1a. http://www.ebay.co.uk/itm/IMax-B6-Li...item4842ad370b Delivery is reliable and takes two weeks.
Or if you are flush, then there are plenty at the 100+ range...
Jonathan Bradbury is offline Find More Posts by Jonathan Bradbury
Old Nov 06, 2011, 11:33 AM
Guidoracer's Avatar
United States, CA
Joined Nov 2004
Hardly young, but I'm happy to help!
Old Nov 07, 2011, 10:39 AM
Joined Feb 2004
Originally Posted by uran View Post
Hello Chris
If the receiver is from Venom then you only have to push the button on the receiver to bind it to the radio.
Old Nov 07, 2011, 10:43 AM
Joined Feb 2004
You should use a 25C or higher rated 2 cell pack and 5000mah capacity so your run time is adequate as well as the power. You can use a 20C 3400mah pack and it works but the run time is less and the pack wont have the punch you may want or need.
The pack will run cooler if you go bigger so I'd suggest you look into the larger capacity high C packs.
Discussion HoobyKing new dirt bike vs. venom vmx 450 amitgv1 Motorcycles 19 Oct 13, 2010 11:09 AM
Discussion Duratrax DX450 VS. Venom VMX 450 Butters Motorcycles 31 Mar 18, 2010 03:41 PM
Discussion VMX 1/4 Scale Dirt Bike Venom Media Venom 4 Mar 01, 2010 06:41 PM
Discussion Venom VMX 450 MX Bike! Mark Headling Motorcycles 2 Feb 09, 2010 11:44 AM
Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's Magicd1 Motorcycles 6 Oct 02, 2006 02:06 AM
