Old Oct 28, 2010, 07:15 PM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Venom VMX 450 1/4 scale Dirt Bike
We are starting a new thread with the bikes name in the title so people can find info easy. The VMX will be released in December, no specific date given.
Here is a photo of the new Supermoto SMR racing tires and the Disk Brake kit installed on the VMX. Some people have asked about this set up so I'll be posting some photos.
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Oct 28, 2010, 07:24 PM
Joined Feb 2004
Front tire and insert are SMR specific, so is the rear tire and insert.
Old Oct 28, 2010, 07:41 PM
Joined Feb 2004
A couple more showing the chassis and the brake servo installed neatly in its pocket.
The front brake is really powerfull and if you use a metal gear high torque mini servo you will have the power to stoppie.
The motor and ESC wires are a little long but this was done to make it easy to install and connect them together from a produciton standpoint. There is a built in wire tie spot to tie the servo wires and the motor wires at the same time.
You can also see the MTCS insert marked A and the range of adjustment the rear shock has.
Old Oct 28, 2010, 07:51 PM
Joined Feb 2004
You can also see the front axle is hollow and the lower legs clamp the tube to keep things aligned, this is straight from the big bikes!
You can also see the functional radiator shrouds which allow air to pass but keeps stones and desbris from hitting your ESC.
Notice the ESC has a low profile heatsink with the fan mounted within it.
Old Oct 28, 2010, 09:10 PM
Bking1340 is offline
Find More Posts by Bking1340
Bking1340's Avatar
South Africa
Joined Jan 2010
Please Chris - DECEMBER, my wife need to know what to order for Christmas. And thanks for the update with pics. Will be nice if you can post an updated video aswell
Bking1340 is offline Find More Posts by Bking1340
Old Oct 29, 2010, 12:26 AM
tntpower is offline
Find More Posts by tntpower
Québec, Canada
Joined Mar 2010
Thanks for the pics Chris, I want this bike even more!.
tntpower is offline Find More Posts by tntpower
Old Oct 29, 2010, 02:31 AM
Gartenzwerg is online now
Find More Posts by Gartenzwerg
Gartenzwerg's Avatar
Austria
Joined Jan 2007
Nice Pics!
Does it have some sort of Crashback System, or is the whole frame bending in a crash?
The CoG looks fairly high, with the Motor above the Swingarm.
Can't wait to see it live and watch it drive!
Gartenzwerg is online now Find More Posts by Gartenzwerg
Old Oct 29, 2010, 08:12 AM
swheels is offline
Find More Posts by swheels
swheels's Avatar
Joined Jan 2005
You know as soon as i get my hands one.I'll be converting it to nitro.
Still great looking bike though.Now hurry up and get these bikes on there way!
swheels is offline Find More Posts by swheels
Old Oct 29, 2010, 10:21 AM
Joined Feb 2004
Originally Posted by Gartenzwerg View Post
Nice Pics!
The steering stem has rubber bushings and the part itself is designed to give way in a front on crash into a curb for example to protect the chassis. Its been tested to withstand jumps and crashes more extreme than you are currently used to from any motorcycle. A high speed head on crash will be pretty difficult to survive with any RC bike even with a pivoting crash back system.
The CG is not bad, the battery pack is right next to the motor standing vertically and the rear wheel is heavy so it averages out to be very stable. If you wanted to you could lower the ESC by cutting away the side motor detail cover or something but that wouldnt make that big of a difference.
When you drive the RTR you will notice its set to be soft all around. This is done to help you learn to drive it. Once you know what to do or if you already know then you can change the oils out to your liking. After much testing the best adjustment you can make is to the steering damper by chaninig the oil to about 60wt from the stock 30wt. This will increase the responsivness and reduce head shake. I would suggest leaving the suspension on the soft side especially the forks.
Old Oct 29, 2010, 10:57 AM
mooneypilot is online now
Find More Posts by mooneypilot
mooneypilot's Avatar
Mission Viejo, California
Joined Nov 2004
I thought my Son was crazy not being patient for the release of a new video game? D'oh!
mooneypilot is online now Find More Posts by mooneypilot
Old Oct 29, 2010, 11:00 AM
Joined Feb 2004
Hahaha I hear you and believe me I understand that feeling.
Old Oct 29, 2010, 12:01 PM
Bking1340's Avatar
South Africa
Joined Jan 2010
Chris - can you maybe post a pic of the steering damper shown on the bike or am I blind?
Old Oct 29, 2010, 12:19 PM
Joined Feb 2004
Sure its on the other side.
Old Oct 29, 2010, 12:33 PM
Joined Feb 2004
Here is the Steering Damper.
This is the not so busy side of the VMX chassis. You can mount a transponder here no problem. The battery pack compartment has ventilation and plug access from this side also.
Old Oct 29, 2010, 01:49 PM
JohnnyMc is offline
Find More Posts by JohnnyMc
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Cool pics!! Venom site updated, now this. I really hope that December is IT. Think of all the sad kids on xmas day crying if they didnt get a VMX. I know I'll be one of them and it would look ugly.
NOOB question: So with the oil filled forks, can the compression/rebound be setup similar to how shocks can use different pistons to manipulate rates.
The rear shock looks nice with the threading but it seems a little small to me compared to size of bike. If there was an aftermarket big bore shock that worked, what benefit would it have if any?
JohnnyMc is offline Find More Posts by JohnnyMc
Discussion HoobyKing new dirt bike vs. venom vmx 450 amitgv1 Motorcycles 19 Oct 13, 2010 11:09 AM
Discussion Duratrax DX450 VS. Venom VMX 450 Butters Motorcycles 31 Mar 18, 2010 03:41 PM
Discussion VMX 1/4 Scale Dirt Bike Venom Media Venom 4 Mar 01, 2010 06:41 PM
Discussion Venom VMX 450 MX Bike! Mark Headling Motorcycles 2 Feb 09, 2010 11:44 AM
Discussion The Original 1/4 Scale RC nitro dirt bike from the 70's Magicd1 Motorcycles 6 Oct 02, 2006 02:06 AM
