Old Oct 28, 2010, 03:48 PM
LowFlier07 is offline
Find More Posts by LowFlier07
United States, OH, Chardon
Question
Can I Use This Compaq Server Power Supply?
Originally Posted by Petrik59 View Post
Compaq
Series ESP104
Model: DPS-450BB A
Part Number: 401401-001
Spare Number 101920-001
On the powersupply it says:
Output: 450W MAX.
+5V === / 24.0A Max - -5v === / 0.5A Max
+24V === / 0.05A MAX
+12v === / 26.0A Max - -12V === / 0.5A Max
+5VSB === / 1.5A MAX - +3.3V === / 36.0A MAX
+3.3V & +5V TOTAL POWER IS 195W MAX
I am planning on purchasing this Bantam BC8HP Charger w/Balancer (280W). My question is - will this Compaq power supply (specs listed above) work with this charger? Is it enough volts and amp output? Or do I need two of these power supplies in series?
Thanks.
LowFlier07 is offline Find More Posts by LowFlier07
Old Oct 28, 2010, 04:17 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Here is a thread with how to get known Server power supplies to power up.
http://www.rcgroups.com/forums/showp...18&postcount=1
Please do not post questions in that thread. It is just to post results in after the solution is found ,not question. Search it and see if the one you are asking about is listed.
12 V @ 26 amps. is 312 watts but some chargers require more than 12V to reach max. output.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Oct 28, 2010, 04:23 PM
tjinguy is offline
Find More Posts by tjinguy
TJin(Guy + Tech)
tjinguy's Avatar
United States, NM, Socorro
Joined Jun 2008
Thanks.
You can't use 2 of these power supplies in series on that charger, assuming you plan to use the 12V output, as the charger it limited to 18V input. Bantam specs say it needs 12V for full output, so this power supply will cover that. Next the BC8HP is rated at 280W, so assuming a 20% loss, 336W is needed for full charger output. This power supply is rated at 312W, so it will be close but I would bet it would be fine.
Making the PS work is another story. It looks like connects to something like a standard ATX motherboard plug, so it may need mod'd like an ATX power supply but that is up in the air in my mind. It will come down to how much you are willing to read/tinker with it.
tjinguy is offline Find More Posts by tjinguy
Discussion Getting a Compaq HP DL580 Proliant Server Power Supply to Work earlwb Batteries and Chargers 544 Feb 22, 2016 04:10 PM
Pin out for Compaq PS4060 power supply? cwdance1 Batteries and Chargers 7 Dec 03, 2015 10:43 AM
Discussion Help! What size core can I use this equipment on? Thanks! TheNiceGuy Flying Wings 4 Nov 02, 2010 06:13 PM
Question can you use this lipo in a 450 roganjosh1 Mini Helis 8 Oct 20, 2010 12:04 PM
Discussion Wrong Power Supply, Can I still Use It? jlcamp7 Batteries and Chargers 11 Sep 03, 2010 11:31 AM
