Old Oct 28, 2010, 10:08 AM
norstaroption is offline
Find More Posts by norstaroption
norstaroption's Avatar
Pacifica, CA USA
Joined May 2009
Looking for a Good Charger for 6S 5000mah
I have this charger right now Hyperion EOS 0606I 6S 6A AC/DC Balancing Charger, but it won't balance and finish charging my 6S 5000mah lipo batteries. It would bring all the cells up to 4.16 each but will not complete the charge even if I leave it for 4 hours at 1C.
So I'm looking for a good charger and power supply combination.
norstaroption is offline Find More Posts by norstaroption
Old Oct 28, 2010, 10:18 AM
cjcyclesrc is offline
Find More Posts by cjcyclesrc
Fly Extreme!!
cjcyclesrc's Avatar
United States, NC, Lexington
Joined Oct 2007
I'm very happy with my CellPro PowerLab 8. It's hands down the best charger i've ever used. I've been charging 6S 5000's two at a time and it works great.
cjcyclesrc is offline Find More Posts by cjcyclesrc
Old Oct 28, 2010, 10:48 AM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
Can that charger even get to 1C? Based on googling about a bit, it looks like it's only a 50 watt charger which would be less than half a C on a battery that size. If you want to charge big batteries quickly, look for something with some watts. I would recommend 200-300 watts each if you want to buy multiple chargers or 1000 watts or more if you want to charge several in parallel on the same charger. FMA, and iCharger have some. Hyperion has some bigger chargers too.
Dave H. is offline Find More Posts by Dave H.
Old Oct 28, 2010, 10:53 AM
realtimerecon is offline
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
This is what i use for my 6 cell 5,000s>>> http://www.google.com/products/catal...d=0CDIQ8wIwBA#
And it works like a charm
And a "Blinky" for balancing>>> http://www3.towerhobbies.com/cgi-bin...MRZ9&P=FR#tech
realtimerecon is offline Find More Posts by realtimerecon
Old Oct 28, 2010, 11:53 AM
tjinguy is offline
Find More Posts by tjinguy
TJin(Guy + Tech)
tjinguy's Avatar
United States, NM, Socorro
Joined Jun 2008
Really? No offense but that is a terrible recommendation. Not only does it lack an integrated balancer but it is more expensive than many modern, more powerful chargers.
norstaroption: To charge a 6s 5000mAh pack at 1C you need at least 126W of charger output. I would look at something in the 250-300W range. That would give you the ability to charge at 2C if you wanted.
tjinguy is offline Find More Posts by tjinguy
Old Oct 28, 2010, 12:04 PM
Skyshark01 is offline
Find More Posts by Skyshark01
Joined Dec 2004
It's really not that bad. It's probably one of the easiest chargers to operate and it outputs enough watts to charge everything in one hour or less. It's one of the only chargers that has the ability to bring a battery with a low cell back to life and it gives a consistant full charge every time.
Now the blinky is a little slow at balancing but as long as you don't run your batteries really low, getting cells balanced within a 1C charge time should not be an issue.
Skyshark01 is offline Find More Posts by Skyshark01
Old Oct 28, 2010, 12:33 PM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
www.progressiverc.com
I use the iCharger 206b with the P350 power supply and it is a fantistic combo. I charge 2x6s 5000 in parrallel in about 35-45 minutes.
I also use a para board from ep buddy and it takes the guess work out of parrallel charging.
http://epbuddy.com/index.php?main_pa...35i59uvom3pgi5
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old Oct 28, 2010, 12:35 PM
Real Time Recon
smith mt. lake VA.
Joined Jan 2007
I think you better read the specs.THEN comment.
>>>>>>>>>>>>>> http://www.astroflight.com/index.php...products_id=23
Old Oct 28, 2010, 12:37 PM
tjinguy is offline
TJin(Guy + Tech)
tjinguy's Avatar
Joined Jun 2008
I have read the specs. There is no specification of maximum wattage but the manual states the charger is designed to work a 12-15V 150W power supply. Yeah that leads me to believe it is a 120W charger, give or take. Am I wrong?
Old Oct 28, 2010, 01:10 PM
Real Time Recon
smith mt. lake VA.
Joined Jan 2007
^^It's fast(45-50 minutes) for a 6 cell 5000.
It's Easy.And best of all...
It's "stupid proof"
Power source = car battery.
Old Oct 28, 2010, 01:16 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Wattage aside, risk of fire due to user error, pack damage, incorrect cell detect, are DRAMATICALLY reduced by the use of a balancing charger (which the 109d is not). This is fact and not a subject of debate. As such, use of a balancing charger (or inline balancer with charge interrupt capability) is wise and prudent.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Oct 28, 2010, 01:24 PM
Dave H. is offline
Joined Feb 2008
It's "stupid proof"
Power source - Wall outlet,Or car battery.
That's about 1C - that was "standard" a few years ago but it doesn't count as "fast" these days. Some newer batteries are rated for up to 10C charging these days.
As for stupid proof, I was just looking through the PDF for this charger:
With battery packs of 4 cells or more, it is possible to get a low cell count detection even if each cell is above 3.2 volts. For example, a four cell pack with four cells at 3.2 volts will have a pack voltage of 12.8 volts. The 109 charger will think that this is a 3 cell pack. The 109 detects the fourth cell at 12.9 volts. To charge this pack, simply charge it normally as if it were a 3 cell pack.
During the first three minutes of Mode 1, the pack voltage will rise above 12.9 volts. As soon as the charger enters model 2 it will think that the battery is over charged and will stop charging beep nine times and Display “Bt Vlt Hi”. Remove the battery and disconnect the 12 volt power. Reconnect 12 volt power and when you see “Waiting for Battery” reconnect your battery. The charger will display 4 cell detected and you can charge your pack normally. On a 5 cell pack a fully discharged pack may read as low as 16 volts. The 109 detects 5 cells at 17.2 volts. So you have to put in enough charge to reach 17.2 volts before 5 cells are detected. Again charge your battery as though it were a 5 cell pack. At the end of Mode 1 the voltage may not have reached 17.2 volts so the charger will continue to charge the pack until it reaches 16.8 volts. That is the voltage of a fully charged 4 cell pack. When the charger stops and says done, remove and replace the pack on the charger and charge a second time. This time the voltage should reach 17.2 volts within the first three minutes and the charger will stop and Display “Bt Vlt Hi”. Now you can charge normally because you pack is above 17.2 volts and the 109 charger will detect 5 cells.
This over lap in voltage becomes higher and higher for packs with more cells. You may have to repeat the charge sequence one more time before proper cell count is detected. If it is practical for you to do so, do not discharge your packs so far in the future.
That does not strike me as "stupid proof" compared to modern balancing chargers can can see how many cells are connected without voltage-based guessing.
Old Oct 28, 2010, 02:11 PM
Ben-Rod is offline
Ben-Rod's Avatar
Joined Nov 2004
I wittnessed my only lipo fire when one of our club members was charging a lipo in his plane with that Astro and didn't set the cell count correctly. Burned his entire plane and a tx that was sitting next to it.
"Stupid proof", I think not...
Ben
Old Oct 28, 2010, 02:19 PM
SpeedVision is offline
Find More Posts by SpeedVision
United States, MI, Grand Rapids
Joined Sep 2007
Will the Astro let me download graphs to my Commodore 64?
If so, I can plot the charge graphs for my Ni-Cads before I put them in my AM transmitter...
To the OP, buy the biggest iCharger you can afford with a suitable PS, both from progressiverc.com. This is by far the best solution if you want to upgrade from your Hyperion. Give David at progressive a call and he will put a nice package together for you. I had a 106B+ and it served me well doing 10 amp charges (2c in your case)(iCharger 206B will give you 4c capabilities) all day long. If you want a true powerhouse and a charger that gives you access to gobs of data about what happens behind the scenes, buy a CellPro PL8 and you probably won't look back for 10 years.
SpeedVision is offline Find More Posts by SpeedVision
Old Oct 28, 2010, 02:35 PM
tjinguy is offline
TJin(Guy + Tech)
tjinguy's Avatar
Joined Jun 2008
It's "stupid proof"
Stupid proof is an FMA CellPro 4S. The 109 needs setup properly or you can burn your house down with it. That makes it far from stupid proof, it makes it a liability in a world full of modern chargers. Oh and 1C charging is not "fast", it is barely acceptable.
Help! Looking For A Good Pilot for our Electric Air Show Teams Murocflyer Electric Plane Talk 34 Oct 18, 2010 03:24 PM
Discussion Whats a good charger that does dual 4s or 6s? johnnychimpo Batteries and Chargers 3 Oct 16, 2010 07:01 AM
For Sale Brand New Zippy FlightMax 6s 5000Mah 25C batteries, Alkaline Aircraft - Electric - Power Systems (FS/W) 0 Oct 11, 2010 02:26 PM
For Sale hyperion charger good for 1s to 5s 5000mah sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 5 Sep 23, 2010 04:21 AM
Wanted Looking for a home for some 6S 5000mAh packs dccdmd Aircraft - Electric - Airplanes (FS/W) 16 Nov 08, 2009 07:02 AM
