Old Oct 28, 2010, 05:24 AM
Redhood is offline
Find More Posts by Redhood
Redhood's Avatar
United States, MN, Odin
Joined Aug 2010
Parkzone P-82 Twin Mustang
I'm building a Twin Mustang out of Parkzone ultra micro parts. Can any of you tell me what material would work best to support the wing connection? I am spliting the stock wing in half and putting a custom depron wing between the fuselages. I've looked at carbon strips and rods from rcfoam and I don't know what to use.
Redhood is offline Find More Posts by Redhood
Old Oct 28, 2010, 06:12 AM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
if your wing is 3mm depron, using a 3*0.8mm carbon flat in the wing would make it plenty stiff.
be sure to post some pics when you can
derk is offline Find More Posts by derk
Old Oct 28, 2010, 07:51 AM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
Yes, We wanna see!
phillip57 is offline Find More Posts by phillip57
Old Oct 28, 2010, 10:19 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
What Derk said.
I have a P-82 on the backburner and 3mm Depron with a thin carbon strip on the CG is all i wa planning to do to stick them together.
I plan to run Wires between the bricks to make the parallel so they start and bind with one battery.
UNGN is offline Find More Posts by UNGN
Old Nov 28, 2010, 09:07 PM
Redhood is offline
Redhood's Avatar
Joined Aug 2010
Here are a few pics. I'll post more complete ones soon.
Old Nov 29, 2010, 12:12 PM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
make sure those props counter rotate or you may have some trim issues...then again i may be wrong...prettysure i read somewhere about that
kelloggair is offline Find More Posts by kelloggair
Old Nov 29, 2010, 12:37 PM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
I think you are going to need some dihedral in there somewhere. You may want to use some lite ply to make the "V". I'm thinking that you want to extend the carbon spar with some support for the outer wings with dihedral.
Good luck with this. I hope it works out.
ducatirdr is offline Find More Posts by ducatirdr
Old Nov 29, 2010, 01:14 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
It appears he connected the carbon to the inside wing stubs so it will have more dihedral than a single mustang would have... not that you need any with ailerons.
Old Dec 06, 2010, 10:08 PM
Redhood is offline
Redhood's Avatar
Joined Aug 2010
I have the P-82 airframe is mostly finished. A bit of filling and sanding still required. I discovered I'll need to move the battery locations forward below the front pink spacer block. I reinforced the wing center section and tail with 3mm x .8 mm carbon flat per Derk's suggestion. Thanks Derk! As far as the dihedral goes it'll be the same as the T-28.
Old Dec 07, 2010, 03:52 PM
Slider2732 is online now
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
Looking forward to you completing this one...don't see many being modelled.
Anyone who posts a front on shot halfway through a build gets my respect
Slider2732 is online now Find More Posts by Slider2732
Old Dec 09, 2010, 11:34 PM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
wicked.
keepin them 2 fuses true must be one heck of task ?
Prime_8 is offline Find More Posts by Prime_8
Old Jan 24, 2011, 12:13 PM
Redhood is offline
Redhood's Avatar
Joined Aug 2010
An update.
I'm slowly moving forward on the P-82 build. I had the flame dampening exhaust made by http://www.shapeways.com and couldn't be happier. You should check it out if you need any custom parts for your micros.
Wanted Nitroplanes P-82 Twin Mustang Yardbee Aircraft - Fuel - Airplanes (FS/W) 3 Feb 02, 2013 03:31 AM
Discussion F-82 Twin Mustang from modified P-51D Combat Plans Atomo Foamies (Scratchbuilt) 10 Oct 14, 2010 05:18 PM
Sold Parkzone P-51D Mustang Bind n Fly With Extras! Torx Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Oct 14, 2010 12:07 PM
Discussion P/F 82 Twin Mustang The Ghost Fuel Warbirds 2 Oct 05, 2009 02:47 AM
