BoxFly Simple Foamboard plane good for windy days with video & plans
I recently posted a video of a plane I build about 1 month ago called Simple box flier. I decided to do a build thread on it and to give it the name BoxFly.
Boxfly is a plane that can do a snap roll in a heart beat. It's lots of fun to fly and with less throw on the controls if would work good for a trainer. I have flown it in wind at better than 20mph, with slight wind 8 to 12 mph the wind has very little effect on it. This is a heavy plane the way I built it, but it is very strong and as a result of the extra weight it does well in wind. It comes in at 17oz AUW which is about 4 to 5oz. more than most 30" planes I build. I have lots of pictures soo I will enter new post rather than try to put everything in one post. The pictures will have a brief explanation of what is going on. You will notice I used a craft glue for the build but and good foam glue will do. If I had it to do over I would use Hot Glue. The plane is built using sheets of Dollartree Foamboard 20" X 30" I have added plans for building. I would like to express my sincere appreciation to potshot for drawing up these plans Thank you
Before we proceed I have a short video of the finished plane. This was made just before dark with winds at about 10mph.
Later I will tell about the power system.
Now I begin to put the fuselage together. I like to use masking take to hold things together while the glue dries.
I like to use large size Popsicle sticks/ tongue depressors to reinforce things and add strength to places that will be under stress.
After I finish the plane I use clear 2" packaging tape to cover everything and protect the plane from water, and hopefully the paper coming loose after the build.
Once you cover it with the tape it becomes super strong and easy to keep clean the tape used weights about 1/2 oz or less. The plane is 30" wingspan 8" wing cord 240 sq.in wing area the total all up weight was 17 oz with the battery. I am not very good at Cad programs for the plans. But one of the fliers here on the forum has agreed to draw up a set of plans for me. So if everything goes well I will post plans in the future. I can post the plans as an attachment picture but i at this point don't know how to make plans that can be down loaded to make the plane from. The Motor is Tower Pro 1000 Kv 2410-12T 3 I have been using a 9x7 slow fly prop with a 1000ma 2S battery. I use a program by a flier here on this forum called WebOcalc to let me know what system to use. I love the program it is much easier to use that Moto-calc whic I also have. Let me add this; if you are going to fly is heavy winds you may want to go to a 3s battery, and maybe an 8x6 propeller. I have found that your motor should weigh between 50 to 60 grams for a 17 oz plane and WebOcalc will tell you what size and type of prop for the way you want to fly. You will find the software here http://flbeagle.rchomepage.com/ This link will take you to where the program is explained http://www.rcgroups.com/forums/showthread.php?t=254742
| Thread Tools | |
| Video BoxFly 30 inch foamboard for windy weather | propjobbill | Electric Plane Talk | 4 | Oct 28, 2010 06:23 PM |
| Yippee! Here's a Plane for Windy Gusty Days | pcaffeldt | Foamies (Kits) | 76 | Aug 01, 2004 02:17 PM |
| Plane for Windy Days | ChazAxl | Beginner Training Area (Aircraft-Electric) | 7 | May 21, 2004 05:17 PM |
| Good electrics for windy days | aeajr | Parkflyers | 69 | May 13, 2003 09:48 PM |
