Old Oct 26, 2010, 02:51 PM
Hannu Vuorinen is offline
Find More Posts by Hannu Vuorinen
Registered IGG Finland pilot
Hannu Vuorinen's Avatar
Finland IGG-FIN
Joined Feb 2003
Indoor Aerotow
Hello fellas!
Once outdoor aerotow season is now ending here in Nordic,
we experimented little bit transferring that great fun into Indoors
also, so here we go, Indoor aerotow:
Lahti Fly indoor - small scale aerotow (1 min 19 sec)
and towing 2 gliders at once:
Lahti Fly indoor - dual small scale aerotow (2 min 14 sec)
Tow plane is CC Lee Cessna -conversion with Parkzone technic, AUW apprx 40g.
Gliders are apprx 100 cm region wingspan
Best regards,
Hannu
Hannu Vuorinen is offline Find More Posts by Hannu Vuorinen
Old Oct 26, 2010, 03:19 PM
Slider2732 is online now
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
Ha excellent !!!
I can imagine heating vent thermal riding too in winter. What a wonderful sight, so very different and graceful
Slider2732 is online now Find More Posts by Slider2732
Old Oct 26, 2010, 03:41 PM
Ryan Archer is offline
Find More Posts by Ryan Archer
United States, AZ
Joined Aug 2004
Very cool!
We do something similar at our field, but there isn't that much interest in it.
What you have done is great! Thank you for posting it,
Ryan
Ryan Archer is offline Find More Posts by Ryan Archer
Old Oct 26, 2010, 04:08 PM
del is offline
del
Find More Posts by del
del
del's Avatar
north of Chicago
Joined Feb 2003
Beautiful!
Can you show us the details of your tow release mechanism?
--del
del is offline Find More Posts by del
Old Oct 26, 2010, 05:20 PM
Finland IGG-FIN
Joined Feb 2003
Hello,
well, there is not much in release mechanism, it is just a pin, where towline is attached. Once glider is turning " in" and tug "out", it releases towline from pin.
So far, it looked to be working just ok
BR,
Hannu
Old Oct 26, 2010, 05:54 PM
del is offline
del
del
del's Avatar
north of Chicago
Joined Feb 2003
Originally Posted by Hannu Vuorinen View Post
Hello,
BR,
Hannu
Thanks for the info, Hannu,
From what I can see, I presume that you are using rudder and elevator. Is that true?
This year at the KIEF model meet some friends tried indoor aerotow. It was not successful. The glider was not stable in yaw or roll while on tow. Do you have any suggestions?
--del
Old Oct 26, 2010, 07:49 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
I'd like more information on the glider! Size, AUW, construction, possibly some 3-views?
Jay
Faethor is offline Find More Posts by Faethor
Old Oct 26, 2010, 11:00 PM
Finland IGG-FIN
Joined Feb 2003
Hello!
Here is some basic specs for Indoor aerotow we used:
Towplane:
-Flying speed as low as possible, needs good static thrust
-Wingspan max 80 cm
-Motor + radio technic for example from ParkZone/Mustang/Sukhoi,
on video towplane is freeflight CC Lee Cessna Rc- conversion with Parkzone
technic inside. We used succesfully also RTF Nine Eagle Cessna in Lahti Indoor event.
-all up weight 40 grams is Ok to tow 100 cm wingspan glider with AUW 40g
-only rudder+elevator is enough for controls
Glider:
-100 cm wingspan seems to be quite good one, scale is approx 1:15
-Profile models, plate type wing, with slightly curved type airfoil
-material used was depron insulation plate, 3mm thickness
-keep it light
-wingload is apprx 3-5g/dm2
-only rudder/elevator control is enough
-tow release servo is not needed, just pin for tow line attachment
This was just our 2nd test for Indoor aerotow, so lets see later on where
"development" leads.
Best regards
Hannu
Old Oct 27, 2010, 02:48 AM
3D Devil is offline
Find More Posts by 3D Devil
Kouvola Utti, Finland
Joined May 2003
Hello guys,
Here comes more info.
Some specs from Ka6e as shown on the second video and two pics on few message above.
Scale 1:15 with no cheating on any surface areas. All material used is 3mm Depron to wing and 6mm to fuselage.
Wing has no spar or anything else strenghtening, just curved slightly.
I glued piece of 0.8x3mm carbon rectangular rod to bottom of the fuselage for strenghtening it.
Lightened Spektrum AR6100, RC1 servo 2pcs, 135mAh 1s Lipo. 1mm carbon tubes for the pushrods with 0.5mm piano wire ends.
All up weight is bit less than 22grams.
I will built new wings with different airfoil and slightly enlarged wing area.
You can find some vintage glider 3-views here: http://www.scalesoaring.co.uk/VINTAG...mentation.html
Now I have on my workbench Finnish designed PIK-15 tow plane project - of course 1:15 scale! EPP fuselage and wings, depron tail surfaces. AUW target is approx. 40g...
BR,
Kimmo
3D Devil is offline Find More Posts by 3D Devil
Old Oct 27, 2010, 05:57 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Wow!
I posted a link in the scale glider forum. Most of those guys think that 1/4th scale is on the smallish side, but I'll bet they like it.
I love the idea, but I don't know any place in NYC where there is indoor flying.
I think I will investigate building something anyway. I am a glider freak. Full sized and models.
Pete
BTW, Scale Soaring UK listed above has a lot of really nice Pathé and Movietone newsreel clips. I think I downloaded around ten or fifteen and also there are some classic old gliding books in PDF format. (Some won't open on my iPad but do okay on my Mac,)
PeteSchug is offline Find More Posts by PeteSchug
Old Oct 27, 2010, 07:12 AM
Faethor is offline
Joined Jul 2007
In my late 20's I started taking lessons to get my Glider License, but my funds ran about half way through.. Some will probably never understand how piloting a scale model with a Tx can bring the joy and peace of mind you get hanging 5000 feet above ground riding thermals, but I swear, sometimes I feel.. Well, you know..
Jay
Old Oct 27, 2010, 07:15 AM
Mike Tully is offline
Find More Posts by Mike Tully
Methuen, MA
Joined Sep 2002
Hannu,
Very nice gliders and video. Thank you for posting all the info. I am building a 30 gram scale glider and hope to get results as good as yours.
Mike Tully is offline Find More Posts by Mike Tully
Old Oct 27, 2010, 09:57 AM
ShawnM4kq is offline
Find More Posts by ShawnM4kq
Still AWD, Subaru
St.Louis
Joined Nov 2006
those gliders look so graceful
the Rhon Bussard looks perfect for vapor guts...you said you built from 3mm?
ShawnM4kq is offline Find More Posts by ShawnM4kq
Old Oct 27, 2010, 10:47 AM
Baratacus is offline
Find More Posts by Baratacus
Post Digger
Baratacus's Avatar
San Diego, CA
Joined Oct 2005
you should get some really nice hang time with your lightened version that you're building. Most indoor gliders are ultra light weight and can stay up for a really long time, but they wouldn't stand up to being towed like that. Should be a challenge to find just the right ballance.
something slider mentioned about thermals, you might see if they'll let you put a small electric blower over to one side of the room with a deflector so you can have a little up-thermal to grab some altitude.
awesome job on the planes and the execution, and a really simple easy tow release.. I would have completely overcomplicated it.
Baratacus is offline Find More Posts by Baratacus
Old Oct 27, 2010, 11:18 AM
3D Devil is offline
Joined May 2003
Hi,
Yep, wings and horizontal tail is 3mm depron. Fuselage 6mm depron - two laminated 3mm depron might work successfully.
If AUW is 20g +/-5g, wing should not need the spar. Wing will feel pretty flexible, but will handle well at slow speed. Sure it will bend if speed or weight goes too big. For the test glide it won't need as powerfull throwing like parkflyers. Just a light push.
Our sailplanes have 100cm wing span. Grunau Baby (on the first video) will glide down approx. 0.45m/s which is pretty good from that size glider.
BR,
Kimmo
Alert Twin Cities Fall Aerotow #2, Saturday, October 16, 2010 sekollera Sailplane Events 0 Oct 13, 2010 09:16 PM
Alert UPDATED!! Twin Cities Fall Aerotow #2, Saturday, October 16, 2010 sekollera Scale Sailplanes 1 Oct 12, 2010 01:00 PM
Sold Visalia aerotow next week end oct.16-17 electric man Aircraft - Sailplanes (FS/W) 0 Oct 09, 2010 11:04 AM
Alert Twin Cities Fall Aerotow - SUNDAY, 9/26/2010 sekollera Scale Sailplanes 7 Sep 28, 2010 04:43 PM
Discussion tvsa aerotow sept 12th 2010. socommk23 Scale Sailplanes 4 Sep 21, 2010 12:36 PM
