Old Oct 26, 2010, 02:16 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Help! What size core can I use this equipment on? Thanks!
Hi everybody!
I have a bunch of equipment I was hoping to use on scratchbuilding my first wing. If possible, I have a small FPV system I want to use on it. I have a hotwire cutter, and have built a FireFly from laminated depron from scratch. So here's the equipment I have on hand and hope to use:
-18/20A or 25/30A ESC.
-TowerPro 2408-21: http://hobbyking.com/hobbyking/store...idProduct=4321
-5 of these nice Futaba 44g servos: http://www3.towerhobbies.com/cgi-bin...P?I=LXH286&P=8
-a bunch of 2200 3s lipos. I also have a parallel connector to be able to run 2 of these at the same time for double duration.
-Nice programmable radio.
If the motor is no good, I could buy another I suppose. But I don't want to invest in any other gear for this project.
My hope is to make a small solid wing for FPV. This means tough, stable, able to fly slow, and no aerobatics necessary.
What size of wing would work with this stuff? 36"? 48"?
Thanks again for your help!!!
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Oct 26, 2010, 03:51 PM
KFC is offline
KFC
Find More Posts by KFC
KFC
Blue Foam Master!!!
KFC's Avatar
United States, KY, Hanson
Joined May 2007
60" Check Monkey's rig out: http://www.rcgroups.com/forums/member.php?u=79638
KFC is offline Find More Posts by KFC
Old Oct 26, 2010, 06:15 PM
Expat
Japan
Joined Apr 2010
Thanks for the interest. Is that the Bluecore wing?
http://www.rcgroups.com/forums/showthread.php?t=497083
Does Monkey list more info on that build somewhere?
Old Oct 26, 2010, 06:31 PM
KFC is offline
KFC
KFC
Blue Foam Master!!!
KFC's Avatar
Joined May 2007
Same basic construction, but the geometry is different.
Old Nov 02, 2010, 06:13 PM
Expat
Japan
Joined Apr 2010
Any other options? How about a small solid core hotwire wing?
Question can you use this lipo in a 450 roganjosh1 Mini Helis 8 Oct 20, 2010 12:04 PM
Discussion What size rubber would you use on a peanut scale model? The Jaws of Ice Free Flight 10 Oct 20, 2010 04:10 AM
Question what is a good 3d foamy that I can use an AXI 2208/34 in? Irg 3D Foamies 2 Oct 14, 2010 08:50 AM
Discussion can someone help me? I need to know what size batts I need to use because these are sherlockshah Batteries and Chargers 2 Jun 25, 2009 02:18 PM
Question What size plane can I use a OS 40 LA engine on?? drumset55 Engines 9 Apr 29, 2009 12:01 PM
