thats where I am.One question, did you concider a separate tail wheel servo? Just a thought, the plane can probably handle the little extra weight. ![]() I look forward to flight report and video. Regards Phillip C Philkiteflyer Invercargill, South Island, New Zealand. |
Well she flies!
But I'm guilty of skipping a step on the assembly notes I just glued the wings strut tubes on instead of first lashing them with thread then glueing them. They came off because I let the elevator stick slip and I pulled back up violently as you saw after the first turn in the video. The reason it nose dived is because I needed a good amount of up-trim (CG was right on, the elevator was pointed slightly downwards). After a quick tape job I had her back up in the air.Anyway, I love how slow it flies considering mine came in pretty heavy at 32.5 oz! The 10X4.8 SF prop gave scale performance and after 27 min of flying on a 2200 mah 2S the battery voltage dropped to 7.6v so 30 mins should be easy. I really like putting around with takeoff flaps just above stall speed. Speaking of stalling, I only tried it once because of the wing struts. It didn't even stall, it was more like a 'parachute' (a move those 3D things do). I do have washout in the wings beacause the AUW is heavier then I want. But now that I know flies so nicely even at 33 oz, I am going to add the flap gap fairing, figure out how to add that foam stuff I got back in January to the landing gear and get some pilots and balsa sheets to make a fun cockpit. Should be a great fun-scale-stand-a-little-back contender for the scale fly-in this July. I really need to consider making some dummy skies as the full version does... Thats all I can say now because it was breezy (take a look at those mean storm clouds down the runway). The right wing was raised a bit higher then the left because of the bad wing strut tape job so the turns were a bit funky. The rudder really helps though. Ethan |
It looks great too. Once I get the lettering graphics on and fix the yellow paint that doesn't match around the side windows it will look great. I also need to figure out how to make some dummy skies....foam? Maybe balsa? Should be a fun late-spring project. But first to fix that 40 size sport plane that lawn-darted at 96 mph and left a 5-inch crater in the dirt today Ethan |
Thanks! Little bouncy but it cut through the wind just fine. I got some balsa sheets today from the LHS. They didn't any have pilots under 1/8 scale.
The plane is 1/10 scale but I can't find any pre-painted figures that are that scale. The closest ones I can find are 1/9 offerings from H9 but I won't be able to fit two in the cockpit. Any suggestions? I don't have the tools, colors or will to paint sorry ![]() I did find a good set of 1/10 scale instruments: http://www3.towerhobbies.com/cgi-bin...?&I=LXR679&P=7 |
| Thread Tools | |
| Wanted ICARE (TopModel) Pilatus Porter | JPHen | Aircraft - Fuel - Airplanes (FS/W) | 3 | Sep 12, 2010 12:54 PM |
| Pilatus Porter crashed, any idea? | RookieOne | Beginner Training Area (Aircraft-Electric) | 6 | Dec 18, 2001 03:04 PM |
| 8ft Span Pilatus Turbo Porter | EAMRC | Scale Electric Planes | 9 | Sep 24, 2001 12:54 AM |
| plan for Pilatus Porter? | partoftheproblm | Scale Electric Planes | 6 | May 19, 2001 05:58 AM |
