| Thread Tools |
| This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies. |
More tutorials!!! I need to get back to flying...
As a DIYer I have built everything from RC airplanes, to motors and even entire FPV setups. In the name of my Lord and Savior, Jesus Christ, I give you the following tutorials to help you be more successful in your ventures. Please enjoy.
In here you will find detailed tutorials that will walk you through scratchbuilding a model airplane, rewinding your electric motor, and many antenna tutorials for FPV enthusiasts. Below are my tutorials and build logs: Tutorials VTX antenna tutorial - Home of what is possibly the most popular aerial antenna in FPV, the inverted Vee! How to build a good ground station - Shows the basics of an FPV ground station as well as things not to do. DIY antenna tracker - The ultimate FPV accessory SWR meter - Tune your own antennas with this quick DIY project. 7.5-12 dbi Helical antenna - A fairly simple circularly polarized RX antenna with incredible performance! The Cloverleaf CP antenna - The best TX antenna I have ever designed! The 10dbic Circular Double Quad antenna - My first ever ground up design of a circularly polarized antenna. It Rocks! UHF turnstile antenna - Improve performance of your UHF radio system with this antenna Ground plane omni directional RX antenna How-to A good omni directional antenna for your FPV aircraft RX. Homebrew Yagi thread - Home to moderate gain Yagis and the Moxon rectangle RX antennas. The fast patch antenna tutorial - The easiest patch antenna you can make for your FPV project. Notch filter tutorial - Knock out interference with ease! 11dbi BiQuad antenna tutorial - A great medium to long range FPV RX antenna solution that can be built in an hour or two. The Skew-planar Wheel - A circularly polarized omnidirectional antenna! DIY diversity controller - Need I say more? Cantenna - 7 dbi in 10 minutes for FPV! How to Scratchbuild a performance electric plane - Tutorial on the basics of performance aircraft construction from scratch. Techniques, balancing, materials, and even motor selection are covered. Wicked fast aircraft construction tutorial - If you have the need for speed, get it here! Parkflyer tutorial with plans - For those who want to build a backyard flyer or park flyer. Scratchbuild hovercraft tutorial - Ok, so it's not technically an airplane, but it does fly. Would be kind of cool to FPV ![]() Simple lost model locator - Easy little device that you can plug into your battery balance port that will help you locate your plane at night if you crash it at dusk. Brushless motor rewind tutorial - If you have a few burned up motors, this might help you not only rewind them, but get a little more performance out of them. Build Logs Diablo scratchbuild pylon racer - This little thing clocked in at 121 mph on a 3S and a GoBrushless GBX triple (9N8P variant) The scratchbuild Bird of Prey - Oh yes I did make a forward swept wing flying wing airplane. And it does 120mph! The Minion - The ultimate FPV airframe. Spirit FPV - A durable speed pattern flyer Wraith V2 - an indestructible FPV parkflyer. 55 mph and 9 minute flight times on a single 2200 battery! Vampire FPV Pylon Racer - This one made a big impression at the Randy Covington Fly-In 2010 when it went skimming across the cornfield only 12" off the deck at 90 mph! Snyper FPV flying wing - Flies great, but nothing spectacular about it other than it's the best looking plane I ever built (which isn't saying much, trust me). Scout FPV - My first ever FPV plane. Even had pan and tilt! Carnivore FPV - This has done some of my most memorable flights. Unfortunately the earlier versions in the scratchbuild tutorial are better performers. Fork Tail Devil - high speed P-38 Lightning - One of these days I'll have the guts to actually fly this one... maybe. Demon V2 - Small park flying pylon racer Antenna tracker development - How the antenna tracker was born and tested. Okay, I think I just noticed I spend WAY too much time on this forum ![]() -Alex |
| Thread Tools | |
| Discussion Looking to get back in.... | Linker33 | Mini Helis | 31 | Nov 09, 2010 04:46 PM |
| Discussion Use pararell wire on big heli to get more flight time? | Voguna | Video Piloting (FPV/RPV) | 25 | Oct 14, 2010 08:35 PM |
| Discussion Helping my Dad get back into flying! SIERRA VISTA ARIZONA | flyinjrc74 | Beginner Training Area (Aircraft-Electric) | 3 | Oct 13, 2010 11:12 PM |
| Discussion Can We Get Harding and Coolidge Back? | Big Foot 48 | Life, The Universe, and Politics | 25 | Sep 13, 2010 01:55 PM |
