That batt. is deader than dead. I'd take it back and ask for a replacement. 12 volts is considered dead after full use and in need of charge, using a good batt. If you can't return it, hook it up to a regular car charger that has no low voltage warning and leave it on till it shows over 12 volts, than switch it over to your more sophisticated charger and hopefully it might take a charge.
Oops, I must be a slow typer. |
Space Coast
Joined Oct 2000
Florida
Joined Aug 2004
Opick, yes 1.2 amperes max. The following site has some very good info on battery care including Pb. http://www.hangtimes.com/redsbatteryclinic.html
Joined Oct 2010
It's kinda charging slow. The battery has had 14.39 volt for a couple of hours now, and the ampere meter is at 0.31 - 0.33 A. It is still feeding mah's, but it's increasing slowly.
I have charged it with 1.0 ampere. Is this the socalled float charging? Will it ever stop charging? |
Did you not listen to everydayflyer? That battery is on it's way out (the fuse is lit) so you should have taken it back. Its yours now.
![]() Rick |
Latest blog entry: mean well S-210-12 power supply
You keep buying dead / bad Pb batteries,. perhaps that one will last a little while.
You really need a true Deep Cycle and it really needs to be a fresh one. http://www.windsun.com/Batteries/Bat...AQ.htm#Battery Quote:
| Thread Tools | |
| Sold Litco Alpha 4 NiCd/NiMH/Pb Battery Charger w/ Extras | martyg | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Jan 27, 2011 04:06 PM |
| Discussion CP2 FIRMWARE 1.46 / Low Voltage Warning | Rejean Boucher | FMA Direct | 9 | Nov 06, 2010 04:45 PM |
| Discussion Hyperion EOS 0720iNET charging Pb: Too low voltage limit | gravityKills | Batteries and Chargers | 0 | Jul 26, 2009 12:59 PM |
| Discussion HELP Needed ! Battery check low voltage | bidouille | Batteries and Chargers | 1 | Mar 26, 2009 02:26 AM |
| Pb battery voltage is MINUS 6 Volt | W@CC0 | Batteries and Chargers | 1 | Sep 28, 2005 05:52 PM |
