Old Oct 27, 2012, 03:34 PM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Woww that is big!
I see that you painted the bowtie, I assume it's ok to do so. What about in my case the copper PCB as well?
Shinny copper catches too much attention in the park. I wanted to color it in a more discrete way.
IceWind is online now Find More Posts by IceWind
Old Oct 27, 2012, 03:38 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by tushev View Post
Tadaaa!! my version is ready to be tested
Looks good, buddy! Wait until you fly it
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 27, 2012, 04:43 PM
Thermicdude is offline
Find More Posts by Thermicdude
Still hackin'
Thermicdude's Avatar
Port Elizabeth, South Africa
Joined Nov 2005
433 bi-quad
I built a bi-quad for 1240MHz - a mate was so impressed he made a 70cm one for himself as well
Thermicdude is offline Find More Posts by Thermicdude
Old Oct 27, 2012, 09:45 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by IceWind View Post
Woww that is big!
Paint won't hurt it at all.
-Alex
Old Nov 10, 2012, 03:59 AM
Aich is offline
Find More Posts by Aich
Joined Nov 2012
bi-quad awsome
after reading this whole thread yesterday and a trip to maplins i made this 5.8ghz bi-quad
it works although as yet no range testing
i have been getting 450m on cp antennas and immersion long range vtx with fat shark goggles in less than ideal conditions
things that are wrong with my bi-quad
messy solder around post
id like a thinner post anyway this one is 5mm i want 4mm
wire is 0.92mm it should be 0.59mm
i read that the shape of the lobes is unimportant so long as they are symetrical and 1 wavelength, its very hard to make a square of wire this small and keep it to 1 wavelength and equal sides so i think the next one i will make 3/4 circular with small straigts at 90 degrees into the post.
once proved and working with my hexacopter and ground station tracker ill be making one for my control tx 2.4ghz
thanks for this informative thread - im very much inspired
Aitch
Aich is offline Find More Posts by Aich
Old Nov 11, 2012, 05:40 PM
IceWind's Avatar
Joined Feb 2005
Today I couldn't use my favourite combination of Vee + Biquad and instead I had to use another quad that has one of these antennas.
(900MHz 1/2 Wave 2dBi Antenna)
I know they aren't center tuned to 980Mhz that I use but I was expecting to at least have clear video at close range. Instead I got always noise, either close or far, of course with distance it would get even worse but in overall the image quality was horrible...
Is it just because of the antenna not been tuned to 980Mhz or is it because this type of antenna don't work well with the BiQuad?
Old Nov 12, 2012, 08:56 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'd suspect something is wrong with the antenna.
Old Nov 12, 2012, 01:17 PM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Check ther is a centre pin in there
Shikra is offline Find More Posts by Shikra
Old Nov 12, 2012, 08:44 PM
IceWind's Avatar
Joined Feb 2005
Oh yes that one is there.
I still get image and it works for 400/600mts... but it's awfull. Next weekend I'll run some tests and see if I can capture some video from the GroundStation.
Old Nov 15, 2012, 09:30 AM
Aich is offline
Joined Nov 2012
update on the 5.8ghz biquad
not actually about the biquad but have range tested the system again with 2 cp antennas and im getting just over 1km
have materials on order now to build an RHCP BI-QUAD and ill be range testing that back to back with current set up
Aitch
Old Nov 20, 2012, 07:35 AM
MXM000 is offline
Find More Posts by MXM000
Joined Jan 2012
Thanks for the design and instructions! I just made one for 2.4 GHz. I used a 0.5mm copper plate for a reflector, and wow, was that a mistake. Soldering anything to that massive heat-sink is near impossible. Maybe I'll re-make it with a copper-plated PCB some other time. I haven't tested the antenna yet, but I had a chance to plug it into a meter, take a look at that return loss on the last picture. Is it normal for this kind of antenna? Mind you, my feed is very long at the moment, maybe 1.5 meters.
MXM000 is offline Find More Posts by MXM000
Old Nov 20, 2012, 11:14 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
MXM000 - Your return loss looks a bit unstable. You might have a defect in the cable (or the feed) causing some resonance effect. This could be skin effect tracking down the tube. Your second major trough in your plot is most certainly skin effect of the signal tracking down the tube.
-Alex
Old Nov 25, 2012, 07:39 PM
dallibab is offline
Find More Posts by dallibab
Joined Jan 2011
-Alex
Hi Alex just building another of these for myself as they are wicked!
With what you are saying in the above post do you mean the ground is not connected well enough to the tube?
I only ask because I have no means of testing antennas at the mo and for the biquad normally I use a tube attached to the reflector that is a tight fit to the ground when pushed through then fold a bit of the ground sheath over then solder that.
Do you think this is sufficient?
John
dallibab is offline Find More Posts by dallibab
Old Nov 25, 2012, 08:00 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
What I am saying is that at certain frequencies the tube actually becomes resonant no matter how it is connected due to skin effect. There's nothing you can do about it other than put a ferrite ring around it. I wouldn't bother, though. You are building it just how I build mine: a tight fit tube.
Old Nov 25, 2012, 10:08 PM
dallibab is offline
Joined Jan 2011
Always worked well just checking. can always be better
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
