Old Oct 11, 2012, 03:24 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Anyone who can build a 5.8GHz Crosshair array is a better man than I am. The cable lengths would be so incredibly short that I don't know that it would be possible to phase them.
Helicals are a totally different story. You don't need matching networks for helicals. Why? Simple: you have to match the impedance to the line anyway with your matching stub. Sure you still need to rotate the helical antennas in your array to achieve rotation, but there is no need to use 1/4 wave lines. You can use 1/2 wave lines and adjust the characteristic impedance by moving the matching stub. This is the preferred method so that you ensure your load is purely resistive with respect to the other helicals in the array.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 14, 2012, 07:17 PM
Imagecatcher is offline
Find More Posts by Imagecatcher
Imagecatcher's Avatar
NSW Australia
Joined Mar 2010
Ground post
I didnt have copper tube and after needing so much heat to the gal reflector, I didnt want to solder the braid to it.
Q: is dropping a copper wire from the resonator (where the braid attaches) to the reflector ok?
I have seen it done in an earlier post but I dont recall any feedback from IBC or other as to any down sides.
Imagecatcher is offline Find More Posts by Imagecatcher
Old Oct 14, 2012, 10:42 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I really do not know. If it is indeed 1/4 wave long, then it should cancel itself out and work fine. If not, then I really do not know.
-Alex
Old Oct 20, 2012, 03:58 AM
Skipper1952 is offline
Find More Posts by Skipper1952
60+ = too old ;)
Skipper1952's Avatar
Poland, West Pomeranian Voivodeship, Szczecin
Joined Oct 2010
How about using biquad as TX antenna. It is electrically closed circuit. Is it safe for transmitter?
Skipper1952 is offline Find More Posts by Skipper1952
Old Oct 20, 2012, 10:12 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes it is safe for a transmitter. I am assuming you are referring to a 2.4GHz radio. This works well for increasing range so long as you are capable of aiming it.
-Alex
Old Oct 22, 2012, 05:03 PM
willieprinsloo is offline
Find More Posts by willieprinsloo
willieprinsloo's Avatar
Joined Oct 2007
Originally Posted by heinduplessis View Post
Holy smokes that was hard work
Mine did not come out as perfect as some of the others on here at all, but I was wondering if you all could take a look at it and see if I've made a catastrophic error somewhere.
Damn it's hard to solder something to a galvanized plate with a 25W soldering iron...
I couldn't find small nylon screws so I used wooden rods with epoxy.
I've soldered the shielding at the back of the plate in stead of the bottom of the front.
It looks great! Now it's time to test it...
willieprinsloo is offline Find More Posts by willieprinsloo
Old Oct 23, 2012, 01:25 PM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Well a huge thank you very much to Alex!
Willie & I just came back from ground tests and on 9.7km the signal was still fine, just some lines and the tiniest hint of noise. See attached.
If this is ground based, maybe I should still have perfect signal at 10km.
My tx is a lawmate 500mw with a home made V.
The stock dipole ducktail dropped out at 3km.
Thanks Alex!!
heinduplessis is offline Find More Posts by heinduplessis
Old Oct 23, 2012, 01:59 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You will go way farther than 10 km if you are doing 9km on the ground. The ground blocks ~50% of the Fresnel zone at that distance. In the air, the Fresnel zone is clear.
-Alex
Old Oct 23, 2012, 02:16 PM
Foam Snow
Joined Aug 2011
-Alex
Yeah - that football shape beam. I'm just carefully optimistic
I'll know by the weekend..
Old Oct 25, 2012, 05:27 AM
Foam Snow
Joined Aug 2011
-Alex
We just did 17km from Table Mountain to Blouberg!! Perfect signal, even better than the 10km ground test!
Long Range FPV Antenae - 30KM (0 min 9 sec)
Old Oct 25, 2012, 08:30 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^You had a long way to go on that BiQuad. If you are confident your plane can make a longer journey, go for it. The BiQuad rocks. I like it so much that I'm actually ganging 4 of them in a phased array for a professional project of mine.
Old Oct 25, 2012, 10:00 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Great!
I'm still pushing the limits of my antenna.
Just out of curiosity what's the power of the vTX you using?
IceWind is offline Find More Posts by IceWind
Old Oct 25, 2012, 03:40 PM
Foam Snow
Joined Aug 2011
Sounds serious I'm just delighted it works so well!
Originally Posted by IceWind View Post
Great!
500mw lawmate.
Old Oct 27, 2012, 02:11 AM
tushev is offline
Find More Posts by tushev
tushev's Avatar
USA, NY, New York
Joined Nov 2008
Tadaaa!! my version is ready to be tested
tushev is offline Find More Posts by tushev
Old Oct 27, 2012, 03:33 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Not to 1-up anyone but...
Just finished this bad boy this morning. 17dbic linear phased OctoQuad array.
Phasing network is 2 - 3/4 wave 50 ohm cables.
-Alex
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 23, 2010 12:52 AM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 04:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 01:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 05:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 09:05 PM
