Old Aug 25, 2012, 07:50 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by erkq View Post
The corners in that antenna aren't sharp. Does this matter? I'm thinking it does...
Not at all. Actually the only detriment is that the wire is flat and not rounded.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Aug 25, 2012, 08:11 PM
snelan is offline
Find More Posts by snelan
snelan's Avatar
Joined Jul 2012
-Alex
Hmm, just out of curiosity, how would the signal and performance be affected if instead of two squares, you just used two loops of wire. I assume the polarization would be very erratic?
snelan is offline Find More Posts by snelan
Old Aug 25, 2012, 08:40 PM
Jack2010 is offline
Find More Posts by Jack2010
Joined Jan 2012
Hi Alex,
I am using your SPW/CL for my 1.2 video link and they are just great. Now I would like get better on the RC link. I know most of you would say: go for UHF, but for the moment I only have 2.4 as an available solution (Spektrum DX8).
With that said I have rather no options on the RX side as it is fix part of my setup (I think it is just non-mod part of my system). However on the TX side the sky is the limit
I have already mod my TX in the way that I can plug in any antenna via SMA connector.
So, after reading many threads on different antennas I came to a conclusion that biquad is possibly my best option. Am I right? Most of you here are using it for video and on the RX. I will be using it on the RC and TX - will this work anyway?
The other concern is that I will have no diversity solution, so will not be able to put two of biquads in order to increase my coverage (horizontally). Is this something to be taken into consideration?
Jack2010 is offline Find More Posts by Jack2010
Old Aug 27, 2012, 09:27 AM
julie32 is offline
Find More Posts by julie32
United States, GA, Atlanta
Joined Oct 2009
Originally Posted by julie32 View Post
Alex, I have been reading this thread lately,
http://www.rcgroups.com/forums/showthread.php?t=1702036
I am thinking I want to build my own biquad for my Frysky tx module. Does the reverse polarity change the construction at all? Do I still connect the coax to the reflector and the cntr conductor to the element?
Thanx in advance for your help.
Update; Tried my homemade biquad yesterday on my frsky module and I got 5381mtrs (3.3 mi) with no faisafes. Was really nice to fly as I didnt have to keep Tx pointed at plane. I turned around because I started losing video. Looks like I will be building a Biquad for that. (using Alex's homemade patch right now)
julie32 is offline Find More Posts by julie32
Old Aug 27, 2012, 02:22 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
I actually have one of those. Not perfect, but certainly awesome. And for that price, it's a heck of a deal!
-Alex
thanks for the reply.
finally got round to building my own tonight for 1280
will be attempting a 5.8 one soon
mudlark is offline Find More Posts by mudlark
Old Aug 30, 2012, 08:58 AM
Fahmi43 is offline
Find More Posts by Fahmi43
Indonesia, West Java, Depok
Joined Mar 2012
Can i use 2.4mm Copper Coated Steel wire (TIG welding feeder) for 1280mhz frequency?
Fahmi43 is offline Find More Posts by Fahmi43
Old Aug 30, 2012, 11:54 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Absolutely!
Old Aug 31, 2012, 02:18 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Jack2010 View Post
Hi Alex,
A biquad would do well. Expect about 4X range or so if you are able to aim it properly.
-Alex
Old Sep 19, 2012, 06:15 PM
WTurbiasz is offline
Find More Posts by WTurbiasz
Tree Flyer
WTurbiasz's Avatar
Albany NY
Joined Feb 2005
Well its not perfect but it seems to work. I made it for 2.4Ghz and will try it out this coming weekend. For now I just hooked it up to my WIFI and saw networks that I have never seen before so Im thinking its doing a good job.
Tek
WTurbiasz is offline Find More Posts by WTurbiasz
Old Sep 19, 2012, 06:20 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^That's what I use my BiQuad for: WiFi sniffing
-Alex
Old Sep 19, 2012, 06:55 PM
klaw81 is offline
Find More Posts by klaw81
Australia, QLD, Toowoomba
Joined Jul 2012
Just to make sure I understand this: you're using a FrSky module with a Bi-Quad antenna for RC control at over 5km? That sounds like a great solution, although you need to keep it pointed at the plane with a reasonable degree of accuracy.
So here's the next logical step for that setup....mount a suitable directional antenna for RC control beside your video Rx bi-quad/patch/helical on the same antenna tracker.
For many hobbyists, this could be a genuinely viable alternative to $300+ UHF systems to achieve moderate range.
klaw81 is offline Find More Posts by klaw81
Old Sep 20, 2012, 07:13 PM
julie32 is offline
Joined Oct 2009
Yes that is what I use. I have now been to 5550 mtrs with this setup however I got a failsafe at that distance. I believe I was to low and under the antenna beam.
Next time I go I plan to use an angle finder to carefully set the ant angle. I use a magnetic compass to set my ant direction.
So far this has been a low cost,simple solution for med range flights.
Also check out this thread.
Old Sep 25, 2012, 10:59 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Here are a couple I did. The 5.8 is not an easy one.
Martin Y is online now Find More Posts by Martin Y
Old Sep 27, 2012, 06:05 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Would it be really bad to use a 200x300mm copper PCB to use with 910/980Mhz?
I couldn't find bigger PCB's that this and I know it's falling shorter than the expected size. (320x320mm)
IceWind is online now Find More Posts by IceWind
Old Sep 27, 2012, 07:40 AM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
I found that 1/8 wavelength minimum from the ends of the antenna element is good. So your 200 x 300 mm is spot on.
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
