Old Jul 09, 2012, 09:50 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by mandis View Post
hi Alex!
will this biquad works on 5.8?
i searched but not much info..
thanks in advance
mandis
If you can build it at such a frequency, then yes it will work fine. The question is, can you actually and accurately build it that small?
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jul 10, 2012, 05:57 PM
mandis is offline
Find More Posts by mandis
Joined Jan 2006
-Alex
can you tell me what the measurements are, so i can try to build it.
thanks!
mandis is offline Find More Posts by mandis
Old Jul 10, 2012, 08:44 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
thanks!
Well for 5840mhz 1/4 wave is 1.2cm and distance from reflector is 6mm.
Martin Y is offline Find More Posts by Martin Y
Old Jul 10, 2012, 09:41 PM
mandis is offline
Joined Jan 2006
thanks martin!
ok so it is12mm and 6 mm distancefrom the reflector.
what about the reflector size is it 52mm square?
Old Jul 10, 2012, 10:48 PM
Martin Y is offline
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
thanks martin!
That'll work, make sure your bends are tight. Nice thin guage wire. Dont use standoff's. Or just use a piece of pcb board and etch it.
Old Jul 11, 2012, 12:58 AM
mandis is offline
Joined Jan 2006
i have a blank pcb in hand. sorry for being slow with this but i'm good with soldering and copying . maybe you have a photo so i can take a look i think it's easier for me to understand..
thanks
Old Jul 11, 2012, 01:09 AM
mandis is offline
Joined Jan 2006
which antenna is recommended to pair with the biquad?
thanks
Old Jul 11, 2012, 07:28 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I use a Vee antenna on my airplane when I have the BiQuad on the ground.
-Alex
Old Aug 02, 2012, 09:22 AM
julie32 is offline
Find More Posts by julie32
United States, GA, Atlanta
Joined Oct 2009
Alex, I have been reading this thread lately,
http://www.rcgroups.com/forums/showthread.php?t=1702036
I am thinking I want to build my own biquad for my Frysky tx module. Does the reverse polarity change the construction at all? Do I still connect the coax to the reflector and the cntr conductor to the element?
Thanx in advance for your help.
julie32 is offline Find More Posts by julie32
Old Aug 02, 2012, 03:36 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^Not at all! Just build it as outlined in this tutorial.
-Alex
Old Aug 05, 2012, 05:17 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
Saw this on ebay
http://www.ebay.co.uk/itm/Biquad-ant...ht_2925wt_1398
what do you recon ??
mudlark is offline Find More Posts by mudlark
Old Aug 25, 2012, 10:52 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by mudlark View Post
Saw this on ebay
The corners in that antenna aren't sharp. Does this matter? I'm thinking it does...
erkq is online now Find More Posts by erkq
Old Aug 25, 2012, 10:55 AM
erkq is online now
Joined Dec 2010
-Alex
How would it work with a circularly polarized cloverleaf Tx antenna? I have a matching Rx antenna I was going to use for close-in on a diversity system. Seems the "V" would be easier to mount for sure at 910mhz.
Old Aug 25, 2012, 11:35 AM
Niels Erik is offline
Find More Posts by Niels Erik
Sorry-I am from Denmark !!
Niels Erik's Avatar
Danmark, Lolland, Søllested
Joined Nov 2010
Bi quad-Danish edition-Copper plate and 2mm welding steelwire. I made it for 1280 mhz.
After testing i will make a wood backplate so it can be mountet on a tripod
Niels Erik is offline Find More Posts by Niels Erik
Old Aug 25, 2012, 07:49 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Saw this on ebay
I actually have one of those. Not perfect, but certainly awesome. And for that price, it's a heck of a deal!
-Alex
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
