Old Jun 25, 2012, 12:24 PM
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
Thanks IB
When you say "with a 20 degree tilt", you mean that the square shape of the antenna does not sit level with the ground? That each tilts (I assume the left antenna would tilt left and the right would tilt right?) 20 degrees offset from the ground itself?
And 45 degrees up seems like a lot. At a 50 degree beam that would leave approx. 20 degrees of uncovered area near the ground. No low level flying allowed there? Perhaps that's a unique condition of your environment?
turbodriven is offline Find More Posts by turbodriven
Old Jun 25, 2012, 01:14 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I mean I aim it up 20 degrees and the antennas are 45 degrees offset from eachother.
Remember the 55 degree beam is the -3db point. At that edge you still have +8db!
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 25, 2012, 01:51 PM
100mph club member
NW O-town
Joined Jun 2005
That makes sense. Thanks, I'm going to start building the tripod mount tonight.
Old Jun 29, 2012, 10:20 AM
100mph club member
NW O-town
Joined Jun 2005
Complete. Almost. I still want to find/build a dome/box to protect each biquad array. As long as I'm careful though they are pretty stiff as is and the spacing from the reflector is consistent. I may add some bracing for added insurance if nothing else.
Galvanized 26ga sheet metal from Lowes
12ga solid copper core wire from Lowes (a bit thick but I wanted it stiff)
Steel compression pins for the standoffs from Lowes (only thing I could find that fit the RG58 cable snug and was solderable)
RG58 SMA cables from Ebay.
And a bit of plywood I had laying around the shop
We'll see how she works this weekend. Although I'll still be limited to only about 2 miles by my radio.
Old Jun 29, 2012, 12:53 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^That must be one mighty strong tripod! Nice job on the diversity BiQuads, though. That was one of my favorite setups.
-Alex
Old Jun 29, 2012, 02:11 PM
100mph club member
NW O-town
Joined Jun 2005
The whole antenna "array" weighs about 5lbs. I could probably shave another 1lb off if I drilled a bunch more holes in all the wood but the tripod seems to hold it without much effort as is. And I don't plan on hiking into any remote locations with it so meh... it'll do for now.
I'm excited to see it perform!
Old Jul 01, 2012, 08:30 AM
modelerchina is offline
Find More Posts by modelerchina
Canada, ON, Mississauga
Joined Apr 2006
how do you straighten the mig wire come out of roll?
modelerchina is offline Find More Posts by modelerchina
Old Jul 02, 2012, 08:06 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I use a series or rollers that straighten it via a variable tensioner wheel.
-Alex
Old Jul 02, 2012, 10:48 AM
100mph club member
NW O-town
Joined Jun 2005
The easy way is to put one end of the wire in a vise, and the other in the chuck of a drill. Pull it tight and then drill away. As the wires spins it straightens it out. It's actually a pretty cool trick.
Old Jul 03, 2012, 08:29 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^ I will pass that on to my machinist. He will be very interested in that technique.
-Alex
Old Jul 03, 2012, 09:06 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I tried it with MIG wire, doesn't work. It do well with copper wire, but with MIG it just go worse.
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Jul 07, 2012, 11:16 AM
ssquillace is offline
Find More Posts by ssquillace
The squidman
United States, FL, Jacksonville
Joined Dec 2011
Do you recommend different wire size for different frequency, i will be on 2510 . Should i use still use 14 AWG?
ssquillace is offline Find More Posts by ssquillace
Old Jul 09, 2012, 08:28 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
14 or 16 AWG works for 2510. My personal 2450MHz BiQuad is 14 AWG wire.
-Alex
Old Jul 09, 2012, 07:36 PM
mandis is offline
Find More Posts by mandis
Joined Jan 2006
hi Alex!
will this biquad works on 5.8?
i searched but not much info..
thanks in advance
mandis
mandis is offline Find More Posts by mandis
Old Jul 09, 2012, 07:38 PM
olympioneto is offline
Find More Posts by olympioneto
Joined Jan 2012
Hi IBCrazy
I would like thank you for the biquad project.
This is mine and works perfect:
regards
Olympio from Brasil
olympioneto is offline Find More Posts by olympioneto
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
