Old Feb 27, 2012, 09:57 AM
H19 is offline
H19
Find More Posts by H19
H19
H19's Avatar
United States, ME, South Portland
Joined Feb 2011
can i use, RG-6 75ohm 3.0GHZ direct TV digital cable?
or
F6TSVV-or-UU-cant read it right) ETL CATTV 18AWG
to make a BiQuad?
thanks
H19 is offline Find More Posts by H19
Old Mar 30, 2012, 06:20 PM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
Hi Alex, please, is it OK to cover resonator with plastic cover - in this example I used plastic box from Carte D'or ice cream ? Or it will damage the antenna gain or characteristics or all together...
Rastislavko is online now Find More Posts by Rastislavko
Old Mar 31, 2012, 02:43 AM
Neo360 is offline
Find More Posts by Neo360
Joined Jul 2009
I do not think there are problems, it's just plastic!
Neo360 is offline Find More Posts by Neo360
Old Apr 07, 2012, 01:06 PM
jetboy_05 is offline
Find More Posts by jetboy_05
United States, UT, Ogden
Joined Oct 2008
5.8ghz Biquad
Hey, I freaking love this Antenna, I built one for these Biquads for 5.8ghz. I'm
Running one of your clover leaf antennas on my Transmitter, and this biquad, on
the receiver. Its flawless video, I haven't found the limits yet. Iv'e been out over three
miles and not a blip. My Dad has access to a network analyzer. These are the
results of my Biquad. -20.60dB and a 1.2swr
jetboy_05 is offline Find More Posts by jetboy_05
Old Apr 07, 2012, 08:14 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That cover is fine. Good idea, actually.
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 08, 2012, 09:45 AM
Thermicdude is offline
Find More Posts by Thermicdude
Still hackin'
Thermicdude's Avatar
Port Elizabeth, South Africa
Joined Nov 2005
Tuning
Hi Alex - how do you tune a BiQuad for SWR? ie you can trim a patch and use gamma match on a yagi...
Thermicdude is offline Find More Posts by Thermicdude
Old Apr 08, 2012, 09:47 AM
erazotropa is offline
Find More Posts by erazotropa
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Make the figure 8 as best as you can in measurements..
Then tune it by moving the figure 8 up and down from the reflector plate
erazotropa is offline Find More Posts by erazotropa
Old Apr 08, 2012, 09:52 AM
Still hackin'
Joined Nov 2005
Duh... that makes sense!
Old May 27, 2012, 05:41 AM
hwat rc is offline
Find More Posts by hwat rc
Australia, QLD, Maleny
Joined Jul 2009
I'm struggling to find a solderable reflector for a reasonable price, do you think this would be ok http://www.ebay.com/itm/1-X-Copper-P...item4ab435f257
hwat rc is offline Find More Posts by hwat rc
Old May 30, 2012, 03:05 AM
Still hackin'
Joined Nov 2005
I used PCB on mine - perfect
Old May 30, 2012, 03:37 AM
HF_ATL is offline
Find More Posts by HF_ATL
Portugal
Joined Nov 2009
+1
Used single sided copper clad PCB
HF_ATL is offline Find More Posts by HF_ATL
Old May 30, 2012, 08:07 AM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
New at this
BiQuad 11dbi antenna.
what would give the further distance.
A BiQuad with 4 squares in a row
or
Two BiQuad on stacked on top of the other?
Thanks for the Help
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Jun 04, 2012, 10:21 AM
clr2cont is offline
Find More Posts by clr2cont
clr2cont's Avatar
Joined Oct 2006
Pcb active element?
Has any one made the active element from a etched pcb trace. I am considering making the bowtie for 2.4ghz by etching on a pcb. I see a lot of commercially made antennas use this method. Will it work as good as 14-16 awg?
Joe
clr2cont is offline Find More Posts by clr2cont
Old Jun 23, 2012, 09:47 PM
turbodriven is offline
Find More Posts by turbodriven
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
I've made two biquads for my 1280mhz diversity setup. For medium range flying (1-3 miles) what do you think is the best way to mount these both to my tripod? I'm thinking side by side angled up slightly of course and also so that each antenna's 50 degree beam overlaps the other by a few degrees? I don't have a tracker.
turbodriven is offline Find More Posts by turbodriven
Old Jun 25, 2012, 08:04 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I would say this is an acceptable system. In fact, this is exactly what I personally use. I angle mine at 45 degrees up with a 20 degree tilt
-Alex
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
