Old Dec 15, 2011, 09:07 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
No. That will work fine. I do the same thing.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Dec 15, 2011, 09:38 PM
Yhdysvallat, CA, Irvine
Joined Nov 2007
-Alex
Ok great. I realized what I did after the drilling
p3jpaavi is offline Find More Posts by p3jpaavi
Old Dec 16, 2011, 08:35 PM
2Vision-Air
bakchos's Avatar
Blainville, Quebec, Canada
Joined Aug 2009
Hey, anyone care to comment that way of building the biquad,
+ and - ? performance ?
SeattleWireless TV WiFi October 2003 (20 min 10 sec)
bakchos is offline Find More Posts by bakchos
Old Dec 17, 2011, 03:05 PM
2Vision-Air
bakchos's Avatar
Joined Aug 2009
I did the copper tube thing, works great, this is my 1st 2.4Ghz biquad, my 1.2Ghz was working perfectly, can't wait to try this one, i have the bowtie done.
I will drill a hole the size of the wire and pass it from the upper part of the antenna, then i will solder the copper tube to the reflector and crimp my connector to the wire, this should be really strong, 2.4 is so small to work with ! i started with 900mhz 4 years ago.
Here is some pictures of the progress.
All done !! some bling bling fun... i will try it on my router tomorrow and compare with stock antenna.
Old Dec 18, 2011, 11:53 AM
Adekamer's Avatar
Russia Moscow
Joined Mar 2005
very big reflector
it no bad but improved minimal.....
Adekamer is offline Find More Posts by Adekamer
Old Dec 18, 2011, 03:33 PM
Team White Llama!
gundamnitpete's Avatar
i agree, looks big. That said, it's not really a problem from what i understand.....just bulkier
gundamnitpete is offline Find More Posts by gundamnitpete
Old Dec 21, 2011, 11:18 PM
Joined Apr 2011
Can I use the RG-174 cable as the feedline for the biquad or the CP double quad?
pyrojets is offline Find More Posts by pyrojets
Old Dec 22, 2011, 07:28 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^Yes. RG174 works no problem.
@Backhos - That is very similar to how I make my professiona BiQuads. The copper tube is there really just for support. You do not need it for resonance. I designed mine the way I did in this tutorial to keep the parts count low.
-Alex
Old Dec 29, 2011, 01:24 AM
Joined Apr 2011
Hi Alex,
Sorry for going off-topic, but for the CP double quad antenna, can I replace the RG 62 cable for the RG 58 or RG 174 cable? Thank you.
Old Dec 30, 2011, 07:08 AM
Joined Sep 2011
Hello,
Regarding the BiQuad Antenna, I read on a website that when attaching the coax to the feed point it needs to be quite accurate because if it's position is out by only 0.5mm, it can alter the center frequency by as much as 50mhz.
Andrew.
aandrewb2001 is offline Find More Posts by aandrewb2001
Old Feb 01, 2012, 10:36 PM
mykwilwin.com
United States, CA, Tustin
Joined May 2011
im just trying to figure out the wave length of 1160mhz
im coming up with 10.4 but want to make sure with you guys here, thanks..
Since this is a closed loop resonator and I'm going to assume that the pilot is not flying in the rain, there will be no degradation factor. I use a direct speed of light calculation. There are 3 calculations you need:
Full wave length:
Full wavelength in inches = 11732/f in MHz
Full wavelength in cm = 29800/f in MHz
For the following frequencies you have:
910 MHz = 12.89”/32.75cm
1280MHz = 9.17”/23.28cm
2450MHz (2.4GHz) = 4.79”/12.16cm
Section length (this is simply your full wave length divided by 4):
Section length in inches = 2933/f in MHz
Section length in cm = 7450/f in MHz
For the following frequencies, the section lengths are as follows:
910 MHz = 3.22”/8.18cm
1280 MHz = 2.29”/5.82cm
2.4GHz = 1.197”/3.041cm
Element spacing
(this is your full wavelength/8):
Element spacing in inches = 1467/f in MHz
Element spacing in cm = 3725/f in MHz
For the following frequencies, your element spacing is as follows:
910 MHz = 1.61”/4.09cm
1280 MHz = 1.15”/2.91cm
2.4GHz = .6”/1.52cm
That wasn't so hard was it? Now write down those numbers and on to the next step.
mykwilwin is offline Find More Posts by mykwilwin
Old Feb 08, 2012, 02:42 PM
United States, NJ, Millburn
Joined Sep 2011
Is there any way to build the biquad with a wider beam angle? Losing gain is OK, I'd rather have slightly wider coverage. I know with the DIY patch that was accomplished by cutting the panel wider. Anything similar here?
I'm not ready for diversity yet.
ov3rmind is offline Find More Posts by ov3rmind
Old Feb 10, 2012, 01:07 PM
Joined Sep 2011
Alex, any ideas? Is there a way to widen the beam angle of the biquad?
Old Feb 13, 2012, 07:33 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Sadly, This is not possible. You can make a UniQuad antenna. I designed it over a year ago, but never introduced it due to switching over to circular polarization.
Here's what you do: Build a single element quad (only half of the BiQuad). Remember that it must be fed from the side, not the top or bottom. Feed the element with 1/4 wavelength (accounting for velocity factor, of course)of RG179 coaxial cable. Splice the other end directly into your feedline.
That's about 9db or so.
-Alex
Old Feb 21, 2012, 09:54 AM
Joined Mar 2009
I need a directional antenna for my RC link 2.4Ghz.
I want test BiQuad..
How I increase dbi in BiQuad antenna ? ( about 18 dbi )
piopio is offline Find More Posts by piopio
Build Log How To Build a BiQuad RX antenna Talajouy Video Piloting (FPV/RPV) 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose Video Piloting (FPV/RPV) 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO Video Piloting (FPV/RPV) 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
