Old Oct 17, 2011, 04:12 AM
Formosa is offline
Find More Posts by Formosa
Joined Aug 2004
Originally Posted by Shikra View Post
The BiQuad here is for linear antennas - not the best match for your cloverleaf which is CP.
The BiQuad you want is here....
http://fpvlab.com/forums/showthread....e-Quad-antenna
It is directional though unlike the skew plana you have, so you will have to fly in the beam, manually aim or use a tracker
What is best depends upon what you want to do and style of flying !!
Hi
Thanks for your reply.
I have not state my intent clear.
My current plan is to use Cloverleaf and Skew Plana Wheel for all round flying in near field and switch to longer range (at specific direction) using the Biquad, possibly hock them up using video diversity.
That is why I ask whether the CP and Biquad are compatible or not.
So are you saying I need to use inverted V and Biquad combo?
Thanks for your help.
Regards
Formosa
Formosa is offline Find More Posts by Formosa
Old Oct 17, 2011, 05:33 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
They will work, but you will get better results by either using using linear or CP antenna throughout.
This biquad is linear, but there is a CP version at the link above
As you already have the other CP antennas I would choose a CP one
CP patch - easiest to make. I would try first. It should give very good results. Less range than the others, but a wide beam
or for maore range, but less flyable beam...
CP biquad -
CP helical -
Shikra is offline Find More Posts by Shikra
Last edited by Shikra; Oct 17, 2011 at 08:58 AM. Reason: oops error in word... hands faster than brain
Old Oct 17, 2011, 08:39 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Unless you are planning on flying reflections, you want CP on both ends or linear on both ends. A Vee/Biquad is a long range system. Vees are so simple to make it's ridiculous. On the CP side should you choose to stay CP, CP patches are ok, but the helical is where the performance is.
On the other hand, a BiQuad will do fine with the Cloverleaf. The beam is pretty narrow, so multipathing is minimal. It's just not optimal.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 17, 2011, 08:41 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I made up a biquad and it gives same, maybe even better performance than my 14db Lcom patch. Very pleased.
As it is so easy to make I am making a double biquad.
But I have a question.
Is a stacked double biquad viable?
Would both use the same dimensions, with 1/4 wave separation?
As I use a tracker, happy to have a narrow beam width..
http://postimage.org/image/170yz8qdg/
Yes a stacked double BiQuad is viable. It would be a bit of a monster, but it would work. You will need to build a double BiQuad and then stack it like catamar's.
-Alex
Old Oct 17, 2011, 09:08 AM
Shikra is offline
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
The nice thing those is it is so quick and easy to make up the element. I found much easier than the CP designs. Especially hugo's 8 lobe turbine.
I was also thinking about separately stacking 2 double biquads with Y/T coax impedance match. I haven't seen that anywhere and my limited knowledge tells me that its realistic and that would achieve better gain over parasitic type stacking.
mmm maybe quad separate stacked with H impedance match.... small footprint high gain. Time to google !!
Just looked at Catamars picture - that is spot on. Thanks for the tip. All the info I need. Thank you !!
G
Old Oct 17, 2011, 09:10 AM
Formosa is offline
Joined Aug 2004
-Alex
Dear Alex & Shirka
Thanks for your advice.
So I will leave my 5.8GHz thing to close range and use 1.2GHz for long range using inverted V and Biquad. I have the gear anyway.
Thank for your advice, it is clear now.
One more question, for 1.2GHz 800mW VTx, what kind of range I can expected when using inverted V and Biquad combo?
Regards
Formosa.
Old Oct 23, 2011, 02:15 AM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
I built the biquad and it works better than my patch. I really like being able to have it higher than the patch needs to be. I was hoping it would get rid of some interference I get after I get out about 2000 feet. Here's a snippet of the interference. I get it on both the patch and the biquad. Can anyone identify the source? My video signal is good and so far I've gone out more then 8000' with my Spektrum and the interference stays about the same. I can still fly but it's distracting and the video quality is affected.
Here's the video:
20111020 Radian FPV Flight-1-Raw Snipet.avi (0 min 14 sec)
Her are pics of the biquad:
Thanks.
Steve
P.S. I'll post this is some other threads too.
Floater73 is offline Find More Posts by Floater73
Old Oct 23, 2011, 08:57 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Looks to me like external interference. I could be multipathing, but the video doesn't show a shift, just a disturbance. I suspect there is a transmission tower nearby. Just a guess. Your BiQuad looks very good!
-Alex
Old Oct 23, 2011, 04:12 PM
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
-Alex
Thanks. That's what I think too. Probably something near the ground station since I get the same interference in all directions. Some days I don't get it at all. I use two receivers with the EagleEyes and even switched the antennas during the last flight and both receivers get the same signal. The new guardian from Eagletree is so good I switched the antennas while just letting the plane fly on heading hold. It still made me nervous while the video was off.
Steve
Old Oct 25, 2011, 09:22 AM
The Flying Farmer is offline
Find More Posts by The Flying Farmer
^Its what I do^ - FPVholic
The Flying Farmer's Avatar
United States, NY, Walker Valley
Joined Nov 2007
Since this is a closed loop resonator and I'm going to assume that the pilot is not flying in the rain, there will be no degradation factor. I use a direct speed of light calculation. There are 3 calculations you need:
Full wave length:
Full wavelength in inches = 11732/f in MHz
Full wavelength in cm = 29800/f in MHz
For the following frequencies you have:
910 MHz = 12.89/32.75cm
1280MHz = 9.17/23.28cm
2450MHz (2.4GHz) = 4.79/12.16cm
Section length (this is simply your full wave length divided by 4):
Section length in inches = 2933/f in MHz
Section length in cm = 7450/f in MHz
For the following frequencies, the section lengths are as follows:
910 MHz = 3.22/8.18cm
1280 MHz = 2.29/5.82cm
2.4GHz = 1.197/3.041cm
Element spacing
(this is your full wavelength/8):
Element spacing in inches = 1467/f in MHz
Element spacing in cm = 3725/f in MHz
For the following frequencies, your element spacing is as follows:
910 MHz = 1.61/4.09cm
1280 MHz = 1.15/2.91cm
2.4GHz = .6/1.52cm
That wasn't so hard was it? Now write down those numbers and on to the next step.
Hey iBcrazy,
You recommended a biquad for my 1900Mhz cellular broadband connection. In this post you said your calculations are assuming there is no rain. Will that mean if it rains I will suffer a performance loss?
The Flying Farmer is offline Find More Posts by The Flying Farmer
Old Oct 25, 2011, 11:59 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Moisture degrades any antenna. Yagis degrade quickly. BiQuads still degrade, but not nearly as fast. I'd expect the SWR to shift from 1:1 to 1.8:1 or so in rain.
-Alex
Old Oct 25, 2011, 12:34 PM
ecampos is offline
Find More Posts by ecampos
FPVEEE ED
ecampos's Avatar
Quebec, Canada
Joined Jul 2010
As said by IBCrazy, it looks like some external interference. I've experienced this problem too, and i found out that it was caused by airport radars/transmission towers... changed frequency and everything is OK now. Here's a video (advance to 3:37):
http://www.youtube.com/watch?v=xgOIvlJ-P3A
ecampos is offline Find More Posts by ecampos
Old Oct 25, 2011, 04:33 PM
Joined Nov 2007
Thanks guys
Old Oct 27, 2011, 01:30 PM
Joined Nov 2007
Alright, Verizon ponied up a magnetic car antenna. I dont need that but it comes with an adapter from my tiny device connector to a FME Male connecter.
Or does anyone know what connector this is, the tiny one
If not, could I buy this cable with a FME female connector and use it to make my antenna? I didnt see if it was 50ohm or not.
http://usacoax.com/20ft-cell-antenna...cable-lmr-240/
Old Oct 27, 2011, 05:44 PM
bakchos is online now
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
Alex, is this the right RG58U wire
http://www.ebay.ca/itm/STEREN-50ft-R...item3a6b859789
i will cut off the connector.
Thanks.
and is this the correct sma connector ?
http://www.ebay.com/itm/10X-RP-SMA-C...item4cf28cd6ff
Any good suggestion for a crimper ?
thanks
bakchos is online now Find More Posts by bakchos
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 23, 2010 12:52 AM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 04:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 01:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 05:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 09:05 PM
