SMA and N connectors are 50 ohms and are fairly common. In FPV we almost universally use SMA. N connectors are used very often for HAM radio. I would suggest getting an F male to SMA female adapter and using prefabricated cable with an SMA end on it to build your antenna.
-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
-Alex |
-Alex |
Good reference for connector types
Reference for connectors; should be a sticky.
http://usacoax.com/coax-connector-pi...es_photographs Cadzilla <easily confused> Quote:
-Alex |
So long as you separate the elements you should be fine. The only issue you would have is if you wanted to transmit on one and receive on the other. If you are using the array to transmit, it will make it difficult to receive on another band.
-Alex |
| Thread Tools | |
| Build Log How To Build a BiQuad RX antenna | Talajouy | Video Piloting (FPV/RPV) | 21 | Dec 22, 2010 11:52 PM |
| Question DIY Biquad antenna for a 900mHz | Moosthegoose | Video Piloting (FPV/RPV) | 5 | Jan 14, 2010 03:37 AM |
| Discussion Antenna tutorial | JIMOOO | Video Piloting (FPV/RPV) | 1 | Feb 25, 2007 12:04 AM |
| Discussion looking for a DIY tutorial. | TonyBAMF | Beginner Training Area (Aircraft-Electric) | 8 | Jan 10, 2006 04:56 PM |
| I need help to DIY flywire antenna for 36 MHZ RX | GoodHeli | Radios | 5 | Aug 24, 2003 08:05 PM |
