Old Jul 11, 2011, 07:06 AM
Gamblerman is offline
Find More Posts by Gamblerman
Gamble with Gravity
Gamblerman's Avatar
Joined Jun 2011
Sounds like noise floor to me. Something tells me that biQuad was aimed right at the interference source as well as your truck. There is no reason for a whip antenna to beat a high gain antenna when you are within the beam.
Gamblerman is offline Find More Posts by Gamblerman
Old Jul 11, 2011, 02:42 PM
roadgraders is offline
Find More Posts by roadgraders
summitmk3
roadgraders's Avatar
United States, NE, Alliance
Joined Jul 2010
I don't know what's going on. I'm not a guru at any of this...I'm just confused???
roadgraders is offline Find More Posts by roadgraders
Old Jul 13, 2011, 07:23 AM
summitmk3
Joined Jul 2010
Went out and tried a regular patch antenna and was a lot happier with the results. Although it didn't go any further on that particular road it worked better in the hills to the side of the road.
Old Jul 15, 2011, 10:21 PM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
Great stuff! Subscribed.
Chairwolf is offline Find More Posts by Chairwolf
Old Jul 18, 2011, 08:05 AM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
How high off the ground should a BiQuad be?
I know its not ground dependent like the Patch antenna.
I'm using 1.2ghz frequency and I have 2x BiQuads on a Diversity(VidRx).
I have a "V" antenna on my 3meter Glider.
Should the BiQuads be 6 feet off the ground or higher?
I have gone 8km out, but I want to go out further.
The higher the BiQuad antenna's off the ground, should I be able to go out further distance?
LexusFPV is offline Find More Posts by LexusFPV
Old Aug 01, 2011, 06:58 PM
GliderLover is offline
Find More Posts by GliderLover
Joined Apr 2008
hi guys, hi ibcrazy,
thanks for all info you provide, you're an hero
i'm going to build a 1010mhz biQuad for my fppv station. I'm going to use a copper clad pcb board as reflector, but i'm in trouble finding one 300x300mm piece. My question is: can i use two (or more) smaller boards glueing them together? Apart the mechanical problem, do the copper interruption makes some negative effect on the reflector function? and what if i solder junction?
thanks for the info
GliderLover is offline Find More Posts by GliderLover
Old Aug 01, 2011, 08:35 PM
kcleong18 is offline
Find More Posts by kcleong18
KL,Malaysia
Joined Jun 2008
Hi Guys,
Flew a LOS flight a couple of weeks back with home brew IBcrazy's Biquad for 1040 Mhz for the first time. Much better reception than the standard vrx whip antenna and this is with a HK 100mW Vtx thru' a quarter wave wire on an Easystar. Reflector is from a piece of thin metal sheet ( roofing material) and quad made from brass welding filler rods with a short length of satellite tv cable to the receiver..
You can just catch a glimpse of the setup/biquad on a chair at the start of the video.
Kc
fpvglenmarie16thJuly2011.m4v (6 min 12 sec)
kcleong18 is offline Find More Posts by kcleong18
Old Aug 04, 2011, 07:00 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
thanks for the info
That should work fine. Go ahead and build it. Be sure to post pictures!
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Aug 05, 2011, 02:48 AM
JLC_BOULOT is offline
Find More Posts by JLC_BOULOT
Joined Mar 2006
Poor reception
Hi,
I made a Bi Quad for 1.2GHz frequency :
section length : 6.21 cm (used 6.19cm)
element space : 3.10cm
total length : 49.67cm (used 49.5cm)
Please :
1/ How is measured element space ? from the wire center section to the bowtie ?
2/ Is section length difference (6.19 instead of 6.21) very important ?
3/ Is total length difference (6.19 instead of 6.21) very important ?
Today, my BiQuad is not better than the orignal 3db antenna sold with the receiver...
Here are some attached pictures of my antennas, if you can see an big mistake, could you tell me what is it please.
JLC_BOULOT is offline Find More Posts by JLC_BOULOT
Old Aug 05, 2011, 05:31 AM
Rastislavko is online now
Find More Posts by Rastislavko
You can't take the sky from me
Rastislavko's Avatar
Slovakia, Bratislava Region, Bratislava
Joined Jun 2006
JLC_BOULOT: Man, your design is wrong. Absolutely. You must not run both + and - pole of antenna parallel each other like on that picture. The + must be shielded - that's why it must run all the way up in the shielded tube.
You have to redo this part - I think it will work much better then...
Rastislavko is online now Find More Posts by Rastislavko
Old Aug 05, 2011, 06:49 AM
Joined Mar 2006
Thanks a lot Rastislavko !!!!
I'll make changes as soon as I can !
Old Aug 05, 2011, 08:29 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The change that Rastislavko suggested will turn that antenna from bad into the best antenna you have ever flown
-Alex
Old Aug 06, 2011, 06:43 AM
Joined Mar 2006
Exact reference
Thanks for your answers.
I saw IBC antenna a few months ago, and when I had time to make one, I used first link I found... but was not IBC !!! But antenna looked like his...
here the link, it is said it works perfectly :
http://www.modelisme.com/forum/aero-...ion-video.html
Man who works in the only electronic shop I go, is not able to recognize antenna connector... and I'm starting to not believe at all in his radio skill !
I looked on internet, and found so many different SMA plugs...
I'm going to order radio components (plugs and cable RG58U), so could you please tell me where I can get information to know exactly what is this SMA plug ?
I'd like to get connector to solder antenna wire as you guessed.
I suppose radio impedance is 50ohms, I couldnt get this data on my receiver datsheet.
Thank you for your help.
Old Aug 06, 2011, 07:49 AM
Joined Jun 2006
This is not SMA connector. It's called "F-connector". SMA is a little smaller.
Old Aug 06, 2011, 09:10 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You can always just buy an adapter. You need an F male to SMA female adapter. You can find them on Ebay for cheap.
-Alex
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
