Old Oct 27, 2010, 01:14 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Originally Posted by techspy View Post
I will be building this one soon. Couple questions... Does painting (light spray paint) have any discernible effect on performance? I am thinking flat black but would there be any benefit to a chrome/copper type paint?
Painting the antenna element will effect it a bit. You can paint the reflector any colour but use either conformal spray or clear on the element. Plus it depends whats in the paint.
Martin Y is online now Find More Posts by Martin Y
Old Oct 27, 2010, 02:01 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
So long as he keeps it off of the antenna feedpoint, there will be no noticeable effect. Since the paint isn't supporting the element against the reflector, the capacitive effects of an insulator are neglegible.
That said, I am assuming he's spraying it with a thin layer and not building it thick. 1-2 mils of paint will not make any difference. Human manufacturing tolerances make far more of a difference.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 27, 2010, 03:00 PM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
Really nice! I have a Spektrum (2.4) and my TX is in 1.2/1.3 Ghz band...
An external SMA connector on the DX7 to hook up antenna to would be really cool - using Interface Cable RP-SMA to U.FL
I assume it's just to solder a connector to the other end of the Coax ?
(I have plans for a really cool - not seen yet tracking device)
//UndCon
UndCon is offline Find More Posts by UndCon
Old Oct 29, 2010, 07:19 AM
NickTT is offline
Find More Posts by NickTT
Joined May 2010
Just thinking out loud , what happens if you make it a tri quad on a more oblong reflector ?
NickTT is offline Find More Posts by NickTT
Old Oct 29, 2010, 07:35 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
High impedance and thus poor performance. You can make a double biquad and get 13dbi gain or a stacked double quad and get 14 dbi. The double biquad is bigger and easier. The stacked double biquad has a parasitic element and thus it is a bit harder to make, but it is the same size as the biquad. It's basically a biquad Yagi
-Alex
Old Oct 31, 2010, 11:50 AM
Bill Sanford is offline
Find More Posts by Bill Sanford
Destructive testing expert!
Bill Sanford's Avatar
Bemidji, MN
Joined Dec 2003
Very nice Alex!
I'll be building one this week!
You certainly have given a lot back to the FPV community.
Thank you!
Bill Sanford is offline Find More Posts by Bill Sanford
Old Oct 31, 2010, 12:57 PM
NickTT is offline
Joined May 2010
Well decided to build a Bi quad and it is not so hard ,
But
I found my self a piece of 1mm aluminum and it is virtually impossible to solder to ....
So my tip is do not use sheet aluminum stay with copper or steel .....
Nick
Old Nov 01, 2010, 09:49 AM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
Great news to report
I built the BiQuad antenna this weekend using variations of the IBCrazy and Talajouy designs.
http://www.rcgroups.com/forums/showthread.php?t=1301126
I made this BiQuad for 1280mhz and used a SunSky 1.2ghz 800mW transmitter and IBCrazy Vee antenna.
Placing the transmitter on one side of my very dense house and my receiver at the other end of the house, I got the following RSSI readings.
Stock rubber ducky antenna on both transmitter and receiver - 63
Transmitter with Vee antenna and stock receiver antenna - 85
Transmitter with Vee antenna and BiQuad antenna (in phase) - 97 rotate BiQuad 90 degrees (out of phase) = 86
I used 22ga sheet of sheet steel from Home Depot cut to 9.17" square. I used 10ga electrical wire for the sections (I took one long piece and bent it as a single wire) and bent them to 2.29" per section.
One question I have is, the designs call for sections of 2.29". I bent the wire at 2.29" but after the bend was made, the outer dimension was ~ 2.40". Which dimension do you bend to? an inner dimension of 2.29" or outer dimension of 2.29"?? Whatever it is, my antenna worked great.
I made slight changes to the IBcrazy design by cutting 6 spacers out of 1/4" wood dowels and sanding them to 1.15" I ended up epoxying the spacers to the steel reflector (worked well) I used hot glue to secure the antenna to the top of the spacers (also worked well).
I used RG174 wire with an SMA connector but try to keep it short, I noticed that the longer the distance from the SMA connector to the BiQuad antenna, the lower the RSSI reading. I noticed that looking at Talajouy's post that he connected the receiver directly to the back of the center feed, I think that is optimal.
I am still waiting for my eBay 13dbi yagi to see if that will beat this BiQuad but I bet it'll be close.
thekubiaks is offline Find More Posts by thekubiaks
Old Nov 01, 2010, 09:53 AM
Bandarra is offline
Find More Posts by Bandarra
Bandarra's Avatar
UK, South Yorkshire, Sheffield
Joined May 2009
On a funny but truthful note, last weekend at my Gf's house they were pissed that they couldnt watch tv cose the antenna they bought, seems to be some kind of patch with an amp didnt work properly and the picture was worse than poor.
Just for fun I grabbed a bit of "wrapping" thin wire that was keeping one of the antenna cables and quickly shapped a biquad. Literally truck it to the plug on the back of the Tv and it had the best reception ever, I was amazed! ahahah great stuff.
Bandarra is offline Find More Posts by Bandarra
Old Nov 01, 2010, 10:11 AM
FabioBrazil is offline
Find More Posts by FabioBrazil
Joined Mar 2009
Hi IB, for long distance, which one is better?
Patch, Biquad or Yagis?
Thanks a lot, your tutorials are awesome.
FabioBrazil is offline Find More Posts by FabioBrazil
Old Nov 01, 2010, 10:24 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
kubiaks - Nice work! Very nice antenna! I can't wait to hear your results flying it. On the dimensions, the lengths should be from the center to center. You built yours correctly.
FabioBrazil - It all depends on what your goals are. There is no "best" antenna. The antenna determines the propagation pattern onf the recieved wave. They all cover the same area, but some direct it better than others.
The Biquad is a longer range antenna and therefore has a narrower beam than my fast patch. I also prefer it to a Yagi as Yagis can degrade the signal with humidity and other conditions.
I need to build a BiQuad for my homebrew antenna tracker I got the control circuit all soldered up. Now I need to build another Biquad and make the turn table
-Alex
Old Nov 01, 2010, 10:41 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
How about 30dbi for the really long range aficionado's using a biquad and old satellite dish with offset feed...
http://www.trevormarshall.com/biquad.htm
Only problem is, it only has a 4 degree beamwidth (aside from it's physical size!) but hey, at 10+ mile out, that 4 degree is quite wide.
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Nov 01, 2010, 02:44 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That is quite possible to do. You can use any satellite dish, really. The focal point must be at the rear of the antenna, not the front. Admittedly, I have no idea why this is.
I will be building a stacked BiQuad (~14 dbi) later. This can also be used as a feed for a dish and will increase the gain even more
-Alex
Old Nov 01, 2010, 04:43 PM
Devonboy is offline
SW England
Joined Aug 2009
The dish needs to be offset fed as well, because if it's focal point is central, the biquad's reflector (and support arm(s)) will interfere with all those waves you are desperately trying to focus onto the biquad feedpoint.
Could you add the sizes for those of us on 5.8GHz in your 3rd post.
Quad element lengths = 12.9mm each leg
Element from reflector = 6.5mm
Reflector size = 52mm square
Works for me
Also, looking at your figues for 2.4GHz "sectional length" in your 3rd post, you have:
2.4GHz = 1.197/30.41cm
Should be 3.04cm (30.4mm)
Keep up the good work.
Nigel.
Old Nov 01, 2010, 06:30 PM
Bemidji, MN
Joined Dec 2003
Hi Alex,
Again thanks for the great BiQuad information. Mine is about 90% done, but I need a few more nylon nuts to finish it up.
Concerning your home brew antenna tracker, I was thinking along the same lines. I assume you're thinking pan only. Tilt seems rather irrelevant unless you're going for very high altitudes or live in the mountains like Trappy! For us flatlanders, pan should be just fine.
Concerning your schematic. I'm not quite sure what the purpose of the 2k and 390 ohm resistors is on the output of the LM393 op amp??
I haven't looked at an NE555 spec sheet for quite a few years. Is there an easy way to get it to change duty cycle based on a varying input voltage? I don't recall that being a feature of the chip. I'll have to get a data sheet from Digikey on the 555 and check it out. At any rate, this scheme should work with the addition of a circuit to convert the varying comparator voltage to a pulse train with varying duty cycle.
To make it work in application, you'll need two identical high gain antennas (Patch, BiQuad, or Yagi) pointed anywhere from 10 to 30 degrees apart horizontally depending on antenna beam width, etc.
All this being said, the more complex GPS based systems do have their advantages. I could see this system tracking a side lobe and getting confused. A GPS based system won't be fooled like this.
You should start another thread so we can begin discussing this. I like the idea of a simpler antenna tracker without all the complexity of GPS, return link, etc.
The big question is: Will it track well? It should be a fun experiment!
Bill
-Alex
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
